LG WM14225FD kept getting a OE code, drained machine, checked filter then tried again...kept doing it so googled and came across youtube man who shows you how to check/replace pump...did all that and cleaned all pipes at the same time and door gusset....put program on quick wash and now it stops at 22 mins and you can hear water pumping in and out at the same time and program is stuck on this action...can anyone help please...lost without my machine :(
JOE LLAMA
  • 26 Answers
SOURCE: LG Intello 7KG Washing Machine
You may have some articles that made their way into the pump housing. Alot of times I see dimes get stuck in the ports of the pump, remove and check out thoroly and also check hoses coming to pump for little son of a gun articles that like to hide.
Posted on Apr 01, 2008
  • 489 Answers
SOURCE: code OE water is not being drained out
You may have a broken or plugged drain pump and needs to be diagnosed by a qualified LG technician.
Posted on Jun 26, 2008
SOURCE: zanussi washing machine won't start E10, E40 & E50 at times
It was suggested that the pump had failed and taken out the programmer with it - expensive! Wife wouldn't wait, and bought new machine. Problem almost solved - anyone want an out of order washing machine?
Posted on Feb 04, 2009
  • 72 Answers
SOURCE: I have OE error message on my LG washing machine.
you may be using too much soap or the wrong soap . you have to use HE soap and about only several spoons of that. too much soap results in too much suds which cannot be pumped out
Posted on Jun 07, 2009
jan mczeal
  • 632 Answers
SOURCE: OE Code LG washer - cleaned filter, checked pump
It is a long drain error. The washer is not fully drained after 10 minutes of draining. Remove the cabinet cover and check the following:
  1. Connector The connector may disconnected or disassembled. Reassemble or repair if necessary.
  2. Drain pump coil
    Check pump coil resistance between the terminals using an ohmmeter. Resistance should be between 10-20 ohms. If the resistance is too high or too low, replace the drain pump.
  3. Voltage Check the voltage between the connector in step 1 during spin. The voltage should be 120Vac, else replace the main board assembly
Main board replacement:
  1. Disconnect the power connector and sensor switch assembly.
  2. Remove the main board protective cover.
  3. Disconnect the connectors.
  4. Remove the screw on the back of the main board.
  5. Slide the main board to the right then pull it up.
  6. Replace the main board in reverse order above.
Posted on Nov 10, 2009
What is wrong when the code oe shows
This OE error or fault code to indicate that the washing machine is not draining properly. Check to be sure the drain hose isn't clogged or kinked. If that checks out, check to see if the drain pump or drain pump filter are clogged. Sometimes objects that are put into the washing machine, for example combs, money, hair pins, etc. end up in the filter. Finally, if the drain line is clear and the pump seems to be clear and functioning properly, you may need to replace the drain pump assembly.
Sep 08, 2014 | LG Dishwashers
I have the error code OE showing up, and the water is not draining from the washer. What should I do?
OE - drain error - 5 minute time out drain time error. check your pump/filter for blockages. Clean out the trap from the bottom, something is jamming the drain motor.
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
Jun 22, 2011 | LG WM-2277HW Front Load Washer
My washer isn't working the washer is an LG TROM WM2277HB the washer shows OC I don't know what that means
Hi dear.As I know there is a OE code on LG washers,if it's Check the followings.OE is drain fault.Check your machine filter there must be blockage(Coin,pin,fluff etc.)clean it.Also check for any kink on drain hose.I hope that helps.Thanks.
Aug 28, 2010 | LG WM-2277HW Front Load Washer
My LG Front Load washer starts to wash, then when it tries to drain, it stops and shows error code OE. I checked back drain hose and they are not kinked. I removed front filter in bottome left and water...
Hi dear.OE code meaning on Lg washer's"machine unable to drain in 10minutes". You can make a little test.Please remove the filter & pour some water in side drum ,watch for water coming out of filter.If it's slow, tub to pump hose clogged.(there must be some sort of fluff or coin clogging hose)if it's not slow,waters comes out freely, run machine on drain cycle & check the pump motor is it running smoothly?If not change the pump.I hope that helps.Thanks.
Aug 23, 2010 | LG WM2487H Front Load Washer
My washing machine showing an OE error before end of cycle
OE error is noyhing but an Outlet Error.. OE simply means “the pump is blocked”. Clean and straighten the drain hose / clean the drain filter. Check the hoses (drain hose) and the pump filter but if it didn't cure the problem then turn the thing upside down and strip the pump out of it check if anything is caught in the impellor.. if so remove it and everything will be fine..
Jan 18, 2010 | LG WM-2277HW Front Load Washer
LG WM2277 "OE" ERROR. PLEASE HELP
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!!!
Jan 12, 2010 | LG WM-2277HW Front Load Washer
I have an OE code on my WM1814CW LG Washer
OE code - Check for clogged drain filter on end of hose, bent or clogged dain hose. Make sure hose doesn't go too far down drain pipe.
Hope this helps
Bob
Jul 06, 2009 | LG WM1814CW Front Load Washer
Lg intellowasher DD 7.5kg WM14225FD error code OE
I think your "OE" is really a "DE" or drain error. Open the access door on the lower left of the front panel on the machine, drain the remaining water with the small drain hose there, and unscrew and remove the larger thing, which is a filter. Clean filter. If filter was not blocked, check for loose impeller on drain pump motor, which requires replacement of drain pump motor. (just sticking it back on will result in it coming off again)
If this helps, a "fixya" rating would be appreciated. Thanks.
Oct 01, 2008 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
