Question about Mitsubishi WD-60737 60 in. HDTV
Software upgrades Can I hook up a sound bar and use it even if my sound doesn't work
    Top Expert:
  • Mitsubishi Master
  • 75,581 Answers
Methods to software upgrade is very difficut to include here by this windwo, as it contains illustrations. If you wish to get more details about software update procedure to Mitsubishi TVs, check the site linked here. It has details with illustrations. http://electronicshelponline.blogspot.com/ Pull up previous posts there, either by type in the Brand name to your set in its search box, or view it in Mosaic / Timeslide / Flipcard option.
Posted on Jul 25, 2013
No sound coming from sound bar
what do you mean hooked up and then no sound, hooked up with dvd player in the tv and then no sound?. ok check the cable if no loose connection, replace if possible.if still doesn't work tried to hooked up in other component input in your tv unit just to ensure if the problem is with in the signal input board.
Sep 15, 2012 | Insignia Televison & Video
The upper thread will not pick up bobbin thread
Make sure the needles are the correct size, fully inserted into the needle bar and oriented correctly for your machine. If that doesn't work check the timing. The hook should arrive at the needle scarf when the needle is at the lowest point in it's travel. If it doesn't... go have it timed by a pro.
Aug 28, 2012 | Singer 1507
Sound capturing problem
Webcam doesn't record sound,try a microphone,and make sure that sound recording software is running when you record sound
Aug 27, 2012 | Gateway Computers & Internet
My nook color has frozen screen and won't shut completely down
TRY a hard reset on the Nook if that doesn't work i know of this fantastic site BNTPrice.com that sells them for cheap. i hope this works for you
  1. Press the "n" button to display the quick nav bar.
  2. In the quick nav bar, tap the Settings icon.
  3. In the Device Settings section, tap Device Info.
  4. Tap Erase & Deregister Device.
  5. Stop. Think. Think again.
  6. If you really, really want to do this, go to Step 7. If not, tap the Back button.
  7. Tap the Erase & Deregister Device button.
May 24, 2012 | Barnes & Noble Nook Tablet
Panasonic bdt210 no sound
you will know if hook to another set but I in our shop have seen similar issues where either a cable or sat box had to be rebooted or even a software upgrade done to the set.
HDMI has mostly sound issues--my experience is it also does NOT like to be connected to units which are on at the time.......
Apr 03, 2012 | Televison & Video
Hooked up my amp it has power but power light won't come on won't power up front speakers work and have sound but it doesn't move to back
Make sure the remote wire is hooked up. You can run a small wire from the power terminal to the remote terminal. If it powers up, then you have a remote wire problem. You can run a remote wire from the blue power antennae wire of the deck.
Apr 02, 2012 | 1991 Ford F250
Just installed WARP registry cleaner from NCH Software. Ran the clean up and rebooted at the finish. MY XP Pro pc now comes up without the start button and all the items at the bottom tool bar. None of my...
GO INTO START, CLICK ON COMPUTER AND UPDATE YOUR COMPUTER. YOU MAY HAVE TO TURN YOU ANTI-VIRUS, DEFENDER ETC, BACK ON WHICH YOU CAN ALSO DO IN YOUR COMPUTER.
WHEN INSTALLING NEW SOFTWARE, ANTIVIRUS IS USUALLY DISABLED, JUST ENABLE IT...TYPE IN ENABLE ANTI-VIRUS, IT WILL COME UP AND CHOOSE YOUR OPTIONS, YOU'LL HAVE TO DO THIS FOR YOUR FIRE WALL AND DEFENDER IF YOU HAVE THOSE ENABLE ALL OF THEM.
WHEN DONE RESTART, MAKE SURE YOUR PRINTER IS HOOKED UP TO COMPUTER, SO IT CAN BE DETECTED AND INSTALLED WHEN STARTING THE COMPUTER.
IF YOUR COMPUTER DOESN'T DETECT YOUR PRINTER, THAN GO INTO YOUR COMPUTER, CLICK ON ADD PRINTER, EITHER AUTOMATIALLY DETECT, OR ENTER THE INFO OF TYPE OF PRINTER AND WHETHER YOU HAVE THE DISK, INSERT DISK, IF YOU DON'T HAVE DISK, THEN CLICK ALL PRINTER INFO, WHAT BRAND & MODEL CLICK NEXT.
YOU WILL HAVE TO RESTART AGAIN, AFTER INSTALLING YOUR PRINTER, IF THAT IS NECCESSARY! SHOULD BE OK AFTER YOU ENABLE YOUR VIRUS PROTECTION.
HOPE THIS HELP!
MARTIE
Aug 24, 2011 | Computers & Internet
99 mercury cougar replaced power window motor and switch window still does not work
That doesn't seem possible does it ?
You remove the inner door panel
You think the motor may be bad,so you unplug it,
knowing it is a DC Motor & can be hooked up either
way & will run in either direction
You put 12 volts to it. Doesn't work ,sounds bad,you
install a new one
Now you need power from the switch to run the new motor,
so you work on that
The switch can be disconnected & tested with an OHM Meter
& if worn,you replace that
You checked the fuse before you started & knew that wasn't an issue,
because all the other windows worked
So what did you mis ,short of having no wiring diagram, to make
things a lot easier?
Aug 04, 2011 | 1999 Mercury Cougar
We have a SAnyo HDTV LCD Model DP19649 and can't
I have a sanyo dp-19649 tv and it's hooked up to a panasonic sound bar model# sc-htb10,and it's hooked up to a sony blueray dvd player. the sony player works on the sound bar but the tv doesn't.
Nov 12, 2009 | Sanyo Televison & Video
Mitsubishi WD-60737 60 in. HDTV Logo
73 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
