How will i reset the lamp timer of an Acto projector?
5 Suggested Answers
SOURCE: Reset Lamp Hours Timer
This works on a couple different Toshiba models -- might work on yours...
Make sure the main power switch is OFF. Hold the "ON", "MENU", and "INPUT" buttons at the same time and turn the main power switch on. Keep them held until the yellow power standby light comes on, then let go. It is done.
Posted on Dec 06, 2007
SOURCE: Resetting the air filter timer
If you do not have a remote here is how to reset the filter time. Use the "Menu" bottun to get the "easy menu" to display. Push the down arrow until you get to "Filter Time," then push and hold the RIGHT arrow to reset the filter time. DO NOT try to reset using the "Reset" option on the easy menu, it will not work.
Posted on Oct 02, 2008
SOURCE: Lamp timer on Sharp XV-Z2000 will not reset
I unplug my cord, waited for 5 minutes, then reconnect cord holding the power button at same time, released, then proceded with input, left arrow, enter, right arrow and depress power button again holding for 15 seconds, then released. projector warmed up showing the  "0000H" on the bottom left of screen...that's how mine worked today.
Posted on Jan 10, 2009
  • 4 Answers
SOURCE: how to reset lamp timer on Pj458D
turn the projector on. open the menu. go to advanced. scroll down to the first option which should be auto source. make sure this option is checked. while on this option press right once, left twice, right 3 times, then left 4 times. another menu will appear. scroll to lamp time and push enter. this will take it back to zero.
Posted on Apr 01, 2010
How do I reset my nec projector model vt700 lamp time without remote
How to Reset a NEC Projector Lamp Timer ... - RelampIt
www.relampit.com/Projector-Lamp-Timer/NEC-Projector-Lamp.php
How to Reset a NEC Projector Lamp Timer. Make sure the projector is in standby mode; Press the Off or Help button on the remote control for a minimum of 10 ...
NEC reset lamp without remote Questions & Answers - Fixya
www.fixya.com/tags/reset_lamp_without_remote/browse/nec
My bulb warning had just recently appeared a few weeks prior, so I thought the bulbmust ... ...reset the Lamp timer o an NEC MT1050 projector. ... ...reset lamp usagetime without the remote on NEC VT490 HelloPress the MENU button on the ...
reset lamp hours nec projector without remote Questions ...
www.fixya.com > Forum > Tags
Find solutions to your reset lamp hours nec projector without remote question. ... My nec vt48 projector gets hot and turns off. It ... Question about VT700 Projector.
Replacing The Lamp - Nec VT700 User Manual [Page 58]
www.manualslib.com > ... > Projector > VT700 > User manual
Jan 29, 2016 | NEC Office Equipment & Supplies
Sharp projector timer unable to reset after replaced lamp.
Reset the lamp timer.
1,Connect the power cord.
2,While simultaneously holding down "menu","enter" and "down" on the projector, press "standby/On" on the projector and keep all four buttons pressed down until the lamp indicator starts blinking green.
"LAMP 0000H" is displayed, indicating that the lamp timer is reset.
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Mar 07, 2015 | Sharp XV-Z9000, XV-Z9000E, XV-Z9000U...
I am unable to reset the timer after replace projector lamp- there are no screen. How to reset the timer?
Have a nice day!
Jerry
Lampdeng Limited
Resetting the lamp timer on an infocus in24 projector
To reset the lamp timer on an in24 go to settings, then select Service. The option to reset lamp hours should be in this menu.
I hope this helps!
Projector Lamps Projector Bulbs Projector Parts Projector Repair Servcie
Jun 04, 2014 | InFocus Office Equipment & Supplies
Temp and lamp lights flashing
can you let the projector work well
if the projector projects the image,
does the projector light?
if the projector work well ,but the indicator lights flashing,that means the projector is ok ,
you only need to reset the timer of lamp and to reset the timer of the filter,
menu-setting-advance-reset-the timer of the lamp
menu-setting-advance-reset-the timer of the filter
Apr 28, 2014 | 3M S15i 165Watt 2000Hrs HSCR Projector...
How do i reset timer on marantz projector VP 4001
Hello
you want to set the Lamp timer after replacing the Lamp I thinks and posts this solution.
[1] Connect the power cord into the AC socket of the projector.
[2] To reset the Lamp timer; While simoultaneously hodking down "MENU, ENTERAND DOWNWARD Button" on the projector, press "POWER/ 'STANDBY/ON on the projector.
* "LAMP 0000H" is displayed indicating that the Lamp Timer is reset.
If you want anymore assistance from me, get me by FixYa. OK.
Sep 19, 2011 | Marantz VP4001 DLP Projector
How do you reset the lamp timer?
Here's how to reset the lamp timer:
- Press the Menu button
- Scroll down to the LAMP TIMER RESET option, then scroll right to enter
- Confirm that it is OK to reset the lamp timer by hitting the OK button.
- The on-screen menu should confirm the lamp was reset correctly
You should only reset it after you've changed the projector bulb.
Feb 03, 2011 | JVC TS-CL110UAA Projector Lamp
Need to reset lamp. replaced lamp and installed new lamp.
Press RESET, <, >, ENTER keys on remote within 5 seconds to reset lamp timer.
Jul 29, 2010 | Sony VPL-CX86 Multimedia Projector
Lamb will not reset
Reset The Lamp Timer.
While simultaneously holding down (+ . >) and AUTO SYNC on the projector, Press ( I ) ON and ( - . < ) on the projector.
NOTE..... Make sure only to reset the lamp timer only when replacing the lamp. If you reset the lamp timer and continue to use the same lamp, this may cause the lamp tp become damaged or explode...
Sinista
Mar 18, 2008 | Sharp Notevision PG-B10S Multimedia...
Lamp replacement
Hi there
You need to reset the lamp timer.
Mar 11, 2008 | 3M (EP7640ILK) Projector Lamp for MP7640
124 people viewed this question
k24674
jasbo
jasbo
