Question about GeoSpring Hybrid Water Heater
14 month old water heater stopped working
The control panel has gone blank and the heater appears to have lost all power. I have reset every circuit breaker in the house and it is still blank. Frankly it is as if there is no power to the unit at all. However how could that be possible for it to randomly stop getting power?
  • GE Master
  • 5,089 Answers
Which water heater do you have??? What is year of manufacture?
Rheem-GE Geo spring hybrid: Rheem-GE heat pump ?? then call GE 888-443-4394 for recommendation of local service technician and expect to pay $400 and do not expect problem to get solved unless area has experienced, certified water-heater-air-conditioning expert.
Installation must be done correctly. For example if water heater is set too close to wall, then service technician will expect you to hire plumber to empty tank and move away from wall and install correctly before repair can resume. It's a nuisance, but this is accurate information based on others who have posted questions.
Copy following link for resources:
http://waterheatertimer.org/Review-GE-Heat-Pump-water-heater.html#maintenance
http://waterheatertimer.org/GE-heat-pump-manuals-by-date.html
There are no service manuals available for homeowner, which is why this product is unwise choice for any installation.
Unit is not protected from power surge. Install one-time-use whole house power surge.
Make sure unit is connected to 240V, and that breaker is not tripped off on one leg. Move wires to another same size breaker. Check wire connections at water heater and confirm 240V.
Check that installation is done correctly as shown on link above.
14 months old means that labor warranty has expired by 2 months. However parts are still covered.
Do not buy expensive water heaters that cannot be repaired easily by homeowner. This single repair can eliminate all anticipated savings from buying product.
If expected heat-pump repair will cost $400, then buy off-the-shelf electric water heater from Lowes for $250 and save the expensive repair.
Gene
Posted on Jul 25, 2013
I purchased a home a little more than a month ago that has an Aqualink RS8 system installed. A couple weeks ago, we noticed that in the indoor control panel was not lit, so we checked the outside panel. ...
open the aqualink control box remove the top panel see if the 4 pin red connector is plugged in and tight if it is check to see if the one inside is connected if ok check to see if wiring is cut
Sep 27, 2014 | Jandy Aqualink All Button RS Control...
GE SmartWater Hot water tank. Water heater will not stop heating.
Hello Anita:
1) For gas water heater: Turn off gas to heater:
http://waterheatertimer.org/images/Gas-water-heater-89-valve-2.jpg
2) For electric water heater: Turn off circuit breaker.
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#veryhot
3) For gas: Copy following link to identify gas control valve thermostat, and troubleshoot by type of gas control.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
4) For gas: Gas control valve thermostat has probably gone bad.
5) Add comment and give clear description of water heater.
6) Call plumber.
Feb 17, 2013 | Water Heaters
GE Smart Water Hot water heater 40 gal will not stop heating water.
1) For gas: Turn off gas to heater:
2) For electric: Turn off circuit breaker.
6) Call plumber.
Feb 17, 2013 | General Electric GE SmartWater Household...
Have a reliance electric water heater model 606; have no hot water. I am having a problem finding the reset switch.
If it was working and recently stopped working, the heating element that heats the water probably went bad, no longer functioning. Check to make sure that there is or is not a reset button, and if there is, press and reset the heater. It's not difficult to remove the old heater element and replace it, but make sure the circuit breaker power to the water heater is off when you remove it. Take it to a water heating supply store, or large hardware store with the Brand and model number of your water heater (Reliance RELIANCE ELECTRIC WATER HEATER,model 606 ) to buy another one.
Sep 21, 2012 | RELIANCE ELECTRIC WATER HEATER
The water heater (Reliance Elec 501) does not turn on, This happened on the same day that our whole apartment lost power due to tripped main switch.n I reset main but water heater does not respond,...
Two-element water heater is 240Volts.
No hot water means: ECO reset button tripped, upper element bad, upper thermostat bad, or 240Volts is not reaching water heater.
Circuit breaker can be delivering power on one leg of the 240V circuit, so water heater appears to have electricity but is only receiving 120V.
Test for 240volts across top two screws on upper thermostat.
Look for loose wires and burned connections.
Push in reset button real hard.
Replace both upper and lower thermostats.
Remove wires and test upper element for continuity.
Open following links for do-it-yourself troubleshoot walk-thru:
http://waterheatertimer.org/B220C.html
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
http://waterheatertimer.org/How-to-troubleshoot-electric-water-heater.html
http://waterheatertimer.org/Test-electricity-to-water-heater.html
Aug 21, 2011 | RELIANCE ELECTRIC WATER HEATER
One of the breakers assigned to our Hot wtr htr has been tripping recently leading to loss of hot water. This has happened twice in the last month. After resetting the breaker things have worked fine,...
Breaker could be bad.
Let's do a quick check and save you money.
Open top cover on water heater and push in red reset button that might be tripped.
If reset is tripped, water heater should turn ON.
If reset will not reset, then replace upper thermostat:
If reset is not tripped out, then it is OK, so test two top wires on upper thermostat.
