Question about Acer Aspire M3641 Dual Core E2200 PC Desktop
No signal to monitor from my pc
Tower powers on but that's about it i have no output from anything no signal to the monitor no usb work. fans spin and hard drive sounds like its working. and there is no beeps tried removing the ram and resetting the bios but still the same any help would be really appreciated
    Brigadier General:
  • Acer Master
  • 3,400 Answers
TRY WITH A OTHER PSU.CAN BE THE PROBLEM.
Posted on Jul 25, 2013
4 Suggested Answers
Fredinot
  • 96 Answers
SOURCE: Desktop will not boot into bios No Usb power;monitor ''No Signal''
Your problem is the memory . YOu have to put off the pc and remove the memory card in the slot. Then clean the silver pins in your memory with a rubber eraser. Put it back and see if the BIOS will be prompted on the screen , if not you have to replace the memory.
Posted on Feb 12, 2010
  • 388 Answers
SOURCE: No signal to monitor and will not respond to manual shutdown.
sounds like the wire to the power button is disconnected also remove the battery unplug form the mains leave for an hour restart the machine without the battery to reset the CMOS
Posted on Feb 11, 2012
joecoolvette
  • 5660 Answers
SOURCE: My Computer powers up but no beeps and "no signal" displayed on monitor. All the fans are working and the tower is relatively clean inside and free from dust, obviously a component has failed to start
Would appear to be a bad Power Supply.
Do you have a multimeter, to test the 3 low DC Voltages coming out of the Power Supply?
A) 3.3 Volts
B) 5 Volts
C) 12 Volts
Again, all are DC Voltage.
In comparison two D cell flashlight batteries produce 3 Volts DC.
(The dangerous AC electricity is contained within, the metal case of the Power Supply)
I have seen economical multimeter's on checkout aisle racks, at major discount stores.
http://en.wikipedia.org/wiki/Computer_power_supply#Wiring_diagrams
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain24
[Don't cut on any insulation of wires. There is a better method, and it does not involve that ]
If this is not feasible for you, how about borrowing (Temporarily), a KNOWN to be good, Compatible power supply; from a working computer?
Either way we are trying to see if the Power Supply is the problem, before you spend your hard earned money.
There is also a visual test you can perform, to see if other components have failed. Electronic components on the motherboard;
Electrolytic Capacitors.
More specifically, they are Radial Aluminum Electrolytic Capacitors,
http://www.ebay.co.uk/itm/Foxconn-RS780M03A1-8EKRS2HM-AM2-for-Aspire-M3201-/130620116535
Posted for visual identification, of Electrolytic Capacitors on motherboard, not advertising for seller; nor website.
Scroll the page down to the large photo.
http://capacitorlab.com/visible-failures/index.htm
http://www.youtube.com/watch?v=Lut7MX5Dd_A
What do they do?
Some of them are used as Filters.
Some of them are in the Motherboard Voltage Regulator Circuit.
Part of what the motherboard voltage regulator circuit does, is to regulate voltage for the Processor (CPU)
The Processor MUST have a steady. 'clean', supply of voltage; and it MUST be kept within the tight voltage range, for the Processor.
Too little, or too much, and the Processor turns off.
(BIOS turns it off)
http://www.hardwaresecrets.com/article/616
If you find faulty Electrolytic Capacitors, can they be replaced?
Yes.
Do I know this will fix the motherboard, or are they just the start?
No.
All I can tell you is this;
I have replaced faulty ones for years, now. The rate of repair fixing the problem is pretty high.
What people do not know, is that we, the worlds electronic consumers; have been plagued with a problem of faulty Electrolytic Capacitors, for years.
Y-E-A-R-S
Started in the early 70's to my knowledge, and continues to plague us today.
Not talking just computers; speaking of all electronic devices that use Electrolytic Capacitors.
(For one; have you ever had an AT&T router go out?)
http://en.wikipedia.org/wiki/Capacitor_plague
Will wait for your reply.
