Evolis pebble 4
Usb soket damage so how chang the soket
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 25 Answers
Go to the authorised service of your Pebble 4 and ask for a socket change, I highly advice you not try that because at the end you might screw up the printer further and not be able to even sell it for 10 pounds
Posted on Jul 25, 2013
  • 54 Answers
SOURCE: Evolis Pebble Cleaning Kit
Check if feedr Roller is moving.
Look at backside of printer . There is a card thickness adjustment lever where you feed the cards . Make it positioned at 1 mm.
Posted on May 21, 2008
SOURCE: evolis pebble 3 ribbon problem
Hi, did you change the ribbon type at the printer properties? You must choose the black ribbon or monochrome in old drivers.
Posted on Aug 07, 2008
SOURCE: We have Evolis pebble printer
The printer is waiting for a card to be inserted. The printer has a manual card feeder option, insert a card into the printer.
Posted on Dec 14, 2010
  • 54 Answers
SOURCE: I have an Evolis Pebble
Just check for thickness adjustment pointer near card feeder . It should be 0.8 for standard cards.
Check in driver settings also if you have selected for manual feeding.
You may need to clean the Roller situated at feeder.
Posted on Apr 13, 2011
  • 54 Answers
SOURCE: My ink ribbon breaks after
Clean all transport rollers . check for X offset by giving Rx command in Properties/Tools/dialoge with printers. Increase offset little bit using Px command
Posted on Apr 27, 2011
Hi I got Evolis Pebble 4 and I have problem with printing the ribbon light is always ON and it does not print with YMCKO, but when I change to black ribbon K it prints. What is the problem.
It sounds like your ribbon setting in the printer-driver is set to the R2011 (or R2211) K ribbon. It should be set to R3011 for the full-color YMCKO ribbon. Check by locating the printer in the Windows Devices & Printers view (Win7: Start Button => Devices and Printers; WinXP: Start Button => Printers and Faxes). Locate your Pebble printer; right-click; select "Printing Preferences". Check your ribbon setting here and match to the ribbon that is loaded. NOTE that you can only make changes to this driver setting if you have Windows Admin rights with your Windows log-in ID. If you don't, have your systems administrator assist you with this by logging in with their ID.
May 04, 2015 | Evolis PEBBLE 4 Led Card Printer
Pebble 3 windows 8 driver
Use the pebble 4 driver. I am using windows 10 and have tested on 8 as well. Download the Pebble 4 windows 8 driver and it will work fine.
Mar 19, 2014 | Evolis Pebble Color Card Printer
I change the printer tape in the printer and it still has the change tape light on
You have 3 possible problems/solutions:
1) Did you make regular cleaning?
2) Sensor is not working properly(maybe a replacement of spare part is needed).
3) Maybe you just connected your usb cable to another port and it generated a copy, in that case, delete all printer Evolis drivers from control panel and enable it from beginning again.
Nov 01, 2013 | Evolis PEBBLE 4 Led Card Printer
Evolis pebble 4 shows the end of ribbon light...
Not card, not ribbon, not cleaning, not driver setting.
Does your black ribbon roll and never stops?
Sep 10, 2012 | Evolis PEBBLE 4 Led Card Printer
I have an Evolis Pebble 4. For each card printed, a white thin streak appears. This streak cuts through the entire card.
Try cleaning your printer first using the Evolis A5011 Cleaning Kit. If the line is solid and goes across the length of the card, you might have a burned/damaged pixel. Check with Evolis or your Evolis Card Printer supplier for warranty information, your printhead might still be under warranty.
-- The Pros at www.DiscountIDStore.com
Aug 28, 2011 | Evolis Pebble Color Card Printer
Evolis pebble doesn't printer after standby
Just do one thing . Check the selection ports tab. Change it Apply it and again change it to original value and apply . This should solve problem. Also check if printer becomes offline. .
May 18, 2011 | Evolis Pebble Color Card Printer
I'm using Evolis Pebble 4 to print card, i wish to let the printer flip the card itself and print at the back of the card. So i first set the duplex of the printer to vbPRDPVertical on VB6, and then i...
Dear Sir,
Evolis pebble4 printer is a single side card printer . It doesn't has mechanism to flip the card.
If you want to flip the card automatically you must go for Evolis Dualys or higher model.
Apr 04, 2011 | Evolis PEBBLE 4 Led Card Printer
I have an Evolis Pebble 4 printer. I am trying to print out cards from the Pebble 4, but the machine is not pulling the cards from the card holding tray. Because the cards are not being pulled from the...
Oct 14, 2010 | Evolis Pebble Color Card Printer
32 people viewed this question
jasbo
jasbo
