Question about Fender Starcaster by Fender Strat Electric Guitar Starter Pack, Sunburst
Fender body neck pocket stamp whats it stand for
Can any one tell me what this stamp in the neck pocket on the body of my guitar stands for it all reads F.P.S 1 MAY 2010 29541350 whats the F.P.S stand for? i am trying to find out more info on this body so i can get a neck for it
3 Suggested Answers
  • 6 Answers
SOURCE: fender M-80 electric Guitar Amp.
You might have a ground problem. Does it do it in different outlets or when you take it to someone else's house? One easy solution to ground problems can be running a three prong to two prong adapter on the power cable. Give that a try and see if it helps.
Posted on Nov 10, 2008
  • 3 Answers
SOURCE: Fender bass guitar shorting out
it sounds to me that you need to fix the input on the bass (where you plug in), sometimes just tightening the nut will do it, or buying a new one and replacing.
Posted on Jul 22, 2009
What is my 1993 fender strat plus worth,in excellent condition.rare blue color
anything fender pre 1979 worth a lot
valuation service
http://www.guitaravenue.com/home.htm
need to look at 2016 fender strat guitar for sales
sites for a price comparison for yours ....$1000 ?
What is fair price for 1993 94 Fender Strat Plus Deluxe
Oct 31, 2016 | Fender Starcaster Strat Electric Guitar -...
What year was a fender stratocaster serial number 33170 made?
This guitar is from the U.S. Vintage Series
made at the Corona Plant (Fender), USA
in the Year(s): Cannot be determined from serial number,
however you can consult this chart showing the
corelation between serial numbers and dates found on the neck
Fender MIA RI Serial Number vs. Neck Date (Note the earliest I'm seeing is mid 80s)
Jul 24, 2014 | Fender Music
MN9332078
Your guitar was made at the
Ensenada Plant (Fender), Mexico
in the Year(s): 1999 - 2000
Jul 16, 2014 | Fender Starcaster Strat Electric Guitar -...
Have a fender strat serial V019217
It is a US strat! Congrats! Guitar Info This guitar is from the U.S. Vintage Series
Fender: Corona Corona factory was opened in 1985, Corona California, with major guitar production starting in 1987. With the addition of a custom shop in 1987 the plant currently employs about 700 workers. Apart from general and Custom Shop Fender instruments and amplifiers, it also encompasses Guild acoustic & electric guitars.
May 19, 2014 | Fender Starcaster Strat Electric Guitar -...
Where is V193037
May 12, 2014 | Fender Starcaster Strat Electric Guitar -...
Guitar serial number lookup us11131155
Possibly... Here's what Fender says...
US11 + 6 digits
V + 5 or 6 digits (American Vintage Series except '52 Telecaster, which uses a five-digit number stamped into the bridge plate)
2011
(for American Vintage series, check neck date for specific year)
What model Fender is it?
Jan 25, 2014 | Fender Music
Strings are very far away from the last frets on the neck...
Sometimes the truss rod (nut you are referring to) will do the trick. The truss rod runs under the fingerboard and allows you to give the neck relief or tension. Some truss rods are dual action but I'm guessing yours is designed simply to give basic relief of the neck. I would make sure the truss rod is adjusted properly before sanding down the saddle. If you sight down the neck you should be able to see the relief in the neck - just use the string as your straight-edge. Most guitars need a slight amount of relief but higher-end guitars can be almost straight (better fretwork.) Once the neck has been adjusted correctly you can move forward with the setup.
Make sure the nut is also the proper height. If the nut is too low (1mm height between bottom of string and first fret) you should get it replaced by someone capable of doing such a thing. If the nut height is okay I would suggest moving forward cautiously by sanding the bottom of the saddle. Make sure this is done patiently and carefully as it can drastically change the sound and playability of the guitar. Hardly any material needs to be taken off to lower the action just a little. Error on the side of not-enough than too much. Make sure the bottom of the saddle remains flat! If the bottom isn't flat the guitar can sound horrible and if there is an undersaddle pickup it might not pick up evenly. The easiest way to do so is to tape some sandpaper rough side up on a flat surface (just don't pick something like mom's heirloom or something important in case it gets scratched.
If you'd like more detail check out http://www.fretnotguitarrepair.com/Repairs2.htm
Good Luck!
Nov 15, 2008 | Epiphone Aj-100 Acoustic Guitar
Fender Starcaster by Fender Strat Electric Guitar Starter Pack, Sunburst Logo
369 people viewed this question
Top Fender Music Experts
Michial Gueffroy
Virgil Watts
Are you a Fender Music Expert? Answer questions, earn points and help others
