Question about Garden
Atco windsor 14s
My mower will often either not start or cut out. The problem appears to be in the safety switch. It only starts when I apply a lot of pressure in the direction of the two red arrows. And then cuts out again after a minute or two. You may see two photos on Flickr -
  • plehpleh Jul 27, 2013
    Even app lying the pressure, it will not start straight away. But if I stand there with the pressure applied it starts after a minute or two. But after a row or two it cuts out again
    photos below
Hello my name is paul and i am looking for a work shop manual for my atco 12/36 rideon lawntactor model 830 would you know where i can get one from please
Workshop manuals are usually only found at dealers. Try some of these links though.
  • ATCO - Official Site ... ATCO is a diversified global corporation delivering service excellence and innovative business solutions in Structures & Logistics (workforce housing, ...
  • Atco Product Support ' My atco balmoral 17 rear roller jams when trying t. ... Service manual for atco balmoral 14s. ... manual Atco Commodore B17.
  • Atco Operating Manuals ' The Old Lawnmower Club Atco Operating Manuals. View (active tab) What links here; ... Title ; atco1246.pdf: Atco 1246 : Atco 141720.pdf: Atco 141720 : Atco 172055.pdf: Atco 172055 ...
  • Atco Lawnmowers - The Finest Cut of All Atco Lawnmowers Since our first lawnmower in the 1920s Atco has had an enviable reputation for the outstanding quality of our cylinder mowers. Save up to £100, from £899.
  • Operating Manuals ' The Old Lawnmower Club The following operating manuals are available for free download from the site. ... Manual ; Atco 1246: atco1246.pdf: Atco 1755 and 2055: Atco 172055.pdf:
  • Old Lawnmowers and other Vintage Machinery Old Lawnmowers and other Vintage Machinery. ... We have a range of Operation Manuals, ... Allen Motor Scythe Model 'T' , Early 1950s ; Villiers Atco 12" Hand Mower ...
  • Lawn Mower Manuals - How to Access Old Mower Manuals > How-To Library Shop by Brand [+] All Brands: Shop by ... However, finding a manual for a specific model can lead you on an Indiana Jones treasure hunt. ... Lawn Mower Manuals ...
  • Free Atco Lawn Mower User Manuals ' Find the user manual you need for your lawn and garden product and more at ManualsOnline ... Atco Lawn Mower Manuals. Showing Products 1 ...
    Sep 14, 2016 | Garden
    ATCO sit on mower. Engine cuts out when I engage the blade. Help? Maria
    Most sit on mowers and riding tractors have an "operator present" switch beneath the seat. If this switch is not activated then engaging the blade will cause motor shutdown - which is what you want if you fall off the mower or even stand up off the seat. The switch could be disconnected, defective, loose or messed up with dirt. Be sure this part is working and I'd expect you will have it fixed.
    Jun 27, 2016 | Garden
    How do you remove cassette from atco windsor
    didnt know a lawnmower had a built in music system
    Sep 01, 2014 | Cars & Trucks
    My atco 12s electric mower will not start, power is getting to the switch ??
    Firstly how have you ascertained the power is getting to the switch?
    It is common on these mowers for the supply cable to brake inside the insulation just where it goes either into the plug which is then inserted into the switch assembly or if wired directly where the wire enters into the switch assembly .
    Insuring that the lead is plugged in to an RCB safety circuit breaker - hold the lead approximately a yard/meter from the switch ( check for any damage in the insulation before starting this test and before switching the power on) operate the switch on the mower and hold in the run position now move the flexi maintaining the yard/metre distance up the cable from the switchmove the flexi in all directions ifyou have any reaction from the motor on the mower this will almost certainly confirm the problem is indeed the flexi.
    All other testing should only be done by a suitably qualified electrician/service engineer
    Jun 16, 2014 | Electric Lawn Mower
    Toro mower won't start
    bad safety switch or bad coil
    Apr 07, 2012 | Toro Power Lawn Mower
    Mower wouldnt start, had seat switch replaced, runs great. When I put the blades into motion, (pull blade switch in the upward position, the blades stall and the enging stopes. I disconnected the power...
    Well Harry these mowers are all made by the same couple of companies. My Husqvarna 2148 was actually an AYP, and yours most likely is also. AYP makes the Craftsman mowers as well and there are a lot of similar complaints on here about those mowers doing the same thing. Now many of those type complaints about Craftsman mowers are resolved by tracking down a central relay that all the safety switches connect to in order to shut the engine down or keep it from starting. So were I you I would track the wiring on the safety switches down, and there is one on the PTO as well to keep you from starting it with the blades engaged, and see if there is not such a relay and it could be your bad boy.
    Sep 30, 2010 | Husqvarna Riding Lawn Mower 42 Inch Cut...
    My husqvana lawn tractor starts well and the engine runs but when I release the brake or apply the cutter it cuts out. Why?
    Most likely the seat safety switch or associated wiring is the problem. It's designed to cut the engine if you release the brake or engage the blades unless it detects your weight in the seat. Tip up the seat and make sure the safety switch under it has not come loose, and that the wire connections are on tight. If that all looks OK, take the switch off and put a piece of tape over it the plunger to keep it in the 'activated' position and see if the mower works that way. If that fixed it, you should replace the safety switch. They are just a few dollars. Hope this helps - if so, please rate my answer.
    Jul 04, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
    I have an atco commadore B20 that cuts out when I
    it could be tight cutter bearings in the deck next time it cuts out switch off the motor and try to turn the deck by hand if its realy tight its seizing up on you
    May 02, 2010 | Garden
    I have an atco commadore b20 that cuts out.
    sounds like it may be a safety switch prob check the seat switch
    Jul 29, 2009 | Garden
    Garden Logo
    52 people viewed this question
    Top Garden Experts
    Dennis Key
    Dennis Key
    john h
