Question about Air Tools & Compressors
Busch Single Phase AC Motor .33 Hp 1440 rpm
Volts 230, Cycles 50, AMP 2.6. Rating CONT, Temp Rise 50 C, Split Winding, .33 Hp, 1440 RPM
  • Fred Blank Jul 27, 2013
    Need wiring details for this motor. It has four wiring points. See Photo of Label and the connecting points, herewith.
2 Suggested Answers
  • 5 Answers
SOURCE: I wish to rewire a single phase electric motor
The motor itself should have a sticker which describes the wiring for 115. It is a small change involving a single wire moving from one pole to another inside the motor starter cap (the bump on the motor itself).
Posted on Aug 29, 2009
How do I change the voltage from 115 volts to 230 volts on a duel voltage motor?
When you open motor you will find schematics on inside of housing.Sometimes its just a switch you push from one side to another.
Sep 12, 2014 | Baldor VL3515 Single Phase C-Face Motor,...
How To Interpret Or Read Nameplate On 3 Phase Motor?
The higher the voltage the lower the amperage, so advantage is its more cost effective to run it at highe voltages since power consumption is I squared x Resistance. The resistance will be the same but the lower the current the less it cost to run it.
Jul 27, 2014 | Baldor 1/2 Hp Motor M3538 1725 Rpm 5/8"...
Won't start
power 120 volt cannot to supply to 230 volt, maximum correction factor for voltage is 15%
Apr 04, 2014 | AO Smith 5 HP 3450rpm R56Y Frame 208-230...
Wiring schematic for MTB217 cooper b line
I would suggest taking a closer look at the motor name plate. I am not familiar with a 120/240 three phase service. When I checked the web it shows: Voltage 115/230 (that is single phase), Max Amps 115 Volts = 19.2 Max Amps 230 Volts = 9.6 , Single Speed, Square Flange, RPM = 3450, Threaded Shaft, Frame = 48Y Used on the following models: Sta-Rite Max-E-Glas, Max-E-Glas II, Dura-Glas, Dura-Glas II, Dyna-Glas, Dyna-Max Pentair Whisperflow, Pinnacle and Anthony AR2 Series. You should also show what voltage you are connected to.
Mar 14, 2014 | A.O. Smith SQ1102 Pool Pump Motor
Need motor specifications
gonna guess..1.25 hp 240 volt single phase continuous operation..two speed 1025 rpm 23 50 rpm high side..gal/hr rating unknown..
Nov 19, 2013 | Emerson Pool & Spa
What is the dynamic output for a stator?
Hi Brandon,
Battery Sealed, maintenance-free, 12V, 19-amp/hour,
270 cca (per Battery Council International Rating)
Charging Single-phase, 45-amp system
(559W @ 13V, 2000 rpm, 599W max power @ 13V)
Starting 1.2 kW electric w/solenoid shift
16-20 volts AC per 1,000 RPM
Jun 21, 2012 | 2006 Harley Davidson FXDBI Street Bob
Century single phase 2 hp 3450 rpm type cs motor Frame f56
the motor is on 220 volts ,i like hook that up on 120 volts ,,thanks
May 10, 2012 | Air Tools & Compressors
I have a motor running 3450 rpm 230 volt 9.6 amp what is my horsepower?
Ok, but I need to know a few things;
Single phase motor or 3 phase motor?
What is the % efficiency?
Feb 17, 2010 | AO Smith Pool Pump Motor Hayward Swimming...
I wish to rewire a single phase electric motor with compositor's that is currently setup for 230 VAC to 115 VAC. The motor is a Ingersoll-Rand Air Compressor motor with the following nomenclacher. Single...
Aug 26, 2009 | Air Tools & Compressors
Air Tools & Compressors Logo
61 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
