Question about Canon Office Equipment & Supplies
Mp280 error p03
Error P03
SOURCE: /*mp250 error code p03 alarm
manual replacing the print cartridges --> try rotating the left white gear back and forward releasing the mechanical lock of the print head it is a small plastic peace in the back of the of the head ...replace the cartridge as you need ...
about the error p03 it indicates a mechanical jam (head carriage - paper jem - paper pickup mechanizm - head cleaning mechanizm ) also clean carfully all sensors from inside ... it can give you a mechanical jam if blocked
Posted on Dec 23, 2010
  • 77 Answers
SOURCE: I have a error on
If it's not a paper jam or out of ink than you should reinstall the drive.
You can download the Canon MP250 driver from here.
Posted on Feb 01, 2011
sabuv
  • 113 Answers
SOURCE: flashing p03 on mp250 printer
Line feed error. Perform the following for the timing **** disk film: - Clean it & Re-attach it - Replace it, if it cannot be cleaned, or if it is deformed or damaged. If problem not solved replace the logic board if not solved replace the entire drive unit.
Posted on May 15, 2011
pheireith244
  • 310 Answers
SOURCE: Error code P03. It won't
Error code PO3 is caused by Timing Disk dirty / damaged.
Please use this methods
1. Check the timing disk sensor located to the left of the printer
2. Check and clean the board.
And start to print... thanks
Posted on Aug 12, 2011
webster1280
  • 5 Answers
SOURCE: What does Error code P03 mean on Canon Pixma MP495
Download the manuel from this link below:http://www.manualowl.com/p/Canon/PIXMA-MP495/Manual/68096
It might have some trouble info for you. ;-)
Posted on Jan 29, 2012
Mp280 printer indicating p /3
P03 is a mechanical jam (carriage, paper jam, paper pickup etc).
Open everything you can and look for foreign objects or jammed paper inside the printer.
If you cannot see anything then it may be a sensor error. You could always try cleaning the sensors if you were feeling brave.
Oct 30, 2012 | Canon MP280 All-In-One InkJet Printer
Mp495 P03
Look in the instructions to find out what the button press sequence is to reset the printer.
Jul 28, 2017 | Canon PIXMA MP495 InkJet Printer
Error code p03
Hi
P03 means Line feed error.
The probable cause is: Timing Disk dirty / damaged.
Solution:
Thanks for contacting fixya.com
Please do get back to us for further query.
Jan 05, 2012 | Office Equipment & Supplies
Mp495 error p03
Hithere all the P errors on Canon devices are repair.I hope this information will help you.
Dec 12, 2011 | Canon PIXMA Office Equipment & Supplies
I have a error on my canon mp250 but its not a paper jam - error P03
Feb 01, 2011 | Office Equipment & Supplies
My mp280 shows po3 error this is not listed in the manual what does it mean , please
P03 is a line feed error. It has to do with an electronic error inside your printer.
Either your timing disk sensor is bad on you main logic board is bad. It either needs to be repaired or replaced...
You can go to Canon's website for an estimate on the cost of repair. That way you can decide to fix or replace.
http://www.usa.canon.com/cusa/consumer?pageKeyCode=repairLanding
Jan 30, 2011 | Canon Office Equipment & Supplies
/*mp250 error code p03 alarm and on light flashing, color ink light on. trying to change cartridge but cartridge head will not go to the center so i can change it. help
Dec 09, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
Errors
If this is a Xerox 128, I have looked through all the documentation and those are non standard fault codes.
I would first start by seeing if the scanner was comming on and moving correctly.
The only other thing you can try is to remove all the covers and disconnect and reconnect plugs, and ribbon cables.
There is nothing in the documentation or engineering notes to reference any of those error codes.
Not even eliminating the P and just looking up the individual codes as just numerical codes.
A non functioning scanner will produce many odd codes not listed in documentation, which is why I am having you start there. Reseating connectors will allow all modules to communicate, which can also produce odd codes.
Feb 26, 2008 | Xerox WorkCentre PRO 128 Copier
old marine
old marine
