Question about Rotary Watches
Changing rotary english date watch - Rotary Watches
2 Suggested Answers
  • 2501 Answers
SOURCE: Ref G3002-Batt:UC-364 PO:01092. Rotary quartz watch. I require
Your watch should have a position in between home and fully out but it sounds as if your watch is like mine, where I cannot detect the position (i.e no click or feeling any detent).
Try to pull the crown wheel out a little and turn it. (the day and date change feature is in this middle position).
The english days can be achieved by turning the wheel until the desired day shows (it alternates between english and another language).
Have patience and keep trying until you get the feel for the correct position!
Posted on Mar 23, 2011
I bought a Rotary watch from amazon on 21 of October.Ican not find away of changing the date and it seems to stop at 1 clock
The instructions will be in the box it came in or if second hand, google the make and model number.
Jan 20, 2017 | Rotary Watches
How do i set the two faces of a rotary relelation watch
What happens when you pull out the button when viewing the white face?
May 26, 2014 | Rotary Revelation Reversible Black/White...
My DZ4067 functions in the non-English day of the week for 21 hours a day now. How do I change it back so the the day of the week is in English for 21 hours a day?
The "day of the week" wheel on your watch actually has 2 settings on it--one for English, one for another language (often French, but could also be Russian, Japanese, Korean, or any other language, depending on the intended distribution of the watch). You'll need to shift the day track over by "half a notch," so to speak, to get things back in alignment.
The crown you use to set your watch can be pulled out into 2 positions. If you pull it all the way out, you set the time. If you pull it half-way out, you can set the day and date. If you turn the crown clockwise, you advance the date. If you turn the crown counter-clockwise, you should be able to change the day of the week. However, instead of turning the day back a full day, stop when you get a day with the correct language on it. At this point, pull the crown out all the way and manually advance the time 12 or 24 hours until the day and date advance as they would when the watch is running. This is to check that you've correctly gotten the day track correctly oriented. You may have to repeat this process a second time to get it right.
Once you have the day back on track, adjust the date and time, and you should be good to go.
Diesel's own directions, which can be found here: http://store.dieseltimeframes.com/common/images/customercare/instructions/ENGLISH/Diesel_Core-Inst_ENG.pdf are pretty cryptic, but they do have a diagram that might help a little bit. You'll want to look at the section for "Day/Date Watch IS02, 507.2-3, 517.2, 2105, 2305, 2405"
May 26, 2011 | Diesel Watch Style # DZ4067
Ref G3002-Batt:UC-364 PO:01092. Rotary quartz watch. I require to alter the date and day feature which has english and european days. I can alter the time by pulling the handle out which is shielded in...
Mar 23, 2011 | Rotary Watches
Need help adjusting the day to english
Usually pulling out the crown to the second position sets the time by turning in one direction and the day by turning it in the other direction. I some you will need to advance the time through 24 hour cycles till you get the proper day displayed and then set the date.
Jun 19, 2010 | Watches
My citizen kinetic watch is set to show spanish days, vs. english i can see that there are english days when i change the time on my watch, but i do not know how to change the setting (this is not a...
Pull the crown out to the 2nd click...rotate the hands clockwise until the day or date changes, that will let you know that the watch is at midnight. Set the correct time, push the crown in all the way. Now pull it out to the first click and turn either direction to change the day/date to english! When your watch is correctly set then push the crown all the way back in and you are finished! :-)
Jan 15, 2010 | Citizen Watches
CYBEAT W.R.3BAR WATCH MANUAL
i have a cybeat watch,the manual is in japenese i need it in english
Dec 29, 2009 | Watches
I have agents rotary quartz with the number 3081 stamped on the back. the watch is oblong with a black black face and gold lettering and a date box. and gold intergrated strap. Would you please be able to...
Your watch is battery operated hence the term "quartz" All quartz watches are battery powered. As for value I'm not sure. The manufacturer of the module (mechanism inside) is a reasonable indicator of value. If its ETA then its in the upper range. You could try seeing if Rotary have a site if so they may allow you to identify details on age etc from the stamp numbers.
Jul 24, 2009 | Rotary Automatic Limited Edition Dark...
Day in both english and french alternately.
retailer contacted rotary.
apparently there is quite a delay (hours) before the day eventually chages back to English. In other words it doesn't change immediately after 12pm but sometime early in the morning?
The moral of the story is that you should be in bed before 12pm and not to take any notice of the day on your watch since it will still be yesterday and in French?
Jun 11, 2008 | Watches
Watches Logo
51 people viewed this question
Top Rotary Watches Experts
richie46
Are you a Rotary Watch Expert? Answer questions, earn points and help others
