Question about Refrigerators
Electrolux ERF 2832 - Problems
Refrigerator section not refrigerating. Freezer section fan jammed up with ice. Cut power to allow full defrost. Claims to be frost-free unit!Should this solve problems? Please advise. Regards, Ally Ross
    Sergeant:
  • 308 Answers
Sounds like a gasket issue somehow warm air is getting into your unit maybe through the ice dispenser
Posted on Jul 26, 2013
  • 159 Answers
SOURCE: ice build up in back section of a Whirlpool no frost top freezer refrigerator 66"hx30"wx27"d
your sure the defrost cycle works? sounds to me its not. you need to remove the freezer back and check the defrost components. or put it in the defrost cycle and see if it is working. to get that much frost as you describe the dor would have to be left open. also check all door seals. let me know what you find and we can go from there
Posted on Aug 10, 2007
  • 1314 Answers
SOURCE: Auto defrost not working
a manual defrost will help in the sense that it will healp save your food now if you dont mind spending a little cash may i suggest you go buy a eurika 350 hand held steamer its great for defrosting and about 1000 other thuings around your house you canget it at lowes places like that after defrosting the unit will freeze again in about two to three days depending on how many times you open your door reply to this thered with the appox age of your unit and i can better advise from there some times as in the case of a stuck theroma stat if seen it fix them but i wouldnt count on it hold my rating tii we are done
Posted on Jan 19, 2008
Sea Breeze
  • 4655 Answers
SOURCE: GSS23WSTA refrigerator freezer section is getting warm.
Just the fist indication that defrost is not taking place. Most likely the defrost heater and defrost thermostat will need replaced. part number Click Here=> WR51X10101 for heater and will be easy to spot if burned out and you should also replace the defrost thermostat just in case part number Click here=> WR50X10068 Let me know if you need assistance, you may reach me through Appliance 911 or Sea Breeze Appliance Parts and Technical Services
Thank, Sea Breeze
Posted on Dec 25, 2009
  • 4 Answers
SOURCE: The lower refrigerator section is not cold anymore
check to see if the fan motor in the freezer is running. all the cooling happens in the freezer and the fan is what circulates the cold air down to the refrigerator.. if the fan isnt running ,it could be a bad connection or a bad fan motor..on some models the doors need to be closed before the fan comes on so just push on the door switch to check .if the fan is running then a defrost problem may be the problem.. you mentioned you defrosted the unit. if the auto defrost isnt working, you would notice frost on the back of the freezer. there would be a lot more frost behind that panel that could block the airflow down to the frig. you would have to remove rear panel of freezer to clear all the frost and restore proper airflow..remember to unplug the frig before doing any work..
Posted on Mar 25, 2010
  • 670 Answers
SOURCE: Side by Side GE Refrigerator freezer will not
The defrost circuit has failed in your fridge. Typical failure is with the defrost heating element. To troubleshoot, you need to remove the remove the contents of your freezer section and remove the freezer back panel to access the evaporator coil. You will need a hair dryer to melt the ice on coil. The heating element is attached to the coil. Use a meter to confirm that the element is bad. Hope this helps you.
Posted on Nov 08, 2010
Fan turns off in refrigerator section.
Its issue with defrost timer causing the fan to turn OFF.
Get the timer checked.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 23, 2012 | Refrigerators
Continuous beeping
Either any door is not closed properly or door sensor is not working,its not sensing the door closed.Or the problem is no defrost.The defrost is causing over ice in fridge or freezer section.
Reset the refrigerator by disconnecting it from wall outlet for 12 hours,then reconnect and see if still the same problem is there.
On some cases its issue with fan not working.There are two fans,one in freezer section and one in fridge section.If either of the fan is not working the controls will flash.
These will help.
Thanks,.
Dec 22, 2012 | Fisher and Paykel Active Smart E522B...
Frigidaire Gallery Warm Refrigerator Cold Freezer
Generally the thermostat that turns on and off the compressor is in the freezer and so is the coils. The control knob that is in the refrigerator section is just to adjust the air flow between the two sections. If the air flow is blocked you don't get cooling in the refrigerator section. This could be a bad fan motor not creating circulation, ice blockage because the defrost cycle is not melting away ice accumulation. If it's defrost problems it could be timer, defrost thermostat, or heater element.