Use cheap multimeter from home center, and set dial to 240-250-277 VAC.
Test across top two screws on upper thermostat to see if you have 240Volts.
To do full troubleshoot on ordinary tank electric water heater takes 30 minutes and multimeter
If water heater is not receiving 240V, then the breaker is suspect, or a wire between breaker and water heater is loose.
See basic water heater circuit
http://waterheatertimer.org/240-v-water-heater-circuit.html
Now let's look at circuit breaker:
Mark suspect 240V breaker.
Identify all your breakers, and also mark another 240 Volt breaker that is same amperage as water heater 240V breaker.
Turn off main breaker.
Take front panel off breaker box.
The wires and lugs on main breaker are HOT, so stay away from that area.
http://waterheatertimer.org/See-inside-main-breaker-box.html
Suspect breaker has 2 wires coming from breaker.
See if one or both wires are loose, and then tighten.
If wires are tight, then move these wires to the other 240V breaker that is rated for same amps as water heater.
Now turn on main breaker.
Put ear against water heater tank to hear bubbly fizzing sound.
This will identify if circuit breaker is bad, or if water heater needs a full troubleshoot.
It is not a good idea to run two 240V appliances on same 240V circuit breaker, so you may have to decide one or the other appliance until you can replace breaker.
Instructions to replace circuit breaker:
http://waterheatertimer.org/How-to-replace-circuit-breaker.html
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on water heater circuit.
Jan 07, 2011 | Water Heaters
The water heater does not react to lowering the temperature...water is above 130 degrees... This is a whirlpool energy smart residential water heater that was bought and installed in Mar of this year. It...
Product features show on link below
http://waterheatertimer.org/Whirlpool-Energy-Smart-electric.html
Energy smart manual shows troubleshooting chart on page 14
http://waterheatertimer.org/pdf/Whirlpool-energy-smart-electric-manual.pdf
Initially I would guess the temperature sensor is bad.
However indicator light would flash 3 times.
And since both elements have a temperature sensor, it's unlikely that both would go bad at same time.
That suggests the Self-diagnostic Control Box located on top of heater is defective.
Turn off power at the circuit breaker and see if unit resets correctly.
Manual shows 1-877-817-6750 number for Whirlpool parts and warranty.
Your unit is still under warranty, so control box and other parts should be free.
Keep in mind this water heater requires 10 gauge wire and 30 amp breaker.
If you are running smaller wire or smaller breaker, that could affect long term operation of electronics.
I guess this requirement is so voltage drop from element turning ON doesn't starve electronics in control box
On the control panel, the Red and Black wires connect to 240V from circuit breaker.
Wires appear to pull out of socket using needle nose pliers. It will be important to keep wires in same order.
Take photo of your wiring before disconnecting anything.
To order parts, you must give serial number located on label on side of tank.
Serial number will identify your specific heater to person answering phone at Whirlpool.
Installation part should come with instructions, but ask the person at Whirlpool what steps they took during training. Whirlpool rep might have helpful tip they learned during training.
Add a comment and let me know about your transaction with Whirlpool so I can pass it along.
Dec 19, 2010 | Whirlpool Water Heaters
I have a atwood hot water heater GC6AA-10E its o...
Does yours have the little cut-out diode looking thing in the plastic jacket installed between power wire and thermostat? If yes, remove it from the circuit and connect female spade of wire, to male spade of thermostat,(just removing it to by-pass it) and try it now. Let me know what happens.
May 20, 2010 | RTO Atwood Water Heater - 6 Gal LP
Hot water wont get hot
1-First check for power to water heater and remove acces panels on heater to check power at thermostats. Thermostats have a reset button on them that trip and can be pressed to reset.
2- If none of the above have changed any thing and you have power you may have elements gone bad.
If an element is gone at top you will get scalding hot water then go to cold.
If an element on the bottom is gone you will get luke warm water then will get cold.
May 17, 2010 | Water Heaters
I am having the same problem as posted by jek01 on Aug 1, my Rheem Tankless Hot Water Heater is not powering off, after two years of use with no issues. I also have to turn the breaker off and wait a short...
Remove power source from the unit. If remote control2.gif is installed; remove cover and lift the control wires on the terminal...can be accomplished from either end.
Restore power and see if unit functions normally.
Contact Paloma/Rheem customer (800-432-8373) support and notify them IF you are getting a code "76" error. Rheem has recently extended the warranty on the "Burner Control Assm."; which is your problem. The C4-C8 portion of the error code, is where the unit stops the ignition process...burner fails to light, or gives you intermittent hot water. In either case, contact customer support2.gif.
If this helps, please indicate so.
Mike
jzklipper@aol.com
Oct 11, 2009 | Rheem Tankless Hot Water Heater...
GeoSpring Hybrid Water Heater Logo
177 people viewed this question
Top GE Water Heaters Experts
Steven's...
Steven's...
RSole
Gene Haynes
Are you a GE Water Heater Expert? Answer questions, earn points and help others
