Question about Konica Minolta Bizhub Pro C6500 Color Copier Color Printer
Error code C2804
What is the error code C2804 on the Bizhub pro C6500 Color copier/printer and how do I fix it? Thanks!
  • 19 Answers
SOURCE: bizhub 350 error code
c3852 means low fuser(hot section) temp setting. hold down utility or stop key, then you should be abel to do trouble reset. if problem persist it would most likely be a lamp or a sensor, which will require a technician to come out.
Posted on Apr 16, 2008
Bizhubman
  • 108 Answers
SOURCE: Have a konica bizhub c6500
C 2861= Gamma correction/Y aborted. Patch output voltage is high.
Possible causes: Printer control board (PRCB) Developing unit/Y
PGC sensor (PS11)
Posted on Oct 01, 2010
SOURCE: konica minolta Bizhub C6500 error code 2424
Hi, I have a C6500 Bizhub pro, but, recently displays an C2404 error. I need to print an urgent job and y can't!
Please helpme!
Posted on Sep 15, 2011
sinclair_cum
  • 38 Answers
SOURCE: konica minolta bizhub pro c6500 error c2452
i have checked all those parts and tested them with a multimeter and there seems to be no problem is there any other way i can overcome this problem
Posted on Nov 15, 2011
  • 1381 Answers
SOURCE: bizhub c6500 error code C-3913
Check the fusing position, check all connector, make sure everything oke, and doing this adjustment:
Utility => Stop => 0 => Stop => 0 => 0 => 1. This is to prevent accidental reset of the code and causing additional damage to the machine. To reset a fuser abnormality code, perform the following:
1. Power the machine OFF from the main switch leaving the sub switch ON.
2. Press the utility Key and power ON the machine from the main switch.
3. Enter Stop => 0 => 0 => Stop => 0 => 1.
4. Press [03 System Setting] on the touchscreen. 5. Press [01 Software SW setting] on the touchscreen.
6. Press the left up-arrow, which is displayed on the touchscreen, 2 times. The number displayed above the up-arrow will change to 03.
7. Select the bit number of switch 1, using the right up-arrow, 03-1 will be indicated.
8. Press the [Return] key, which is displayed on the touchscreen.
Posted on Dec 22, 2016
Error code C-2704 mean on C6500 Bizhub Pro
Abnormality in the black charging unit.
Possible causes:
Black charging unit
HV Unit
Print Control Board
My best guess is that you have a faulty charge unit. Try swapping the units around with another colour and see if the fault code shifts.
Dec 30, 2013 | Konica Minolta Bizhub Pro C6500 Color...
Error code c0101
konica monalta c70hc error code c0101
Sep 01, 2013 | Konica Minolta Bizhub Pro C6500 Color...
Bizhub c 6500 pro code 2840
help me Konica C6500 error code 2840. thanks
May 14, 2013 | Office Equipment & Supplies
Error c2804
C-2804 While in the gamma correction,
the dirt correction of the gamma
sensor is not sufficient. When this
condition is detected 10 times in
succession, the error code is displayed
Jan 08, 2013 | Konica Minolta bizhub 750
Error code 4701 for Konica Minolta bizhub pro C6500
- 4701 error
Communication fifo problem error 4702/4701 of 5500;6500;6501 konica minolta mfp printers
1) reseat all connectors in Ipb
2)image memery controle board
Inspite doing all these if the problem persists please reload the firm ware/flash firm ware.
Last one is to replace image memory board only .no need to replace prcb; overall status board; nvram
Jan 09, 2012 | Office Equipment & Supplies
Konica minolta Bizhub C6500 error code 2424
Please helpme!
Jan 07, 2010 | Konica Minolta Office Equipment & Supplies
Trouble shoot error code 2701 in bizhub c6500
Probably this would help you.
http://www.cleanerrors.com/fix/error-2701/
Plz dont forget to rate me....
Oct 19, 2009 | Canon BJ C6500 InkJet Printer
Konica Minolta Bizhub Pro C6500 Color Copier Color Printer Logo
460 people viewed this question
Top Konica Minolta Computers & Internet Experts
Lawrence Oravetz
David Payne
David Payne
Tom Chichester
Are you a Konica Minolta Computer and Internet Expert? Answer questions, earn points and help others