Feb 29, 2012 | Frigidaire Gallery GLRT218WD Stainless...
Refrigerator isn't cold enough, but the freezer is fine. Model number is PSS26MSWASS, Serial number is GM439772, I turned up the temp for the Refrigerator, but its not that cold.
This problem is related to defrost.The defrost cycle is not running as it should be. The other possibility can be ice blockage in the ventilations.The defrost is not working,.The evaporator coil in the inner section of freezer is got blocked by ice .
Try manual defrost reset procedure: ----
First unplug the unit from main power outlet. Then empty whole unit completely. Then keep both the doors open. Wait for 24 hours. All the ice collected on the coils and in the freezer section will get melted. Clean the water from the sections. Then Connect the power cord of the unit to main power outlet after 24 hours/.Then set the temperature to normal in both fridge and freezer section. It will take near to 4 hours to get run in its proper cooling cycle. Then check, if the problem returns again. If the same problem occurs then it's defrost problem. The defrost board and the defrost thermostat/heater is not functioning properly and it has to be checked and replaced.
Check the damper if there is too much water collected in the damper then press the damper and remove the water collected in it. The procedure of this unit is as follows: --- The compressor starts then it cools the freezer section. When the freezer reaches its cooling level the defrost cycle starts functioning. In this cycle the fan in the freezer section starts running and the cool air in the freezer section is passed to the refrigerator section and the refrigerator section gets cold. The air from freezer to refrigerator passes from the section, in that section the damper is located. Now this problem which you mentioned. In this problem the freezer works but no cooling in fridge, this happens if the thermostat is not functioning or the heater is not heating. Then the ice starts getting collected on the evaporator coil. The evaporator coil is at the internal section of freezer. If too much ice gets
collected then this ice blocks the fan in the freezer section from functioning and this blocks the damper section with ice getting collected there. This all procedure is controlled by the main defrost board of the unit. Now if the damper is not got blocked with too much water or if the ice is not got collected on the damper area then check the evaporator coils. If there is too much ice got collected on the coils, then takes a hair dryer and melt the collected ice. Then see if the problem returns again. But if there is little bit ice collected on the coils and fan is running properly then it's not a problem. In that case main defrost board is faulty and it has to be replaced. The main defrost board is working but its not controlling the functions as required so the freezer works but fridge section not getting cold..
You can get required parts from sears part direct online site or from repairclinic.com site.
This will help. Thanks. Helpmech.
Mar 01, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Fridge is not cooling well. Freezer is fine
Feb 25, 2011 | Frigidaire FRT21P5A Top Freezer...
Does not go into defrost mode. refrigerator section becomes hot
The defrost is not working.This happens due to the evaporator coil in the inner section of freezer is got blocked by ice .--------
The procedure of this unit is as follows: --- The compressor starts then it cools the freezer section. When the freezer reaches its cooling level the defrost cycle starts functioning. In this cycle the fan in the freezer section starts running and the cool air in the freezer section is passed to the refrigerator section and the refrigerator section gets cold. The air from freezer to refrigerator passes from the section, in that section the damper is located. Now this problem which you mentioned. In this problem the freezer thaws, this happens if the thermostat is not functioning or the heater is not heating. Then the ice starts getting collected on the evaporator coil. The evaporator coil is at the internal section of freezer. If too much ice gets collected then this ice blocks the fan in the freezer section from functioning and this blocks the damper section with ice getting collected there. This all procedure is controlled by the defrost board of the unit.
So first try reset procedure.If that is not helping then defrost assembly parts are to be checked and replaced.The defrost thermostat is located in the freezer section beside the evaporator coil.The defrost heater is located in the freezer section beside the evaporator coil.And the defrost control board is located in the fridge section.-------------
you can get the required parts from online sites like:---
www.repairclinic.com or from searspartsdirect online site.---------This will help.Thanks.Helpmech.
Feb 21, 2011 | Whirlpool GS6NBEXR Side by Side...