Can I help you in replacing bad 'caps'?
Sure.
Do you have basic soldering skills?
Please post back in a Comment.
Regards,
joecoolvette
http://www.hardwaresecrets.com/article/595
http://www.youtube.com/watch?v=YCSNWi3UHf4
Posted on Mar 29, 2013
Gateway a computer desktop has power but nothing on screen the computer doesn't have a tower
1) Computer doesn't have a tower? Means it is a 'pancake style' of desktop computer. A flat model.
2) No signal on monitor screen?
Good.
At least we know the monitor is good.
Problem is monitor cable, IF separate cable; or computer.
Computer isn't sending a video signal.
No Signal, Power Saver Mode, etc.
If an older CRT type monitor, (Looks like a small TV), and monitor cable is not detachable; use a known to be working monitor, and monitor cable.
If a separate monitor cable, use a monitor cable from a working computer, for a temporary test unit.
Put it back when deemed monitor cable is the problem.
Logic at this point, would deem something is wrong with the graphics chipset.
Whether mounted directly to motherboard, (Integrated), or a separate graphics adapter card. (Graphics/Video Card)
However, computer could be dirty inside, or have a bad Power Supply.
LED's (lights) light up? Maybe fans spin?
Means nothing.
1) If ALL of the Light Emitting Diodes were on at once, they would use less than 1 Watt of power.
2) EACH fan uses 2 to 3 Watts of power.
3) A typical Processor can use from 51 to 130 Watts of power.
Just depends on what Processor it is.
Older desktop computer?
Ummm, 35 to 40 Watts.
That is why LED's can light, and maybe fans spin, but no computer.
NOT enough power to turn the Processor on.
Computer needs to be CLEAN on the inside. Inside of Power Supply too, as well as possible.
Proper method to do this procedure, post back in Comment if you need guidance.
Also remove ALL Ram Memory modules, and clean gold plated contact pins on bottom; with pencil eraser.
Reinstall. Make SURE they are seated in tight, and Lock 'ears' are locked in place.
Post in a Comment, as to the model number.
Example, DX4300-05. Should be on back of computer.
Regards,
joecoolvette
Mar 22, 2013 | Gateway Computers & Internet
Acer Aspire x5810 black screen
Can you open the setup page a reboot to verify your settings? Try a system restore/recovery. I'm not sure if that will help but it's a start. When you alter the BIOS or the System Registry it can be a minefield, one wrong move and will you know. Second, would be to remove the CMOS battery for a few hours and see if that clears up the issue.
Nov 13, 2012 | Computers & Internet
Pisplay not shown
Display not shown?
1) Does the monitor show No Signal?
If so go on.
If not;
Use another known to be good monitor, and monitor cable, on your desktop computer. Be aware that the problem may be the monitor cable.
Or use your monitor cable, and monitor, on another KNOWN to be working computer.
The monitor isn't receiving a Video Signal. Means the signal is not reaching the monitor. Could just be a bad monitor cable.
2) If the monitor is good, and the monitor cable is good, the problem is the computer itself. The computer isn't working.
You may see LED lights light up, hear fans running, and maybe even the Harddrive spinning.
Problem could be the Power Supply.
A) IF, all of the LED lights were on at once, they would use less than 1 Watt of power.
B) EACH fan only uses 2 to 3 Watts of power.
C) A typical Processor can use 51 to 125 Watts of power. Just depends on what Processor it is.
(Older Intel Pentium III processors, and AMD Athlon processors, use less power than 51 Watts)
Not enough power? BIOS will not turn the Processor on.
Solution is to test the Power Supply's 3 main voltage power rails, or use another KNOWN to be good, COMPATIBLE power supply, for a test unit.
The 3 main voltage power rails are;
A) 3.3 Volt power rail
B) 5 Volt power rail
C) 12 Volt power rail
Test is done with an economical Multimeter, set to DC Voltage.
