Question about Juicers
Breville br3 basket - Juicers
The wire basket of my Breville Juicer is rusted. is there a safe way to remove the rust or am I going to have to buy a new part? if it the the former, what should I use? if it is the latter, where can
I am not sure how rusted it is, but it should be fairly easy to clean.
I would start with either distilled white vinegar or fresh lemon juice. You should have good results with either.
Otherwise Breville does have an 800 number or just google the model number and part name, the part should be available.
Feb 13, 2015 | Breville Juicers
I cannot get the mesh basket off it is stuck fast
If you can, soak the mesh basket in some hot water, boiling if possible. Many times this will break up residue
May 04, 2011 | Breville JE900 Juicer
My Breville juicer JE95 needs a new plastic fliter bowl surround. Where can I find one for this model, please?
Hi! My name is Mace and I'm here to help you.
The part you need is called Filter Basket and this cost around 53.99 us dollars.
You can purchase for this part online from this link
1. http://www.brevilleusa.com/parts/filter-basket-je95xl26.html
other price for this:
1. http://www.cresdo.com/product/12923
2. http://www.thegourmetdepotco.com/store_details.asp?item=6627
I hope all informations is in my answer.
Thank you for using Fixya.
Jan 12, 2011 | Breville JE95XL Juicer
Cannot twist off the filter basket of the breville JE 900 Juicer
I had the same problem. It must juat got a bit stuck - I gave it a really good twist anti-clockwise and it came unstuck and popped lose.
May 13, 2010 | Breville JE900 Juicer
I cant get the filter out of my Breville JE900
hmm, i cant tell if this is the same as my juice fountain. mine just twists to the side and then you can lift both pieces out together. then the filter just falls out when i turn it upside down.
Jan 02, 2010 | Breville JE900 Juicer
Where can I get a replacement filter basket for Breville JE95XL?
I have one. It is brand new and if you are interested I will make a deal with you as I no longer have the juicer. stormsound1@aol.com
Nov 15, 2009 | Breville JE95XL Juicer
Replacement part needed
TRY 800 424 6783. PERSONALLY USING
A BREVILLE IS LIKE HANDLING A LOADED
WEAPON. MIGHT WANT TO CK OUT THE
OMEGA 4000.
May 06, 2009 | Juicers
Breville JE90J juice fountain spare part
The coupling on the juicer basket end is no big problem, but the coupling on the motor end is a big problem as you need to stop the motor from rotating to unscrew the coupling. This means remiving the base of the juicer which may be difficult because of the type of screws involved.
JE90/06 DRIVE COUPLING,
JE95/26 FILTER BASKET & DRIVE COUPLING
If you email me at sales@ewingelectrical.com.au I can help you with prices etc.
Mar 28, 2009 | Breville JE3 Juicer
Juicers Logo
Top Juicers Experts
eyecam
Tom Chichester
David Payne
David Payne
Are you a Juicer Expert? Answer questions, earn points and help others
