SAKURA AV-5023 no RIGHT OUTPUT
Tried replacing the 2 resistors coz it was kinda burnt. but still no sound in right output. i even swap the left and right wires from the volume area to the board but still right output doesnt have a sound. i figured maybe the problem is in the board. but i am not really a technician. so i cant figure out what the problem is.
Palmbeach
  • 185 Answers
SOURCE: No signal from the Left output + Tinny sound
1. Assuming there is no problem with your amplifier of input cable, the headshell/tone-arm needs rewiring. This is very thin flexible wire and not easy to do, but can be done if you are careful.
2. Turntables require a special input on your amplifier which has a frequency response that is suitable for them. If you connect a turntable to an ordinary input, it will sound tinny. If you don't have a turntable input (known as a phono input [from phonograph]) you will need to use a preamplifier with your turntable.
Posted on Mar 17, 2008
jack_daniels
  • 304 Answers
SOURCE: No Sound in Right Front Speaker- Denon AVR-1508
hi there,
have you check the system settings for each of the speaker..? should be set and balance all output of the speaker
`jack
Posted on May 24, 2008
  • 4234 Answers
SOURCE: fuzzy sound from right front speaker output
The main issue is to determine where the distortion is coming from. Does it start in the front and and get amplified or does it appear in the output section only? This will require a fixed signal and an oscilloscope to trace. Check for leaky coupling caps or leaky transistors in at the diff-amp section.
Dan
Posted on Feb 02, 2009
  • 22 Answers
SOURCE: need wire diagram jvc av-48wp74
I have it send me your email
Posted on Feb 09, 2009
  • 182 Answers
SOURCE: wiring the scosche fai-3a to a pioneer two channel amp
the 2 left and right dont matter, it only matters when ur hooking up a 4 channel amp.
all u do is connect one of the channels to it but it would be best o buy a stereo ull have alot of engine nose and vibration on ur speakers and a thump every time u turn on ur car but itll sound ok for now ti
Posted on Jul 07, 2009
I am not getting equal sound from right as I am on left. The right is a little less on volume and wattage meter,when I balance it fully to right and turn the volume up, the sound gets static and scrat
Check your connecting terminals on both ends for that channel that the polarity is correct and firmly connected. If you find no problem with that, then swap the connections...if the problem repeats to the other side then the speaker is damaged. If the problem stays on right side then it is the unit and needs to be investigated further.
Dec 22, 2014 | Pioneer Sx-1080 Monster Receiver Beautiful...
Front left speaker stopped working. I use the system with my computer (full volume on computer), and usually half volume on the speaker. I've had the speaker for a few months now. I looked the wiring to...
You 'looked' at the wiring but have proven it is defective by swapping the speaker independent of the wiring. What's next? Replace the bad wiring.
What happens when you put a working speaker and wire on the front left output?
Apr 14, 2011 | Samsung HTC550 Theater System
I have bad static from my Pioneer vsx 49 Elite
sorry no easy solution as it sounds like the output transistors blew out or the emmitter resistors. you will need a service manual and an multimeter to measure the resistors on or around the audio output transistors they are a low value resistor usually around 1 to 2 watts in size. Do not replace any bad , burnt or discolloered resistors around the audio output transistors as if tou do you might just cause more damage to the output transistorsor audio output stage including the audio driver stage of the amp!!!!!!
Larry Dillon
Aug 27, 2009 | Audio Players & Recorders
Blue & red ghosts across screen. things look like there are two of everything covering approximately 2/3 of the screen
Sounds like your convergence outputs are bad and you may also have some low value resistors that need replaced. That set probably has 2 outputs. Both will need replaced even if only one is defective. Kinda like headlights, if one is bad, the other isn't far behind it. Excessive heat kills the amps after a few years of use.
Jul 18, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Amp won't power up,anymore! Even with new parts installed,removed
Hiya, dont have a diag either what you will have to try and is compare the left channel with the right. There will be 2 driver transistors (also likely on heatsink) close to the outputs. Check which driver drives which output on the left, then match it on the right. Those same drivers could very well also be a problem on the right as they often go with the outputs. There is a possibilty they have smoked again. See here to test FETS
http://www.4qdtec.com/mostest.html
Basically the left will match the right but not similar locations but definitely by track joins.
Also check the power resistors at the output. Often also go.
Hope that helps
Jul 15, 2009 | Car Audio & Video
Crackling
Possibly bad news I am sad to say. You might have lost the transistor in the right channel output Or if it is an IC that. The things on the heat-sink! However you might be lucky and it might be just either a bias resistor or a ceramic capacitor. The small components are cheap the bigger ones tend not to be. Resistors often look burnt, but apart from that is a case of replace and see.
May 28, 2009 | Audio Players & Recorders
Left channel does not work; plug needs to be wiggled in order for sound to come through
Try a new patch cable between the receiver's input and the device your using.Also try swapping out the left and right speakers. If the left side still isn't working it's probably the output transistors in the amp and they will need replacement.
May 06, 2009 | Audio Players & Recorders
NAD 302 stereo balance problem
I would replace the output transistors of the bad channel and any very low ohm resistors associated with them.
Whilst youre in there replace the electrolytic caps in the power amp section. Caps are cheap and plentiful.
I dont know what the rest of the circuit looks like but there might be a need to balance the DC offset after replacing transistors.
matelectronics.com and audiolabga.com carry many good replacement transistors.
Dec 30, 2008 | Audio Players & Recorders
VERY LOW SUB OUTPUT
does the volume change with the variable resistor knob when you turn up or down? If you open you may see burnt resistors in that area.
Sep 14, 2007 | Sony XM-4060GTX Car Audio Amplifier
Televison & Video Logo
145 people viewed this question
Top Televison & Video Experts
Electro Med Services...
