Question about Dell E153FP 15" LCD Monitor
Dell monitor power button is flashing
Dell E175FP has dark screen. I tried to disconnect it from computer and leave AC cord only, the result is the same. While monitor plugged in to AC the power button flashing green, the screen is dark. I am saying it's dark but it's not complettely dead because there are very very low visible flashes also, they are hard to see. Seems like these flashes on screen and on power button going together at the same time.
  • 2 more comments
  • Anonymous Nov 04, 2007
    My monitor does the same thing. I have a Dell Dimension 2400 that's about three years old. Lately, upon booting up, the monitor shows the welcome screen but then goes blank. The power light starts to flash quickly and a slight, ghostly flash plays on the screen. Nothing I try works to stop this, except tapping the plastic casing with my knuckles! After a few times, the screen starts to work normally. I'm getting fed up with this.
  • Anonymous Jul 15, 2008
    my E153FP dell monitor has the same problem. the power botton flashes green and the screen is dark with flashes.
  • Texas Dude Jul 22, 2008
    I have a Dell 22 in. 2005FPW that is doing the same thing. It was working before lunch and when I returned the power button was flashing, and the screen was flashing on very briefly. I never did see any thing displayed on the screen though, it just flashes a black screen for less than a second and then repeats the cycle over and over. Anyone know what causes this, or better yet know a solution. I am willing to crack it open to try and fix it.
  • Anonymous Mar 12, 2009
    I am having the same problem on my dell 15" Monitor. But it only happens about half the time. The power button is flashing and that has a "Ghost Effect" on the monitor like others mentioned but nothing on the monitor shows. Then other times I will start my computer up and the monitor will work just fine. Not under warrenty anymore so I don't know what is best to do now.
I had the same problem. After buying another monitor and before throwing this one away I thought I would try plugging it in since it was sitting for a day. I still received the flashing light until I gave it a slight hit on the back side, it is now working fine.
Posted on Feb 27, 2009
  • 1 more comment
  • Dean R
    Dean R Nov 28, 2015
    Haa! This is hilarious. I've been scouring the Net for days trying to find a solution to the same problem. Most hits have lead to replacing bulging capacitors in the monitor. Then I saw this post, gave my monitor a whack and presto, display restored.
    I'm sure there are still some electrical or mechanical issues and this is just a temporary fix. but I wasn't looking forward to opening this up and futzing around with circuit boards.
    Thanx for the chuckle Gorgas!
  • Jeddediah Chapman
    Jeddediah Chapman Jan 21, 2017
    There's something to be said about about this method...Just tap t in! Give it a little tap tap taparoo! It works
  • Pam H
    Pam H Jul 14, 2017
    "I gave it a slight hit on the back side, it is now working fine." Worked!! Thanks Gorgas!
We had the same problem noted here. Dell PC & monitor about 5 years old (maybe more). A little "pat on the back" of the unit cleared things up and got the floating colored box. Reconnected to PC, and everything is good. Thanks for the tip Gorgas, that's not something I would normally have tried with expensive electrical equipment.
Posted on Apr 17, 2009
    Problem Solver:
  • 19 Answers
If you have the monitor on, but no video signal (for whatever reason) you should get a floating "Dell Self Test Feature Check" window with red, green and blue lines on it that shows the monitor is actually able to display a picture. Disconnecting the video cable is the easiest way to try to see this, and would show if the monitor can display anything. If you don't see that with the power on and video cable unplugged, then the monitor itself is most likely the problem (since you said the power light is on). If this is the case, you would need to contact Dell Technical Support to see about getting the monitor replaced, assuming it is still covered by its warranty. If you are not sure about the warranty, tech support will be able to check that as well. While it is bad news, hopefully it will help. Larry Dell Customer Advocate
Posted on Sep 05, 2007
  • Glennewen Aug 05, 2011
    If TVs were as **** as your monitors, no-one would buy them. It is, essentially a TV and none that I've ever had has lasted less than seven years. I dunno how you get away with selling such unreliable garbage.
    New Friend:
Same problem. smacked the back of the monitor and voila. Thanks
Posted on Jul 11, 2010
    Sergeant:
  • 279 Answers
Check the power supply (brick attached to the power cable). Does the light on it flash the same way the power button does? If so, you have a bad power supply. I could not find your model monitor on Dell's site, which means they don't carry it anymore. But, if you email Dell and tell them you need a new power supply for an E175FP, I'm sure they can sell you one. Or, you may be able to find it by putting your service tag in here: http://accessories.us.dell.com/sna/DellPartsFamily.aspx?c=us&l=en&RPU=1&s=gen
Posted on Aug 30, 2007
  • Mike Honcho Oct 31, 2010
    Same issue. Light was flashing green, no picture. I pimp smacked it. Everything is working fine now. Thanks folks.
    New Friend:
Had the same problem, read the post, slapped it on the back and presto!! Thanks
Posted on Jul 18, 2012
    New Friend:
I just repaired two of these Dell monitors and they both had the exact same problem. Blown capacitors, it's about a 10 dollar fix and there are a dozen youtube videos that show you how. I almost guarantee any of you that is all that's wrong with your monitors. Apparently there was a flood of bad capacitors manufactured between 2000 and 2005.
