Power wont turn on my Staples SPL-1506X Paper Shredder
Power wont turn on. nothing goes on. what could be wrong and could i fix it myself?
macrule413
SOURCE: Ativa SPL 1506X not working
I had the same "click" noise when trying to shred. I had a Staples replacement guarantee (extended warranty) so I called them up and described the issue. They are sending me a gift card for the purchase amount. Seeing as they did not want the original unit back I decided to take it apart to see if I could find the problem. I did not find an issue with the gear as the other user stated but I did notice a burn mark on the circuit board just under the relay (which could make a click noise) I removed and inspected the relay (desoldered), but I could not see anything wrong with it so I re-soldered it back onto the board and re-soldered (re-flowed) all of the other connections just in case there was a cracked joint. Upon testing the shredder still has the same "click" sound. My guess is there is a faulty device on the circuit board such as a resistor or relay. To sum it up, to repair this particular issue you will be unable to implement a "simple" fix and it would realistically require either a new circuit board or a whole new shredder.
Posted on Jun 22, 2008
SOURCE: Staples SPL-1506X Shredder Issue
I had the same problem. I have a solution but I do not recommend this unless you have technical experience with repairing electrical appliances. I took the back cover of the main shredder unit to expose the wiring (there are 7 screws in total). The bin full sensor has a blue, green, and red connected to it. I clipped the blue wire to defeat the Bin Full error. You can look through the plastic window to check that the bin is full.
Posted on Aug 09, 2008
Well, despite the manufacters warning label I choose to take the shredder apart and found that one of the plastic gears was broken. Hence the motor runs, but the blades do not turn. The thing I didn't understand, the there are metal gears and plasic gears...I can only imagine that the plastic gears at one point or another are going to give. I would suggest not to void the manufacters warrenty, take the shredder back, and get one that is built a little stronger. Hope that helps.
Posted on Aug 12, 2008
  • 7 Answers
SOURCE: Have a Staples shredder SPL 1506X and need to find
no there is not
Posted on Jun 11, 2009
  • 300 Answers
SOURCE: Automatic switch does not shut off after shredding
These shredders have a "paper in" sensor. This is either optical or mechanical.
Sounds like the sensor is blocked and therefore "thinks" there is still more paper left, and this is why it keeps going.
Before you do anything UNPLUG THE SHREDDER.
The sensor is located about in the middle and at the level of the blades.
If it's mechanical, you should see a little finger, else it is electronic.
Shine a light in the area and you should be able to spot where the blockage is.
A shot with compressed ais usually gets rid of the offending particles.
After you're finished working on it, set it back securely on the basket and plug it in.
Posted on Feb 14, 2011
Where can I obtain a repair manual for a Staples SPL 1506X Shredder
You can't. You take it apart yourself, you find the cogs inside are plastic and shattered and you can't get replacements, so you have to buy a new one.
Apr 09, 2016 | Staples Office Equipment & Supplies
How to oil shredder staples spl-1506x?
You can buy commercial products, or run some wax paper through your machine periodically. The wax will not gum up like oil and attract dirt.
Jul 13, 2014 | Staples Office Equipment & Supplies
Spl-1506x shredder only runs in reverse
Daniel:
Unplug the shredder... Take the top off and turn it upside down. Use a screwdriver to take the lower cowling off and look at the motor. If the mounting area where the motor sits looks melted at all, the machine is toast. If the motor mounting area looks good, look at the slot where the paper is inserted... there should be a sensor (that "sees" the paper when you insert it) at the paper slot. Check to see that the sensor isn't damaged.
Nov 11, 2012 | Staples SPL1506X (CrossCut) Shredder
Staple Model SPL-XC200D Paper Shredder, During the
Fixya does not sell parts and cannot identify sources.
Jul 18, 2017 | Staples SPLXC200D Shredder
Automatic switch does not shut off after shredding on Staples model SPL-1506X shredder.
Feb 13, 2011 | Staples SPL1506X (CrossCut) Shredder
SPL 1506X Shredder
Have you looked for hidden staples in the machine. Sometimes they can be hard to spot.
Aug 01, 2008 | Office Depot Ativa DQ60M Shredder
Staples SPL-1506X
Jul 05, 2008 | Office Depot Ativa DQ60M Shredder
Apr 25, 2008 | Office Depot Ativa DQ60M Shredder
Shredder problem
Call us at Fellowes Customer Service 1-800-945-4545 On Monday between 7am and 7pm Central Standard Time
Feb 23, 2008 | Fellowes DM15C Shredder
I had the same problem. I took the machine apart and found out that the main gear running the rollers was defective. All of the cogs were broken or worn out, If you can find parts it can be fixed?
Nov 29, 2007 | Office Depot Ativa DQ60M Shredder
65 people viewed this question
k24674
jasbo
jasbo
