Question about Bvlgari BV 550 Sunglasses
Lens replacement
Can i buy replacement lens for this model ? thanks
Is it worth paying sony to replace lens block assembly on dsc-w5, 6yrs old, or buy a new camera?When I tirn on camera message says turn on & off again, which I do but does not help. Lens moves back...
Replacement of the lens will cost more than the camera is worth. Try these solutions at the following website before deciding to buy a new camera.
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Oct 23, 2011 | Sony Cyber-Shot DSC-W5 Digital Camera
My dvd player was working fine this morning and now it's not reading discs. What can I do to fix this or do I need to buy a new dvd player? It is a Dual Deck DVD/VCR Player MVD4544 model
Good day!
This are the common and basic causes reading disc failure of DVD players.Try this D.I.Y procedure before you buy a new player.
  1. Check the CD itself.If the CD got many scratches,replace it.
  2. Clean the DVD lens using CD cleaner.
  3. Try to use other new CD or the one with no scratch.
  4. If the steps # 1 to 3 are not successful.The problem could be on DVD lens.
  5. If the DVD lens is defective you better to buy a new player.Because the lens is expensive and it is not easy to install on DVD player.
I hope this information will be helpful.Thank you and good luck.
Apr 25, 2011 | Memorex MVD4544 DVD Recorder/VCR
I have a H50 Sony, there is an internal fungs on the more external lens, is there any thing to do to clean it? I was informed that is needed to buy a complete new kit of lens. Is it correct? tks in...
Yes, its correct, you need to replace lens assembly because lens assembly can not be repaired easily and satisfactory, labor of qualified tech to get repair old lens assembly would cost you similar to new lens price as well so it would be good to buy replacement lens assembly to solve DSC-H50 camera issue.
Thanks.
Feb 27, 2011 | Sony Cyber-shot DSC-H50 Digital Camera
Pioneer model # DV-c503 will play DVD but does not play CD's anymore.
The problem could be dirt on the surface of the lens.
Use a dry cotton bud to clean the surface of the lens, this you have to do gently because the lens is fragile.
If otherwise you have to change the lens.
Try websites Shopjimmy.com,Ebay.com to buy parts for replacement..
May 28, 2010 | Pioneer DV-C503 Multi-disc DVD Player
PS3 laser lens
Hi
If you are talking about replacing the lens itself and not the whole drive then according to my information the lens should be the same for any PS3 although there are differences in the complete drive units.
There is an excellent guide to replacing the lens itself (as opposed to the whole drive) at this link http://www.waltercedric.com/component/content/article/1350.html
Its also a lot cheaper if you can manage to do it this way by replacing the lens alone. Here is an example of where you can source the part you need
http://www.vavolo.com/productdetails.asp,mode,1,ProductID,3738,,.htm
Hope this helps. Please do rate this answer. Thanks.
Sep 01, 2009 | Sony Playstation 3 (PS3) Console
Hello, I have Sony DVP-S735 DVD Player and i want to replace the LENS, so could you please tell me where can i find that and how much it will cost me Thanks Kam
Replacing the lens alone is only psiible if u know how to take it apart and put it back just the way it was. And it has fine ribbon cables too, U should be careful.
U cud get a lens from a used one but a new one is not possible since sony does not sell the optical pickup buy it's self in these models. I can get a new lens, but it comes with the lens, plus everything u get on that block, meaning the housing with the two motors.
Buying a new one is upto u since I donno where u are, the cost is around 100 USD for us in Maldives but it will be much cheaper in the rest of the world. If u can try googling for the replacmetnt lens block, sometimes this hels on how to get ur hands on an new one.
Rifaa
Nov 17, 2008 | Televison & Video
MOdel 5 Bose Lens
If this is the front panel lens for the display, this is a Bose part only. Contact Bose directly to find out how to order the part.
Jerry G.
Jan 20, 2008 | Bose & Wave& Music System
Lost lens cap
I would sugest using an adaptor ring. You can reduce the size of your lens opening down a common size lens cap that will fit your camera. If you can't go this route then give me the make and model number and I will see what I can do for you. LJ
Sep 18, 2007 | Konica Minolta DiMAGE Z20 Digital Camera
ILO DVDRHD04 PARTS
I understand that Funai corp makes these iLo DVD player/ recorders but when I spoke to someone, they did not recignize the model number. Their number and address is :FUNAI CORPORATION Customer Service Tel :1-800-605-8453 http://www.funai-corp.com 19900 Van Ness Avenue, Torrance, CA 90501 Good Luck
Jun 05, 2007 | iLO DVDRH04 DVD Recorder
Bvlgari BV 550 Sunglasses Logo
27 people viewed this question
Top Bvlgari Clothing Accessories Experts
Da Doc
ray gallant
Are you a Bvlgari Clothing Accessory Expert? Answer questions, earn points and help others
