Question about Coffee Makers & Espresso Machines
How To Adjust a mulini salt grinder - Coffee Makers & Espresso Machines
Received partial order for 002-3709564-0135420. The Touchless automatic stainless steel pepper mill and salt grinder was not in package.
Please contact the vendor your ordered your items from. We have no way of 1) knowing what the item is; and 2) more importantly we have no idea who you ordered from. Please go online and find their customer service information.
Dec 02, 2016 | Coffee Makers & Espresso Machines
Why is there iodine in salt?
Because the USA government want you to take iodine. Buy Kosher Salt or Natural sea salt if you don't want the iodine.
From Wikipedia, the free encyclopedia Jump to:navigation, search global_iodized_salt_logo.jpg Global logo for iodised salt. Logos, such as this one, are placed on salt packages to help consumers identify salt that contains added iodine. Iodised salt (also spelled iodized salt) is table salt mixed with a minute amount of various salts of the element iodine. The ingestion of iodine prevents iodine deficiency. Worldwide, iodine deficiency affects about two billion people and is the leading preventable cause of intellectual and developmental disabilities.[1][2] Deficiency also causes thyroid gland problems, including "endemic goitre". In many countries, iodine deficiency is a major public health problem that can be cheaply addressed by purposely adding small amounts of iodine to the sodium chloride salt.
Iodine is a micronutrient and dietary mineral that is naturally present in the food supply in some regions, especially near sea coasts, but is generally quite rare in the Earth's crust, since iodine is a so-called "heavy" element and abundance of chemical elements generally declines with greater atomic mass. Where natural levels of iodine in the soil are low and the iodine is not taken up by vegetables, iodine added to salt provides the small but essential amount of iodide needed by humans.
Iodine in Salt Why Is It Added
Nov 03, 2015 | Wolfgang Puck 1181667 Colored Salt And...
Salt and pepper grinders how to clean
warm soapy water, you can put some soapy water in the grinder, shaker and shake it vigorously to remove any pepper or salt that is stubborn, but hot water will dissolve the salt and loosen the pepper.
Sep 29, 2014 | Cuisinart Salt and Pepper Grinder,...
Wolfgang puck bistro elite gravity spice mill
Go to this website: http://www.hsn.com/products/wolfgang-puck-bistro-spice-mill-with-peppercorns/7012934
and click on the Video under the grinder picture. I think this may be helpful
Feb 10, 2013 | Wolfgang Puck Bistro Elite Gravity Spice...
How to load peppercorns into trudeau 0716840
I found the following webpage on your grinder: www.shoptrudeau.com/v/vspfiles/images/instructions/0716840.pdf
Just in case the link doesn't work, it looks like the top (salt) part just pulls off the bottom, pepper grinder part. With the top off, there's a hole to pour the peppercorns into.
Jan 20, 2013 | Trudeau 0716840 Click Combo Pepper Mill...
My grinder will not turn on. The cup and lid are on lockThe light are on. When i press the start button it does not grind
The best case is that the contacts that turn the motor on are not working, maybe need cleaning. Someone would have to open up the grinder to check and correct that. The worst case would be that the rotor or field coil to the motor became fried. That happened to me when I tried to grind damp sea salt.
Jul 29, 2011 | Mr. Coffee 2.3 oz. Coffee Grinder - White
Stupid question but how do you refill the pepper grinder of the Octo Combo? I don't consider this an appliance since it doesn't use electricity or batteries but couldn't figure out another category for...
Hi, from the photos I see on the web, it looks like you hold the salt chamber and then unscrew the nut on the top of the unit. I would say that you need to then pour out the salt into a small container, and then grasp the bottom (pepper chamber) and pull up on the salt chamber to separate it from the bottom chamber. Fill the pepper chamber and then replace the salt chamber and fill with salt, replace salt cover and then replace nut. I hope this helps.
Jan 02, 2011 | Vacuums
Coffee Makers & Espresso Machines Logo
46 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
