Question about Illy By Francic Francis X7 Expresso Machine ,barely Used
Upgrade illy x7.1 steam wand
I'd like to change illy Francis Francis X7.1 steam wand like X7 steam wand. But illy doesn't sell X7 steam wand. Does anyone have an idea which product's steam wand fits for illy X7.1?
Red triangle will not stop flashing even after I descale
I have the Illy coffee maschine x7.1 and I'm trying to do the descaling (since the litle triangle sign is flashing), but power button doesn't start flashing after I push the coffee and steam button together (as indicated in the manual). Any suggestions what I should do, that the on/off button would start flashing?
Jan 25, 2014 | Illy Francis Francis X7.1 iperEspresso...
Lost nozzle on steam wand of Francis Francis x7
I did a quick search, and unfortunately, your only realistic options are to either fabricate yourself one, or try to get one via the manufacturer.
Sep 02, 2012 | Illy Francis Francis X7.1 iperEspresso...
Francis francis X1---the steam nozzles won't work,
HI Unscrew the chrome tip from the wand. Then check the wand tube for a plug. Insert a paper clip into the wand tip to see if there is a restriction.
Feb 07, 2010 | FrancisFrancis! Coffee Makers & Espresso...
My francis and francis is leaking and the espresso
Hi
Try calling Illy at 877-469-4559. They can help you get your machine fixed.
Jul 15, 2009 | FrancisFrancis! X1 - Stainless Steel...
Francis francis x1, blocked steamer
Pour in a solution of 50% distilled white vinegar and 50 % water. Set the steam wand knob to a water setting, and run the solution through there. I would suggest letting a small amount of the vinegar/water solution drip out, then cut the machine off for about 20 minutes - allowing the vinegar to thoroughly soak and decalcify the insides. After 20 minutes, let the remaining vinegar/water pour through.
If the problem persists, Francis Franic is now owned by illy - 1-877-469-4559
-Tha Mp3 doctor
Oct 05, 2008 | FrancisFrancis! X1 Espresso Machine
Illy By Francic Francis X7 Expresso Machine ,barely Used Logo
171 people viewed this question
Top Illy Coffee Makers & Espresso Machines Experts
ray gallant
Shrikant Shinde
Shrikant Shinde
Level 1 Expert
Are you an Illy Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
