Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Burning smell When my machine is on any cycle, there is a burning smell coming from the washer. It does not make any loud noises or anything.
  • 641 Answers
There are a lot of reasons could cause it. Best thing will be to open machine's service panel and to find out from where does this smell comes. Let us know with your results and we will see how could we help you.
Posted on Aug 30, 2007
SOURCE:
Whirlpool duet ghw9250 smells like burning rubber and very loud
Does the drum turn, if not then the drum bearings may have siezed.
Dec 30, 2012 | Whirlpool Washing Machines
Admiral washer model AW20N2V making a clicking sound...
call manufacturer. heard there was a recall... for dangers of fire.
Oct 02, 2012 | Admiral Washer Control Panel Frame 35-5733...
I have a maytag washing machine model A712, during the spin cycle there was loud screeching noises and burning smell. What could be the problem.
problem could be the gearcase or the motor, to find out remove the motor and turn it with your hands to hear any abnormal sounds coming out, and also try to smell the motor see if it has a burning smell
Oct 16, 2011 | Washing Machines
1 yr machine. Won't spin but has burning smell
The reason to this problem can be due to the
brake rotor.It need's to be replaced.
Sep 01, 2009 | Maytag Centennial MVWC500V Washer
Loud noise, then not so loud, but now electrical burning smell and little draining
the smell is your clutch and the lack of draining is a clogged washer drain protector. see these at www.repairclinic.com drain protector is part 541811 and clutch is 2670. go there enter model number and scroll down to the red 100 click it and look for these part numbers.
Mar 02, 2009 | Whirlpool LSR5132PQ Top Load Washer
The basket drive and the drive block will need replacing. The nut that holds the basket to the drive block may have come loose causing the drive block to 'jump' over and damage the tabs on the basket drive that causes the thumping as the spin cycle ends. To repair, you will need to purchase a basket drive and drive block. The agitator, balance ring, basket and transmission, will have to be removed in order to replace the basket drive. If less than 3ys old, consider contacting whirlpool for possible warranty concession.
May 26, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Burning smell/noise with my Maytag Ensignia MAV7657EWQ Washer
it could be [motor] or 'condensur' for motor, starting to burn out or over heat, check drive belt as well for ware
Dec 08, 2007 | Maytag Ensignia 3.3 cu. ft. Top Load...
LG WD-1234FH
You will need to have it checked by a qualified LG technician to see what is the deal with the burning odor.  And the noise is probably the washer not balanced correctly.
Oct 28, 2007 | LG WD-1080FD Front Load Washer
Loud noise on Spin Cycle
CENTER SUPPORT BEARING IS BAD. VERY COSTLY IF NOT UNDER WARRANTY USE FOR BOAT ANCHOR. GOD KNOWS I HATE TELLING PEOPLE THAT. SORRY, FXIT
Oct 11, 2007 | Admiral AW22 Top Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
205 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
