Zebra P430i - Color Dye Sublimation / Thermal Transfer Card Printer - 300 dpi Print Resolution - PVC/PVC C Logo
Anonymous Posted on Jul 25, 2013
Unable to finish initializing
Is only displaying initialization message and doesn't go beyond this level.and i can not do anything with it.
Anonymous
Level 1:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Contributor 25 Answers
  • Posted on Jul 25, 2013
Anonymous
Contributor
Level 1:
New Friend:
Greenhorn:
Answers
25
Questions
0
Helped
2003
Points
49
I'd suggest you get it for a refurd, thats either a faulty wire or faulty motherboard, had such issue at the end it turned out the power was too low, so check your AC too or house/workplace power.
My BR-900CD -- when I try to record I get Unsupported Card so how do erase the card
Press [UTILITY].
– Press CURSOR [] to move the cursor to “INI,” then press [ENTER].
– Press CURSOR [] to move the cursor to “CARD,” then press [ENTER]. The confirmation message “Are you sure?” appears in the display.
– To continue the initialization, press [ENTER]. To cancel, press [EXIT] or [UTILITY].
When [ENTER] is pressed, initialization begins. When the initializing has been completed, “Completed!” appears in the display. The message “Keep power on! Song creating…” then appears in the display, and a new song is automatically created. In this case, the data type selected is HiFi (MT2). When the creation of the song is finished, the play screen returns to the display.
Oct 02, 2018 • The Music
How to clear back to factory setting
Service-mode functions
NVRAM initialization
An NVRAM initialization will return the following device settings to the factory-set defaults:
All menu settings, including the fax header and company name
Fax numbers and names that are associated with one-touch keys and speed-dial codes
Additionally, all faxes stored in memory are cleared.
1. Turn off the product.
2. Press and hold both the down arrow button and the Cancel button, and then turn on the product.
3. Wait until the message Permanent storage init. appears, and then release the buttons.
When the NVRAM initialization process finishes, the product control panel shows the Ready message.
Super NVRAM initialization
The super NVRAM initialization clears all settings affected by a regular NVRAM initialization, and also
clears the product language and country/region settings. Both settings must be reset after a super
NVRAM initialization.
When the process finishes, the product control panel shows the Ready message.
Code to initialize ami rowe jukebox
For full initialization, in service mode, press 3 to enter init. sub menu, type 0 for full initialization. Press popular, then put switch in normal position and initialization will begin. You can still select and play discs while initialization is in progress, providing you select from cd's already finished. The machine will continue initialization after selections are finished playing.
When my Korg d8 power is on 'working' message is followed by Init>?, I cannot go beyond this. How to solve this problem? And can I change the internal Hard drive.
It is asking for confirmation that you want to initialize the unit. The manual doesn't say anything about this... but you should try pressing the "Yes" button to confirm you want to initiallize the unit or press no if you want to staart without initializing.
Please help.. my monitor has no display and my don't even beep. the LED in the monitor turns back to orange after few seconds. cpu, disk drives and ram are working..
This is one of the serious problem that arises because if you set your monitor with a high resolution with high frequency, then the monitor doesn't display anything as it's frequency is out of the rang or limit of the monitor's actual resolution capacity. Each monitor will have a limit of max frequency that is said to be the Refresh rate (for each and every resolution setting the display is refreshed.) When high resolution is set with high frequency that is not supported by the monitor, it then display a message like "frequency out of range". If you press ESC key within the few seconds of this setting, it will revert back to its initial resolution. But if you continued with the setting of same High resolution with High frequency, the monitor is not going to display anything because its frequency is out of the range. Most of old monitors like CRT's etc doesn't support 1024×768 at a refresh rate greater than 60Hz.
I have a sony DSC T300 that the back touch screen doesn't display any video. It lights up and I makes the noise when I touch where the scroll arrows are (when in play mode) or where menus should be (in...
Hi your unit has lens unit defectiveness. It won't reset itself initializing. The noise come from initializing IS unit defect. your local repair shop would charge around $45 to 115 depend on what they really want to charge. thanks and best regard!
10helpful
2answers
Samsung s5233 unable to open message box as it says initializing
2answers
Unresponsive mouse XP unable to initialize device driver for Logitech LX8 laser mouse
Is your mouse new? if new maybe got factory defect. did you try your mouse to other pc? if not please try. if encounter same problem then, mouse is really defective. if not then, maybe your pc cannot support the mouse to run in the system.
melnavz
Top Zebra Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
ExpressFiX
ExpressFiX
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
