Question about Dryers
Mde9316ayw I have a Maytag mde9316ayw dryer. The unit began buzzing only when pressing the start button and the timer seemed dead. I swapped out the timer and now I can hear it working however the unit still only buzzes when I press start. I bypassed both fuses, motor seems to check out, what could be the issue?
    Problem Solver:
  • 18 Answers
Sounds like u got a bad motor. try holding the lid or door switch in while u press the start button. if u give the tub a little help and it starts going then it is the motor.
Posted on Jul 25, 2013
  • 90 Answers
SOURCE: Buzzing noise when pressing start button
does the buzzing noise sound more like a hum, if so could be a bad motor or possibly something stuck in blower wheel.
Posted on Jan 05, 2008
IFIXALL
  • 868 Answers
SOURCE: Dryer will not start when start button is pressed, makes a buzzing noise
Mode land serial number?
Posted on Jun 02, 2008
rickzilla
  • 706 Answers
SOURCE: Amana Dryer won't start
Depending on your interpretation of the 'buzzing' sound compared to mine, I'd say it may be a relay chattering or the motor trying to start up but the windings are beginning to fail. You may want to clean the motor housing from dust etc and make sure that you do that with the power disconnected. Also: with no clothes in teh dryer..try rotating it around and feel for any spots in that rotation that may be binding.. if the drum has excessive restriction while rotating.. the motor may not have enough torque to overcome that and just buzz,,, Hope that helps...
Posted on Aug 14, 2008
  • 1122 Answers
SOURCE: WON'T COME ON AT ALL.
you have not said anuthing about ohming out the start knob,and have you checked both legs on the power cord are getting 120 volts each?let me know what you find-mike
Posted on Oct 02, 2008
  • 8 Answers
SOURCE: Amana gas dryer wont start. just makes a faint buzzing noise
The drive motor starting capacitor is likely dead. This can be tested if you are competent enough to take the thing apart and use an electronic multimeter. Otherwise it is a cheap part to replace, depending on how much the repair guy charges for labor and to be called out.
Posted on Dec 09, 2009
My maytag Neptune dryer is not working. It makes a noise when you hit the start button but doesn't start. The timer continues to go until it reaches stop. Have checked belt and it seems to be fine? Any...
I have worked at sears appliance have come across exact or similar problems. You push the button and you hear something like a loud buzzing. My experience has been that the drive motor is locked and needs replacing. Depending on the age of the dryer and the cost of a motor and installation, you might but another dryer.
Mar 03, 2015 | Maytag Neptune MDE4000 Electric Dryer
I have a Maytag dryer model no mde9316ayw It buzzes only
How about the door switch attached to the door latch assembly. If it does not close the device will not get power
Sep 21, 2017 | Dryers
MAY MAYTAG DRYER WONT START I HAVE POWER WHEN I PRESS THE START BUTTON IT SOUND LIKE IT SHORTED OUT
HI
Need to know what the unit does, Buzz, nothing? Because if it buzzes it could be a clogged blower or bad motor, its important to know this information.
Please get back to me
Sep 08, 2011 | Maytag PYE2300AY Electric Dryer
The timer makes a loud buzz sound and the dryer will not start
It sounds like your motor has gone bad....it will buzz really bad when it is tring to start and cannot...
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
heatman101
Asker's Testimonial " Thanks so much for your help. Now that you'v mentioned it, the buzzing does sound like it's coming from the motor. I'm,now, more comfortable in call " -
Apr 09, 2010 | Maytag PYE2300AY Electric Dryer
MY MATAG #MDE9316AYW RUBBING SOUND NO START WHEN HOT
the drum of the dryer that holds the clothes has a seal surrounding the entire front of the drum. once dried out alot of build up is accumulated and will cause your problem. also the belt and tensioner should be looked at as well when opened up for inspection
Feb 06, 2010 | Dryers
Makes buzzing noise when pressing the start button but doesn't always start
With the dryer off, try to turn the drum by hand 1/4-1/2 turn, then turn the dryer back on and push the start butteer and see if this helps.
Sometimes motors get a dead zone in them and this will help move it from the dead zone.
If this does not help then your problem could be a bad motor, broken belt, faulty start switch or faulty timer switch.
Hope this helps
Sep 26, 2009 | Maytag Dryers
Start switch does not work properly
The start switch is stuck closed. Replace the start button switch.
Sep 03, 2009 | Dryers
Maytag Dryer - funny buzz sound and then nothing
my dryer makes a buzzy sound bt it wnt start just make a buzzy sound
Jul 10, 2009 | Whirlpool LER4634J Electric Dryer
Maytag MDG9316AWW Wont start
HI again. this seems to be a wiring harness issue. there may be a lose wire connection or some corrosion on the couplers that are connected to the timer and push button starter. I recommend checking all wires and clips for lose and corroded ends. make sure the clips aren't touching any other individual wire clips. The second issue may be the timer itself. it may have some damage with in the circuitry.
This reoccurring issue leads me to believe that there is something abnormal within the current flow. this. This abnormality is continuing to blow the starter switch. there are only three areas you can check to find this issue. the timer itself should be check for proper voltage and the wires and harness should be inspected as well. The last check would be the terminal block. Check the terminal block for lose power cord wire connectors.
If you have anymore question, please feel free to ask:)
Apr 08, 2009 | Maytag Dryers
Dryers Logo
66 people viewed this question
Top Dryers Experts
