Question about Dishwashers
Dishwasher will not turn on
Caloric model dus500b-55 checked power source...good
4 Suggested Answers
  • 360 Answers
SOURCE: Dishwasher will not work--no lights are on.
I would first check/test the door switch
Posted on Mar 31, 2009
  • 5603 Answers
SOURCE: need a manual for Caloric model dc52151W0A
You are correct. The water sent to the DW should be from your hot water source. No need for a manual on that one!
Posted on Oct 09, 2009
  • 827 Answers
SOURCE: DISHWASHER WILL NOT TURN ON WHEN I PUSH THE BUTTON. i CHECKED POWER TO THE UNIT AND IT'S GOOD.
Are you certain the door is closing at the switch,. if not, inspect the close door switch real well.
IS there any water in the bottom -- perhaps it may be clogged and refuses to call for more water (i.e. turn on).
Best regards,
Ck
Posted on Dec 04, 2011
Samsung ln 55 wont turn on
Hi
First,
Re-check the power connections.
Check the power source by plugging another device on the same source.Replace the power cable.
Hope it helps.Thanks
Feb 19, 2012 | Samsung SyncMaster 2233BW 22" LCD Monitor
For a ge dishwasher mod#ghda485nools:on startup mode lights blink and pump turns for 10 seconds then shuts off
00023396.gif small_9_26.jpg For a detailed Dishwasher illustration, click below.
redarrow.gif Built in
transparent1.gif Find a part for your Dishwasher godark_3.gif How Dishwashers work godark_3.gif What is wrong with your Dishwasher? godark_3.gif Email the RepairGuru for help with your specific problem godark_3.gif Maintenance tips for your Dishwasher godark_3.gif Answers to common questions about Dishwashers (FAQ) godark_3.gif Locate your Dishwasher model number godark_3.gif Accessories for Dishwashers godark_3.gif Appliance Recall Information godark_3.gif RepairClinic.com is the web's best resource to buy parts for your Dishwasher and get free Dishwasher repair advice for all major brands of Dishwashers including Admiral, Amana, Asko, Bosch, Caloric, Crosley, Electrolux, Estate, Frigidaire, GE, Gibson, Glenwood, Hotpoint, Insinkerator, JC Penney, Jenn Air, Kelvinator, Kenmore, Kitchen Aid, Magic Chef, Maytag, Modern Maid, RCA, Roper, Tappan, Thermador, Westinghouse, Whirlpool, White-Westinghouse, and more.
Jul 04, 2008 | GE Dishwashers
No water
Check the incoming water to the dishwasher. If the filter is clogged clean it and re fix. Strainer is located on the machine inlet junction where the hose is fitted.
The humming sound is due to motor running without water. When you rectify the inlet flow fault, pour additional water manually into the wash chamber and run the cycle. This to remove trapped air in the pump due to dry run.
May 28, 2010 | Caloric 24 in. CDU300C Built-in Dishwasher
Bosch Dishwasher (SHE44C05UC) won't turn on
Just had the same problem, same model. Found the wiring below the front cover fried. So now I'm checking to see if anyone else had this happen.
Jan 13, 2010 | Bosch 24 in. SHE44C05UC Stainless Steel...
Need a manual for Caloric model dc52151W0A
Oct 09, 2009 | Caloric Dishwashers
Water does not drain completely,water from sink backs up in DW
Here is a tip that I wrote that will help you with your dishwasher2_bing.gif not draining problem...
Dishwasher2_bing.gif Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
Jan 31, 2009 | Caloric 24 in. CDU510C Built-in Dishwasher
Water leaks from door
Hi dec507,
I'm Harvey the Master Plumber.
Your problem is: you have a Caloric Model CD4 200 CWW and water leaks on the right side of the door. The gasket seem to be worn.
The gasket is easy to replace but you should also check the d/w for level. I mean horizontal, vertical and front back. Over time they can get out of level enough to cause a problem.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 09, 2008 | Caloric 24 in. CDU210C Built-in Dishwasher
Frigidaire dishwasher
Next thing to look at--considering all the power is good--although that's what I'd check on again, would be the door switch. May have to remove the control panel cover or the door interior.
Try www.repairclinic.com if you need parts.
Sep 08, 2008 | Frigidaire 24 in. FDB1050RE Built-in...
LD Dishwasher power problem
On the LDS5811 model, I doubt very much that the door switch would cause a full failure.
If you are confident the power is live into the dishwasher, the most common failure with this symptom is a failed controller card (PCB) and will require a service call to LG.
Aug 09, 2008 | LG 24 in. LDS 5811 Built-in Dishwasher
Dishwashers Logo
16 people viewed this question
Top Dishwashers Experts
