Question about Nokia 6680 Handheld
Code imei number that is 352278013419847
Nokia 1650 security code
Now the first method.
  • Take the phone locked with security code
  • press and hold the unlock button for a while without releasing it.
  • the phone will display now press *
  • quickly press the star button and the phone will be unlocked
    Second method
    This method deals with the serial or imei number of the phone.
  • while the phone is not yet locked, dial *#06# to get the imei or serial number of the phone. Write down the 15 digit imei number somewhere
  • Go to www.unlockitfree.com
  • When the page loads, select, free remote master code
  • In the area provided for imei/serial number, insert the serial/imei number of the phone.
  • Click on generate.
    Once done, a number will be generated, that's the master code for the phone, copy and keep the number. When ever that particular phone is locked with security code and you want to unlock it, even though you don't know the phone's security code, just enter that number, i.e. Master code and it'll be unlocked!
  • Jun 03, 2013 | Cell Phones
    My imei is 333333333333333,how is the code?
    Your IMEI Number is Invalid,so please Provide the correct IMEI Number,To know the IMEI Number type *#06# then it shows the IMEI number remove the special character and dashes and that is IMEI number,Then it asks for Network Unlock code means it may come 15 or 13,16 digit,Master reset code differ,Network Unlock code to unlock from Network lock,to use other GSM Network Sim card,master reset code to reset from security lock,Get the Network Unlock code from here
    Unlocking4free.com ALSO get the master reset code there.
    Aug 17, 2011 | Nokia 6600
    What is the NCK code to unlock Sony Erricson W350 please?
    Before you get a unlock code you need to provide the IMEI number. Every phone has a code that is as unique as a fingerprint, it is called an IMEI number. To locate your unlocking code we need you to provide us with your IMEI number. (You can either locate your 15 digit IMEI number underneath your battery, usually on a label, or alternatively you can simply dial *#06# on your phone)
    Feb 27, 2010 | Sony Ericsson W350i Cell Phone
    Security code lock
    Hi Friend,
    From the below link u can get the security code by providing your IMEI number,to get the IMEI number u must just*#06# or at back side of the mobile u will have serial number is as same as IMEI Number,
    http://mastercode.nokiafree.org/
    Or try this below mention code
    4107367127
    1072357407
    Regards,
    Ayyasam
    Jun 22, 2009 | Nokia 6070 Cellular Phone
    Unlock code for Nokia 2720
    To unlock your Nokia 2720 phone you will need to enter the code. This code is just a calculation of IMEI number of your phone. To find your phones IMEI number -type *#06# into your phone or look under the phone battery.
    There are different online services that will calculate the unlock code for your IMEI number. I can recommend this one (cheap and reliable).
    Click here to unlock your Nokia 2720.
    Note: don't share your IMEI number on free forums like this.
    May 20, 2009 | Nokia 6101 Cellular Phone
    I need a free vbag activation code
    THIS IS U R CODE FOR VBAG1.1 :774798469674773000000000000000
    Jul 12, 2008 | Nokia 6600
    Unlock code
    hi i can help you but the master code will only work if the phone is asking for the code when you switch it on also it will only work if the wrong code hasnt been entered more than 5 times if it has then your going to need flash lead and unlocking software witch costs more than the phone.
    Anyway if you want the master code for your phone then i need your imei number so that i can generate your master code as each phone has a certain master code set by the imei number.
    The imei number is located on back of phone under battery and looks similar to 123456/12/123456 its about 15 numbers long once i have this i can get the master code for your phone ok speak soon
    Mar 19, 2008 | Nokia 7610
    Forgot security code
    IMEI number should b 15 digits press *#06# to get it after that i will give u the unlock code
    Nov 28, 2007 | Nokia 1600 Cellular Phone
    Nokia 6680 Handheld Logo
    48 people viewed this question
    Top Nokia Computers & Internet Experts
    Computer Links
    Gopi Venkatesan
    Gopi Venkatesan
    Are you a Nokia Computer and Internet Expert? Answer questions, earn points and help others