Electrolux Side-By-Side Refrigerator making really load noise
You have a defrost system issue! DON'T chip any more ice!! EEEKKS! You are lucky you didn't puncture the freon line! There is no repairing a punctured freon line!! We will send the correct parts to you if you will please provide your model number for this unit. Once you replace this defrost system. you will not have any more icing up issues. You must, however, defrost the unit out before you replace the defrost system. You can do this by unplugging your unit for at least a whole day and by placing a fan in front of the opened up unit to allow it to thaw out PROPERLY. BTW: I love the Electrolux Icon appliances. I hope this resolves your problem and I hope to hear back from you soon. We answer our phones from 7 Am until 9:30 PM CST.
Sep 09, 2009 | Electrolux Icon Professional Ice Maker...
Kenmore elite 596 73503201 no cooling in top compartment
if the freezer is getting cold the problem is due to the cold air from the freezer not getting into the refrigerator. There are several things that can cause this problem. The coils in the freezer icing up and not defrosting properly is one of the things that can cause the refrigerator not to get cold enough. Another problem is the fan that blows the cold air from the freezer compartment into the refrigerator, not working. When the compressor is running open the refrigerator's door and push the switch that makes the light go out. You should hear the fan blowing the cold air from the freezer into the refrigerator, when this switch is pushed in. If the fan is working then you will need to find what is blocking the air flow. Iced up coils are a common problem. The icing problem can be due to a defective defrost timer or something defective in the defrost circuit. Click here for more information. Check for these problems and let me know what you have found.
REFRIGERATOR TROUBLESHOOTING
#1 Refrigerator side getting warm Freezer still cold
Evaporator fan motor not running.
Defective defrost timer. See Defrost Diagnosis Procedure
Defrost heater defective. See Defrost Diagnosis Procedure
Defrost thermostat defective. See Defrost Diagnosis Procedure
Airflow blocked from freezer compartment.
Freezer control turned to "coldest" setting blocking air flow to refrigerator side. On most refrigerator/freezers, the freezer control closes a baffle when turned to coldest setting, and this blocks off the air flow to the fresh food compartment.
Fan blade broken.
Defective door switch on older models.
Light staying on with door closed.
2 Refrigerator & freezer compartments both are getting warm
Make sure refrigerator is plugged in and has power.
Condenser fan motor on bottom under refrigerator not running.
Condenser coil clogged.
Defective defrost heater. See Defrost Diagnosis Procedure
Defective defrost thermostat. See Defrost Diagnosis Procedure
Cold control defective.
Compressor overload defective.
Compressor relay defective.
Compressor defective.
Low on refrigerant. #3 Freezer compartment getting hot.
Defrost timer stuck in defrost cycle.(replace)
Defrost thermostat stuck.(replace)
Ice maker stuck in harvest cycle
Light staying on with door closed. 4 Ice maker not making ice
Defective inlet water valve.
Freezer temperature not cold enough. (see problem # 2 & 3 above)
Defective thermostat in ice maker.
Defective drive motor.
Water inlet tube clogged with ice.
Defective module in newer style icemaker. 5 Refrigerator sweating around door edges
Door gaskets leaking air.
Defective case heaters.
Energy saver switch not set to reduce exterior moisture
also if require more help click the link http://www.applianceaid.com/refrigerator.html please do rate the solution .thanks in advance.thank you for using fixya.
Mar 27, 2009 | Refrigerators
Fridgidare/Electrolux top freezer not freezing fan stays on.
Look for ice buildup on the back wall of the freezer.
If ice is there you have a defrost parts issue.
If not, check the compressor to make sure it is running.
Mar 04, 2009 | Electrolux Refrigerators
Top refrigerator section will not cool
Check the evaporator fan , freezer must have a fan to avoid ice formation, if evaporator does not work, thermic sensor jams up and freezer stop working. The fan is located behind the panel in the freezer.
Check the back of your freezer, If there is frost or ice, then the unit is not defrosting.
This is often caused by problems with evaporator system.
Sometimes you also need to check the defrost timer, located at the top of the FFC on the Top freezer.
Check also the defrost thermostat, which is on the evaporator inside the freezer.
If it isnt defrosting, change both.
Sep 02, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerators Logo
193 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
