Question about Refrigerators
Good day I have a Whirlpool Refrigerator Model No. WBM 322SS - our refrigerator keeps dripping from the ice compartment above into the fridge below, how do I sort this problem out?
Model WBM 322 SS -
aborcass
  • 2651 Answers
SOURCE: refrigerator whirlpool model wrx38rwh6
sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine
Posted on Oct 26, 2008
  • 7 Answers
SOURCE: water is dripping into refrigerator
If it's the same as our GE fridge, there's a tube in the back of the fridge on the outside with an S shaped curve in it that may be plugged up with dust and/or dirt. Clean it out to let the water get through.
Hope this helps.
Johnnyczar
Posted on Mar 20, 2009
SOURCE: WATER DRIPS DOWN FROM INSIDE TOP REFRIGERATOR BELOW FREEZER
Not an original solution - but a good one. Remove panels at the back of the freezer compartment to expose the heater unit or heater wire that defrosts the freezer coils and wrap a solid copper wire gently around the heater/ heater wire and place the loose end in the drain. This will conduct heat to the freezer drain and help keep it open. I did see a manufactured part in one of the appliance parts websites but it did not match my unit.
Posted on Jun 09, 2009
woodchuck789
  • 4059 Answers
SOURCE: Kenmore refrigerator (model 106.78187891) leaking inside
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Posted on Aug 14, 2009
  • 3600 Answers
SOURCE: whirlpool 6 sense model WSC5513- A+ X side by
The temp for the fridge is about right and -18 for the freezer is ok so check to see if the water filter is plugged, at 8 degrees Celsius is about 18 degrees fht. Which is freezing so the numbers don't add up. 26 degrees below zero on the freezer side is what you want if it that cold it could have frozen the water line.
Posted on Aug 20, 2009
Refrigerator whirlpool wbm 501
Problem is defrost thermostat, defrost heating element or defrost timer and or low gas in the system. Remove the back panel in the freezer and look to see if the evaporator coils are frozen solid with ice. If so the problem is no defrost cycle. If no ice then the unit is low on gas and it has a leak. If the refrigerator is old... recycle it and go buy a new refrigerator from Whirlpool.
Feb 07, 2014 | Refrigerators
Model et18pkxfno1 serial eg4024334 type c18tfa97\r\nwater drips into refrigerator compartment somewhere from freezer (inside). Occurs daily. Tried to adjust temp in both refrigerator and freezer but...
The problem is that your fridge's drain line (which is located in the freezer) is iced over. So water can't drain out of the freezer when your fridge enters it's defrost cycle. The freezer and drain line needs to be defrosted by hand. Or you can unplug the fridge and open the doors for a 2-3 hours. Eventully, if no action is taken, the ice build up in the freezer will block the cold air flow to the refrigerator compartment .
Feb 19, 2011 | Whirlpool Refrigerators
Model EEV163F refrigerator our problem is: Ice in refrigertor compartment, water drips down from freezer. How can we fix the problem.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 15, 2010 | Whirlpool Refrigerators
I have a model ET8CHKXKQ0 1 Whirlpool refrigerator and it keeps collecting water in the meat tray, the vegetable tray and under both vegetable trays. I have vaccumed under the frig., in the back and...
The drain in the freezer is clogging. When the defrost switches on, the backed-up ice thaws and starts dripping down into the fridge area.
Easiest is probably to turn off the fridge, let it thaw, then check the freezer drain to see if you can unclog it.
Otherwise, you have to pull out the bottom and back parts in the freezer (which will probably have some sort of ice frozen to them). Once you see the drain pan, get a turkey baster and flat head screw driver. You'll have to make a hole in the ice above the drain and squirt hot water until you hear it start draining. The drain hole is off center to the right in the drain pan.
Good luck
Mar 23, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
My Whirlpool Refrigerator Model ER8MHMXML02 isn't as cold. Help!
Freezer drain plugged and froze up also froze the air returns to frig
Aug 22, 2009 | Whirlpool Refrigerators
May 29, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Hotpoint CTF15ELD top freezer refrigerator - freezer O.K. refrig too warm
It's likely the door was inadvertently left open, and the cold air passages from the freezer have built up enough ice that the cold air from the freezer has no way to enter the refrigerator. Check the cealing of the refrigerator. If you can see or feel ice in the passages between the freezer and fridge, you can probably solve the problem by finding a safe temporary home for your food, and leaving the refrigerator unplugged overnight.
May 25, 2009 | Hotpoint HTS16HBR Top Freezer Refrigerator
Water in bottom of fridge
Thanks to all who spent money or shared their experience to have somebody do this repair, and I really mean it.
I have a Whirlpool TopLoad Fridge (not a side by side).
Things you'll need
30 minutes
Small socket for cardboard panel on lower back and panel inside freezer
Bicycle Pump
4 Towels
Hair Dryer
1. Take everything out of freezer
2. Turn dials off in fridge for both compartments
3. Pull fridge out so you can get behind it and unplug it
4. Be vigilant of ice maker line if installed
5. Pull cardboard panel off on back
On the left side you should see the back of the skinny drip pan and a small line. That line goes from the freezer and is most likely clogged.
6. Blow dry the back of the freezer enough so the ice is thawed at the bottom of the back panel.
7. Remove the two screws on the back panel. You may just be able to pull it toward you enough to get behind it. You'll see the coils and fan, and underneath these you may see some ice sheets and there should be a hole. That is the drain line that is clogged. I heated up some water and poured it over the drain to thaw the line. You may want to remove the crisper drawers and put some towels down there to catch the overflow. Once the ice is thawed enough at the drain. Go to the back of the fridge and place the end of the bicycle pump at the bottom of the drain hose. Apply pressure to get a good seal but keep pumping. You may have to go back and forth between pumping and thawing, but you'll know it is clear when you hear air going into the freezer and then the wonderful moment when water drips into the drip pan as advertised!
Keep those fridges less full so that the door stays sealed and keep the seal clean and also keep your doors from having too much stuff so the weight of the door doesn't pull away.
Okay, put it back together, turn everything on and be careful of your cord and lines when pushing the fridge back. Thank the Lord ours has wheels and man,was it cruddy underneath. Vacuum those coils underneath the fridge too for proper air circulation.
Blessings to you!
tay
Sep 15, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Water Is accumulating at the bottom of my fridge....below the vegetable/fruit crispers. The fridge however contiues to keep things cold.
The automatic defroster is supposed to drip down a tube and deposit water into a tray underneath the refrigerator. If that tube becomes clogged with either ice or mold, water is supposed to drip down the back of the refrigerator and go under the crispers, but there is a drain under there that takes it to the tray under the refrigerator. That drain might get clogged with mold or food.
So my suggestion is, try to clear out the drains under the crispers. More difficult, remove the floor of the freezing compartment and clear out the drain there. If it is severely clogged with ice under there, you have a defrosting problem.
In this hot, muggy weather you are likely to get lots of condensation. Good luck.
Jun 13, 2008 | Whirlpool Refrigerators
Refrigerators Logo
54 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