Post the model number of the IBM Netvista desktop computer. You will find it on the back of the computer, next to the Windows product key,
(XXXXX-XXXXX-XXXXX-XXXXX-XXXXX), or up on the side of the computer tower.
Post in a Comment.
Regards,
joecoolvette
May 20, 2012 | IBM NetVista PC Desktop
When I turn my computer on, my monitor displays a message of 'vga signal, no vga input signal' and 'dvi signal, no dvi input signal' and 'monitor going to sleep'. My cables are...
The symptoms you described is common in fault mobo or VGA card.But VGA doesn,t turn bad so easy.I suggest to change your mobo first.
If you need more help post back!
Thumbs and testimonial are welcome!
Aug 15, 2011 | HP dx2300 Monitor Personal computer Intel...
My fujitsu scaleo p tower won't display anything on the monitor! The monitor works fine with other devices.... everything spins and all LEDs light up just no output to the monitor :/ any...
Have you tried putting the Graphics card in a Different slot? If you have and it is still not working most-likely it means that your video card has gone bad and needs replacing.
Jul 11, 2011 | Fujitsu Siemens SCALEO 600 (FSP:83C005617)...
Veriton 7600gt why no output video is going to the monitor
Hi mellomoris,
Sometimes we wonder why there is no video output on the monitor or we just get "no signal" display. This may happen if the vga cable or the cable that connects from the monitor to the system unit (tower) is loose. It also happens when the monitor has power but the system unit is not turned on. In this case, you can try to do the steps below if it can resolve the issue. (This works with others, I hope it'll work on yours.)
- Sheck the cables and connections to make sure that they're securely plugged in.
- If you have another monitor, please try to plug it in.
- Try to check if there is activity on your harddrive or fan, issue might not be with the monitor but with the system unit.
Hope this helps.
May 27, 2011 | Acer Veriton 7600GT PC Desktop
When I turn the computer on it goes into digital power save and windows does not load
The monitor is going into power-save mode because it's not receiving a video signal from your computer. Are you turning on the computer at the monitor or on the tower? If you're turning the tower on are you hearing any noise (i.e. fans running, beeps, drives spinning, etc.)? Does the power light on the tower come on and stay on? If not you may have a bad power supply or other hardware issue.
May 02, 2011 | Computers & Internet
MY HP TOWER TURNS ON AND THE FAN RUNS, BUT DOES NOT SEND A SIGNAL TO THE KEYBOARD OR MONITOR. BOTH THE KEYBOARD AND MONITOR HAVE POWER AND ARE PLUGGED INTO THE TOWER. ON OFF BUTTON IS ILLUMINATED ON THE...
If the keyboard and is USB, you can try another USB port. For the monitor not getting display, I would try either a different monitor or a video card. Otherwise, the motherboard could be the problem.
Oct 02, 2010 | Computers & Internet
No signal or cable disconnected or power problem
check the black cable with big blue connector at the back of the monitor if its connected properly. Also follow the cable and check if its securely attached at the back of the system tower. if the cables are connected properly check if the cable is connected to the correct port at the back of the system tower. Some computers have two places to connect this cable one towards the top and other towards the bottom of the system, tower.
Thanks for using fixya
proton
Jun 16, 2010 | Dell Inspiron 530 Desktop Computer
Cpu says no input vga signal, then goes to sleep
The no input VGA signal just means that the monitor is not receiving anything from the graphic card on the tower. Is the card a digital (DVI) output card? You'll know by the connector, it's white and slightly wider than a standard VGA connector. If so, perhaps the monitor is set to the wrong input?
If that isn't the case, and the computer is using an on-board or built-in graphics controller, you could try resetting the system's CMOS settings by setting the clear-settings jumper on the system board, or simply remove the plug and CMOS battery for a few minutes. Check the computer's documentation on the exact steps to do this.
Hope this helps!
May 19, 2009 | HP GX613AA Pavilion A6300F Desktop PC
Acer Aspire M3641 Dual Core E2200  PC Desktop Logo
71 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
