Question about Hr Carbon Fiber Hard Case Coverlcd Screen Protector For Metropcs Zte Score X500m X500 M
Zte x500 metropcs diagnostic mode keys
I have a ZTE x500 metropcs phone which is working on voice alright. I want to be able to configure data on it but the difficulty is that, am not able to send the phone into diagnostic mode for configuration and programming. Kindly help.
Zte score stuck on muve music screen loop
Hey i've been workin on these ZTE phone and i guess all u need to do is a reset. But the only problem is u will lose all ur data. all u gotta do is First power off the handset, press the Camera key + Power on key +Down volume key together at the same time.
when restart the handset,When display "ZTE", press the Menu key at the bottom of the screen;
Choose "Wipe data/factory reset" through volume key
Press "Camera" key to confirm the above item
Choose "YES...delete all user data"
Choose "reboot system now", handset will be restarted automatically and all the user data will be erased.
Now once its done ur phone will automatically configure all the factory setup and should work fine,
Apr 09, 2013 | ZTE Score
Transfer my phone number to new phone
If the phone still turns on, transfer all your contacts to us SD card and use the same SD card on ur new phone.
Mar 22, 2013 | ZTE Score X500
Forgot my lock code
If you have forgotten the password to unlock X500,you need to reset the phone also it will erase all the user personal information. First power off the handset, press the Power on key + Camera key + Down volume key together at the same time when restart the handset.When display "ZTE", press the Menu key at the bottom of the screen;Choose "Wipe data/factory reset" through volume key Press "Camera" key to confirm the above item Choose "YES...delete all user data" Choose "reboot system now", handset will be restarted automatically and all the user data will be erased.
Mar 18, 2013 | ZTE Score
My ZTE muve cricket phone is stuck on the lock pattern screen and when I go to unlock it all the circles do is flash red and green and wont let me draw the pattern?
I have a Cricket X500 phone and to reset this phone I use the following instructions:-
1) First power off the handset, press the Power on key + Camera key + Down volume key together at the same time when restart the handset.
2)When display "ZTE", press the Menu key at the bottom of the screen;
3) Choose "Wipe data/factory reset" through volume key
4) Press "Camera" key to confirm the above item
5) Choose "YES...delete all user data"
6) Choose "reboot system now", handset will be restarted automatically and all the user data will be erased.
Jan 23, 2013 | ZTE Cell Phones
ZTE-X500 USB DRIVERS
There is no need of USB drivers for this device. If the phone uses SD card function, directly connect the phone to the PC through the data cable. As "USB connected" appears at the top of LCD, use your fingers to pull down the top, tap "USB connection" and then select "Mount USB".
Jan 21, 2013 | ZTE Score X500
How to reboot x500
3) Choose "reboot system now" through volume key
Jan 13, 2013 | ZTE X500 Score - Black cricket Smartphone...
How can i make my zte score x500m go past the metropcs logo screen
You can perform Hard Reset and check if it works.To reset, you can refer to the following method, which can reset the phone and erase all the user personal information.1) First power off the handset, press the Power on key + Camera key + Down volume key together at the same time when restart the handset.2)When display press the Menu key at the bottom of the screen;3) Choose "Wipe data/factory reset" through volume key4) Press "Camera" key to confirm the above item5) Choose "YES...delete all user data"6) Choose "reboot system now", handset will be restarted automatically and all the user data will be erased.
Jan 07, 2013 | ZTE Score
Zte score x500 muve music won't launch?
Try Hard Resetting the device and check if it works.1) First power off the handset, press the Power on key + Camera key + Down volume key together at the same time when restart the handset.
Dec 10, 2012 | ZTE Cell Phones
Need to unlock my metro zte phone
should be the last 4 digits of your phone number.
May 25, 2012 | ZTE Cell Phones
Hr Carbon Fiber Hard Case Coverlcd Screen Protector For Metropcs Zte Score X500m X500 M Logo
355 people viewed this question
Top Hr Photography Experts
Tony
Are you a Hr Photography Expert? Answer questions, earn points and help others
