Question about DIGITECH Vocalist Live 3 Vocal Processor
Troubleshooting & Support for DIGITECH VOCALIST LIVE 3
When I use the footswitch to start the harmony midway through a song, my vocals cut out altogether, until I push the footswitch a few times and it may come back on again.
5 Suggested Answers
  • 5603 Answers
SOURCE: no vocal sound
It sounds like the guitar level input to the unit is too low.
NOTE: With this product you MUST use an amplified or electric guitar that has a preamp within it.
If you have a straight guitar that does not have an amp in it, buy a preamp to first run the guitar through.
Posted on Apr 28, 2010
  • 5603 Answers
SOURCE: distortion on vocal reproduction on
You need to check the actual signal levels to make sure they are within the specs for the unit. The mic input is low impedance. Your mic should be like a Shure SM58 or equivalent. The output is fairly high... up to +14DB which will require you to turn down the trims on a mixer this runs into or set a -20Db pad at the input. I suspect your distortion is from the device output to the mixer input. It is VERY important that the mic does NOT "hear" the speakers as the feedback loop resulting will be mass distortion. The guitar should also not "hear" the mains.
Posted on May 07, 2011
SOURCE: I was using my digitech vocalist live 2 pedal
After using my digitech vocalist live 2 pedal, the next time I used it only the harmony side of it is working. The harmony on/off switch to deactivate the harmonys just switch the selected harmonies on the effects side works as well.The open mike side is dead. Any ideas??
Posted on Sep 15, 2011
  • 5603 Answers
SOURCE: The digitech vocalist live 2 ,the left side button(reverb,enhancer) , activates the right side (harmony) LED's on the circuit board itself are lit up and nothing happens. t
The buttons are probably scanned as a matrix and possibly a circuit board has been cracked causing wrong data to go to the microprocessor in it. It is unlikely this will be a DIY fix so you should contact Digitech for a repair facility.
Posted on Jun 22, 2012
Testimonial: "Sort of what i suspected, I'll just toss it! The new one is out ,I'm on it."
The lights are on but nothing is coming out,, no voice no guitar nothing???
Double check all your settings, then do a reset. If that doesn't work it will need to go to the shop. Here is the Digitech contact page to ask them or to find a service center-
Support DigiTech Guitar Effects
Apr 01, 2015 | DIGITECH Vocalist Live 5 Vocal Harmony and...
Why isn't my microphone coming through? Setup is guitar, mic and amp.
Which kind of mic do you have, don't you need the phantom power switch set to on? (condensermic)
Mar 17, 2015 | DIGITECH Vocalist Live 3 Vocal Processor
The vocal cuts out completely from time to time. Comes back after a while but keeps cutting out at intervals. Have two of these and both do it. Is it my set up, is it overload in some way. Guitar ok. Use...
The amp or pre-amp for the vocals built into the unit is failing when it gets warm. This is a common problem with electronics, that when it cools down cures itself until it warms up again a few seconds later.
The units need repair or replacement.
Dec 22, 2013 | DIGITECH VOCALIST LIVE 2
Jun 21, 2012 | DIGITECH VOCALIST LIVE 2
Distortion on vocal reproduction on Vocalist Live 2. Even with input volume down to minimum a loud vocal performance produces distortion on single voice and harmony output.
May 07, 2011 | DIGITECH VOCALIST LIVE 2
Vocalist live 2 problem. power to unit OK , lights up. Guitar output OK. No tuner, no vocal output.
NO power light or audio from Digitech Vocalist 2 live. Check that your power adapter is for 9 Volts AC (not DC like most pedals) and is rated at 1300ma or more. A DC adapter MAY light up the unit but not make it pass audio. Lights can be lit but that is NOT an indication thaat correct power is applied. They likely use the AC input to generate both positive and negative voltage within the unit. The use of a DC adapter will prevent generating one of these required voltages and prevent audio from passing.
Jan 13, 2011 | DIGITECH VOCALIST LIVE 2
I was using my digitech vocalist live 2 pedal during a gig 3 days ago and about 2 songs in, everytime i touched any part of the pedal or pressed the harmony on/off switch to activate the harmonys, the...
Yeah I have an idea... It is likely static electric discharge. At this time of the year we get zapped touching metal things and it also drives electronics nuts... You don't even have to feel it to get zapped.
Try using in your bare feet and see if it fusses... We had a lady vocalist wearing those ugg boots and caused static pops in her microphone... anyway try the test and if it fixes the problem, then look up Staticide spray... You can get it at Amazon.com for example... spray floor in the area you are playing on to kill the static.
The only other thing is to check if wiggling the power input plug causes the problem. Those plugs are notorious for poor connections when they wear.
Dec 28, 2010 | DIGITECH VOCALIST LIVE 2
Hi i have a vocalist live 3.. my harmony button..when i press it, it does not stay on. can someone please help me. it worked earlier but not now, i am not sure if i pressed somehting
To the guy with the vocalist live 3. You need to change the FS (footswitch) setting under setup. It toggles between a true switch and working only when you hold it down.
Nov 22, 2010 | Digi-Tech Digitech Vocalist Live 4...
No vocal sound
Apr 26, 2010 | DIGITECH VOCALIST LIVE 2
When i press the harmony effect i have to hold it
Well i hope the latching mechanism isn't busted!
Check/review your parameter settings for your programs. Especially in the Expression Pedal Control areas.
From their site:
--Harmony Footswitch
This footswitch turns the harmonies on or off. While multiple harmonies can be selected within a preset, the HARMONY footswitch activates or deactivates any selected harmonies simultaneously.
When the LED above the HARMONY footswitch is illuminated, the harmonies are on. When the LED is turned off, the harmonies are turned off.
--Note: The settings for FX Footswitch Control, Harmony Footswitch Control and Guitar Sensitivity apply to ALL presets. The setting for the Expression Pedal Control applies to the current preset only. If you modify the Expression Pedal setting and wish to store it you must Store the preset (see page 11 ). When you load another preset, its setting for Expression Pedal Control will take effect.
--To perform a Factory Reset procedure
If you are editing a preset, press the Up or Down footswitch to exit edit mode.
Press and hold the Major/Minor button and then press and release the Store button. The display will read FAC RESET- WILL ERASE ALL YOUR PRESETS... , then STORE=RST.
Press the Store button again to continue with the factory reset. If you don’t want to do the factory reset, just wait 5 seconds, or press almost any other button, to cancel.
Mar 27, 2010 | Digi-Tech Digitech Vocalist Live 4...
DIGITECH Vocalist Live 3 Vocal Processor Logo
464 people viewed this question
Top DIGITECH Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a DIGITECH Audio Player and Recorder Expert? Answer questions, earn points and help others
