My samsung N150 plus gives error 17. I installed
My samsung N150 plus gives error 17. I installed android x86 OS on and it gives me kernel panic so i restarted it maunelly and after the samsung logo the error comes. pls help me cuz am losing my brians.
  • 157 Answers
Your application is corrupt. You need to reinstall it.
Posted on Jul 25, 2013
  • 5 more comments
  • Sagabravo Jul 25, 2013
    But pls there is a windows 8 on n my documents is on so how can i recover them.
  • Hassel Lee
    Hassel Lee Jul 25, 2013
    You can recover it by updating the window. Remember do not new install it only update it.
    I made my pendrive bootable but still gives the error when i insert the pendrive to it.
    Thanks to u, my problem is aolces
    Solved my problem
    Solved my problem
  • Hassel Lee
    Hassel Lee Jul 26, 2013
    your welcome
4 Suggested Answers
clusterfx
  • 67 Answers
SOURCE: Will not reinstall
download, burn and run the bootable memtest cd or dvd, boot from it and it will run tests your RAM.
http://www.memtest.org/
I have run into similar problems with faulty ram.
Posted on Feb 23, 2008
  • 33 Answers
SOURCE: Error 17 when booting up Asus Eeepc 701sd
You should try to repair your windows. Which OS you are using...
Posted on Aug 30, 2009
  • 228 Answers
SOURCE: i want to install wireless
Hi deyab123,
Check out this link and see if you can find one compatible for your Operating System.
http://www.samsung.com/hk_en/consumer/computer-peripherals/notebook/netbook/NP-N150-KP01HK/index.idx?pagetype=prd_detail&tab=support
Just click the "Driver" tab beside the "Manual" tab and it should show available drivers. Choose the one compatible with the Operating System version that you are using.
Good luck.
Posted on May 10, 2011
What is the corrective action for a "kernel panic upload" pop up?
hi, sounds as though it is a corrective, maybe for a linux instal that is/has become unstable? maybe android
not certain.
see if link below provides any clues
good luck
Kernel Panic Upload Mode
Jun 16, 2014 | Samsung Galaxy Pocket
Crystalview xt
you need to reload your windows, cause it sounds like you have corrupt startup files, also check your hard drive for errors.
Mar 20, 2014 | Computers & Internet
Resolve Error Code: C7 on SuperMicro Server
First check the OS compatibility for you motherboard here:
http://www.supermicro.com/support/faqs/os.cfm
Then, if compatible, check the IDE/SATA setting. Change the hard drive controller settings from IDE to AHCI or vice versa to see if the OS kernel panics on boot. If that does not work, please reply with your OS version and motherboard model.
Apr 12, 2012 | SuperMicro Computers & Internet
Mac laptop screen froze with message stating must turn off laptop
font.f1 { font: 12px Helvetica; } Thanks for asking your question with Fixya Support. I will be glad to assist you.
What you are experiencing is what is called a Kernel Panic.
A Kernel Panic, is a internal fatal error, detected by your system from which it
cannot recover from safely. Such an error can be the result of a software
function or operation failing to execute as it normally does, or halting without
warning, or even a hardware component, suddenly ceasing to operating
or simply shutting down. In either scenario, the system will display the frozen
black and white screen with the languages text listed.
Normally a simple reboot of your Macbook Pro will resolve the issue, but in some cases it can take a specific procedure to correct and prevent a kernel panic from occurring again.
So here are a few procedures you can use to resolve and prevent further kernel panics:
• First, hold in your power button for approximately 10 seconds to do a hard shutdown, if your Macbook Pro is still turned on.
• Once your Mac is shutdown, you will need to perform what is called a PRAM reset (Parameter RAM)
• Locate the following keys on the keyboard: Command, Option, P, and R. You will need to hold these keys down simultaneously .
• Turn on the Macbook Pro.
• Press and hold the Command-Option-P-R keys. You must press this key combination before the gray screen appears.
• Now, hold the keys down until the computer restarts and you hear the start up sound for the third time.
• Release the keys and allow the Macbook Pro to start up.
If your Macbook Pro starts up normally and does not go into another kernel panic, then you should be able to resume normal session activity on your Macbook Pro.
However, should the kernel panic return, then you can use an SMC Reset to correct the kernel panic:
-SMC RESET-
The System Management Controller is an integrated circuit (computer chip) that is usually on the logic board of your Mac portable.
