Question about Rock & Ice Climbing
Fridgemaster univa stove gas
Why does the flame in the oven go out for no reason?
  • 6 Answers
SOURCE: oven produces soot when running, broiler ok, stove top ok
Al, you need to seat the needle valve on the bake. Remove the bottom drawer, right below the bake burner you will see the nut just below the air shutter adjustment. Turn this nut clockwise a few times, it might seem hard but just do it. Then try the bake again, you should have a nice bluel flame. Tenbears.
Posted on Dec 20, 2008
  • 95 Answers
SOURCE: Kenmore gas stove. Oven burns big flame which soots
The manifold needs to be cleaned and adjusted could have rust etc in it Not a good thing to do yourself unless you know what you are doing
Posted on Jan 24, 2009
bozcro
  • 867 Answers
SOURCE: xl44 oven burner pulses, doesnt properly heat up.
it seems the burner in the oven is clogged, by grease, carbon or corrosion, it may need replacing, specialy if this is an older unit
Posted on Jul 30, 2009
vinzen
  • 217 Answers
SOURCE: Where is the pilotlight on a ge xl44 gas stove
In general lets be clear. The OVEN pilot is located under the oven door at the top of the Broiler.It is a small piece of metal just before the GAS safety Valve which acts on temperature so gas won't flow unless Pilot is lit,That's the OVEN PILOT.The stove's RANGE is the top burners where you heat Pots and Pans.It has either 2 Pilot lights that connect the burners to the Flame they are under the Range Top.Newer Models use electronic ignitions no flame.Please note if you had your stove/oven disconected or Gas off when you turn it back on there will be air in the line that needs to escape before you light.This is why in NYC when Utility Co.works on steet main the MUST re-light your appliances.Be Careful with Gas.Good Luck.
Posted on Sep 19, 2009
  • 42 Answers
SOURCE: Stoves panache 600 SIDLm - oven full on
NEW THERMOSTAT IS REQD.
Posted on Sep 28, 2009
Oven igniter comes on gas burner lights but goes out after 15 seconds cutting power to the stove power comes back on after a couple of minutes model mgs5770
Hello Susan,
it is not quite clear to me what you mean.
But I think, the ingition in the gas oven works and lights the burner.
and then after 15 seconds the burner goes out.
Any modern oven has a Flame Failure Device.
That prevents the oven getting gas when the burner went out for some reason.
I would suspect that FFD, it is mounted besides the burner.
You can not repair that part for safety reasons, You have to replace it when it is gone.
Kind regards, Dik
Flavel Leisure Cooker Spare Flame Failure Device FFD CO1464
Feb 10, 2018 | Kitchen Ranges
Oven not lighting
Replace the oven igniter. If it is a flat/rectangular shaped igniter use part# 5303935066:
Range Stove Oven Igniter 5303935066 .
If it is round, use part #:
Range Stove Oven Igniter 4342528
Jul 12, 2016 | Kitchen Ranges
Magic Chef Chateau stove pilot goes out when two burners are used!
The pilot flame may not be set high enough to cope with the demand of two burners.
Dec 19, 2013 | Ovens
I bought gas cook stove used. I have propane gas & I don't know what kind of gas the stove was set up for. When oven is on it smells strongly of gas, food cooked in oven has black soot on it and flame...
There is a regulator behind the bottom drawer remove the drawer.look in the back you will see a silver box that the oven fuel rail is on just below the rail there is a brass fitting that needs to be turned clockwise till it stops it can be hard to turn some times but turn it till there is no clearance between the nut part of the valve and the silver box then you can start your oven and it should work fine you can also adjust it to get a little more flame if needed.
Feb 03, 2011 | Frigidaire Gallery GLEFM397DS Electric...
Need wiring diagram univa stove /oven model ph14s
Were do I get the skimatics for a stoves wiring as I have to put the regulater back to geather as old one fell apart.
Jan 22, 2010 | Ovens
Where is the pilotlight on a ge xl44 gas stove I belive it is in the door under the oven well I turned the gas on and stuck a flame down there and nothen took off is there a certian place to put the flame....
Sep 19, 2009 | Ovens
Poorly functioning Shipmate stove
Hi
Normally pressing red buttons on stoves is for lighting the oven. You press the button, light the pilot light, leave it depressed for a minute and then that heats up the thermocouple, which opens a valve and allows gas to the main burner.
Shipmate Stoves are still in business, so you could contact them. The link also suggests places for Shipmate propane gas stove spares.
Shipmate stoves Google Search
Mar 27, 2017 | Brown Stove Works 23 in. TL03-3 Gas...
Oven burner flame is low
0000000.jpgOn top of that safety valve is a nut. Get a good fitting wrench. Turn on the oven and use that good fitting wrench on that nut. Turn it counterclockwise till the flame comes up about midways of the flame spreader. Don't get the flames too high. Midways of the spreader now. LOL
Jan 02, 2009 | Ovens
Gas stove
The most common reason for that is that the oven ignitor is bad. Part number WB2X9154.
Nov 10, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Rock & Ice Climbing Logo
316 people viewed this question
Top Rock & Ice Climbing Experts
Makenzie Floyd
Level 1 Expert
Betty L Kidd
Betty L Kidd
ray gallant
Are you a Rock and Ice Climbing Expert? Answer questions, earn points and help others