Posted on Aug 05, 2011
I did figure out what wasn't wrong. We had another one that had a broken LCD, so I just swapped out the power supplies. That didn't fix it. Something on one of the controller boards went bad. Dell sent us a new one anyways.
Posted on Nov 04, 2008
  • Texas Dude Nov 04, 2008
    I found out that it wasn't the power supply. After taking apart one with a cracked LCD I discovered the problem remained. The other had a good power supply so I just moved the LCD screen over to the busted one. Then dell sent us a replacement. so fixed one that had run out of coverage and had the other replaced.. that was nice of dell.
  • 45 Answers
It's usually one or more capacitors heading south. Very common problem, unfortunately, if it is an older monitor it may not be cost effective to take it in for repair. Drop in to your local Thrift/Goodwill store. They usually have a half dozen older working monitors you can pick up for $20 - $30. A fraction of the repair cost.
Posted on Aug 07, 2016
    New Friend:
  • 168 Answers
When it have this kind of error is a problem of the powerboard.
Anyway you must open it and look at the all capacitors and if are them inflated, if them are inflated must change them.
But can be a problem with inverters... control the transistors - MOSFET on the powerboard.
Posted on Oct 04, 2014
    New Friend:
Amazing! Same problem. 2005 Dell monitor model E193FPc. Tried various combinations of pushing/holding buttons, unplugging power/computer.
Read on a Dell Community post from 2007 that it is likely a bad, "bulging" capacitor problem that can be fixed for $2-$4 and a soldering iron, with some carefully handling of the various capacitors, a multimeter - and take many pictures to get it back together correctly. I have don\'t have/never used a soldering iron, and didn\'t have any luck a few months ago when attempting a blow torch fix for a faulty \'08 Dell laptop video card, so wasn\'t interested in taking a chance with the soldering iron testing and repair. Resigned myself to needing a new monitor.
Searched one last time before shopping, found Gorgas solution above, slight slap on the back and "presto"! It came on. Amazing that the stereotypical, frustrated "hitting" of a technical machine actually fixed it. Hope it lasts.
Posted on Sep 22, 2013
I had the same problem. it showed the colors in a box. all u do is make sure the the cords with the blue top are connected. thats what i did. worked perfectly
Posted on Jul 13, 2008
SOURCE:
Dell computer won't start up.
Please connect an external monitor, and turn on the power. If it is working, then it is video and LCD problem.
If not working on external monitro, try to remove the battery, then unplug AC adapter. Then press and hold power button for 30 seconds.After that, put battery back and re plug AC. Turn on the power. If still not working, and no display on screen, Then the motherboard need to replace.
May 09, 2010 | Dell Inspiron 9300 PC Notebook
My monitor is flashing on and off. The screen is
Check for poor solder joint oat the AC inlet, common problem due to poor design to support the AC inlet connector, see pictures here: http://s807.photobucket.com/albums/yy352/budm/Dell%20E153FPB/
Mar 27, 2010 | Dell E153FP 15" LCD Monitor
Can't power on my DELL 1707FP monitor
Try a different wall outlet. If no go swap the monitor and tower power cables. I still no joy disconnect the power cord from the monitor, hold the power button for 10 seconds with the power cord disconnected. Try Plugin intu cable. If the screen is still dead check with dell tech support if the monitor has a warranty active on it. If the warranty is out get the monitor checked at a local computer shop.
Aug 08, 2009 | Apple Power Mac G5
Dell E228WFP two months out of warranty -monitor on and off
if your purchase just the monitor on 2/28/200, normally dell gives 3 years warranty for the monitor If purchased Separately.
OK.. try doing this call Dell.. 18004563355.. JUST give them the serial number of the monitor ONLY they'll check it out then if your lucky they'll send you a replacement.
Apr 23, 2009 | Dell E228WFP LCD Monitor
Dell E173FPc monitor. Screen is black, power button color cycles
First, verify the monitor is functional.
Monitor STFC (Self Test Feature Check)
Turn off the monitor
Plug the monitor power cord directly into the wall socket to remove any
surge protectors or APCs from the troubleshooting equation
Unplug the monitor video cable from the back of the computer
Turn on the monitor
The floating dialog box should appear on screen against a black background.
If the issue appears during the STFC, the monitor is defective.
What are the results please?
Feb 24, 2009 | Dell E173FPc 17" TFT LCD Flat Panel...
Dell monitor problem
Disconnect and reconnect both ends of the video cable (while the computer and monitor are both off). Also disconnect and reconnect the power cable. Is the power cable plugged into the same surge protector as the computer? And also try a different outlet on the surge protector for the monitor.
Jul 22, 2008 | Dell E153FP 15" LCD Monitor
Monitor image flashes off and on
Sounds like you've done all the trouble shooting. If you just need that extra nudge, I would agree... it sounds like you'll be needing to shop for a new monitor.
Jun 29, 2008 | Dell E153FP 15" LCD Monitor
Monitor problem
Try unplugging the video cord from the computer.
If it does the same thing then it is not detecting your cord.
If so, try a new cord.
What does it say on the screen if the above does not fix it.
Feb 23, 2008 | Dell E176FP 17" LCD Monitor
20V AC power adapter for Dell 2001FP 20" LCD monitor
try to contact dell spare parts department. they may give you a good price.
Feb 01, 2008 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Dell E153FP 15" LCD Monitor Logo
48,048 people viewed this question
Ekse
Clive
Clive