It is responsible for power management of the computer. It controls back-lighting, hard disk spin down, sleep and wake, some charging aspects, trackpad control, and some input/output as it relates to the computer sleeping.
Shut down the computer.
• Disconnect the MagSafe power adapter from the computer, if it's connected.
• Remove the battery.
• Press and hold the power button for 5 seconds.
• Release the power button.
• Reconnect the battery and MagSafe power adapter.
• Press the power button to turn on the computer.
Once again, when you are back up to your main desktop, resume your normal session activity.
At this point there should be no further issue a the kernel panic rearing its ugly head once again.
If it does, then you will need to take more intensive steps such as inserting your Mac OS X installation disc and booting up to that disc and running Mac OS X's Disk Utility, to repair the hard drive and permissions of the Mac OS X system you are using.
I will leave you with that procedure, in the event you need to run Disk Utility:
Insert your Mac OS X Startup disk
•Reboot your Mac
•At the Apple Chime, press the C key and hold it until you see a White screen, gray Apple and eventually a Spinning gear.
• Release the C key only after you see the Spinning gear.
•Mac will boot from the start up disk to the Installer environment
• From the Installer Menu bar, click Utilities > Disk Utility and open up Disk Utility application.
• Click on on the hard drive at the top of the window in the left sidebar and
• Select "Repair Disk"
**Let Disk Utilities run this repair the disk until completion
• At the end of this process, reboot your Macbook Pro
Return back to you main desktop and again, resume your normal session activities.
Any more kernel panics after this, you may want to consider taking your Macbook Pro in for service at your local Apple retail store Genius Bar or local Apple authorized service provide in your area.
I hope this information proves helpful for you.
Regards,
-Mactechtrainer
Mar 30, 2011 | Apple Mac Book Pro 15.4" 2.53 Core2Duo 4GB...
When i try to boot my ibook g4 it gets stuck on a blue screen or the mac logo and it brings up a sign saying to shut down or restart.. i do this but it does it all over again..
The sign i believe you are referring to is a Kernel Panic, if it is a gray box that dims the screen. Example: http://www.ourhangout.net/archives/Kernel_Panic-1p0f.png
If this is the case, and you have your Mac OS X install dvd, try to boot off of the disc and use disk utility to repair the hard drive.
Dec 18, 2010 | Apple iBook G4 Mac Notebook
Why my ibook cannot boot to desktop.but only stop at the grey apple display
What is happening is the mach kernel is hanging during bootup. This is likely caused by a kernel panic. Boot-time kernel panics are caused by the following things:
  1. A botched software update
  2. A badly behaving hardware device
  3. Flaky RAM memory.
  4. You are WAAAY too low on free disk space.
Insert Installer disk and Restart, holding down the "C" key until grey Apple appears.
Go to Installer menu (Panther and earlier) or Utilities menu (Tiger) and launch Disk Utility.
Select your HDD (manufacturer ID) in the left panel.
Select First Aid in the Main panel.
(Check S.M.A.R.T Status of HDD at the bottom of right panel, and report if it says anything but Verified)
Click Repair Disk on the bottom right.
If DU reports disk does not need repairs quit DU and restart.
If DU reports errors Repair again and again until DU reports disk is repaired.
If DU reports errors it cannot repair you will need to use a utility like Tech Tool Pro or Disk Warrior
If you can make it this far, it is likely that your hard disk and the majority of your computer hardware are functioning correctly and your issue is software related.
Here are the best methods to troubleshoot Mac OS X filesystem problems: http://support.apple.com/kb/ts1417
May 29, 2010 | Apple iBook G3 Mac Notebook
Apple mac g4 laptop wont come on
Kernel panics are not what you have, you have a flashing question mark, it indicates there is a problem with either the hard drive or the operating system on the hard drive.
Kernel panics are different, the unit tries to start and then the unit crashes with a "kernel panic"
Feb 19, 2009 | Apple PowerBook G4 Mac Notebook
MacBook Kernel Panic
To fix this problem, download and install Mac OS X 10.4.8 from - www.apple.com/support/downloads.
This should solve your problem.
Let me know how it went.
Aug 14, 2008 | Apple MacBook Mac Notebook
Not able to boot RHEL5.1
which ver of red hat is it? x86, etc?
Mar 31, 2008 | Intel D102GGC2 Motherboard
Computers & Internet Logo
253 people viewed this question
David Payne
David Payne
