Question about Crafts & Hobbies
Sakura av5023 SAKURA AV-5023 right channel no output. tried swapping Left and Right wires but right still not working.
jack_daniels
  • 304 Answers
SOURCE: No Sound in Right Front Speaker- Denon AVR-1508
hi there,
have you check the system settings for each of the speaker..? should be set and balance all output of the speaker
`jack
Posted on May 24, 2008
mrwtech
  • 59 Answers
SOURCE: How do I connect a Polkaudio powered subwoofer (psw 125)
Connect a set of stereo RCA cables from the 'Output 2' on the Hafler to the line imputs on the Sub.Turn on the '1+2' output switch on the Hafler and rock out!
Posted on Dec 17, 2008
  • 4234 Answers
SOURCE: fuzzy sound from right front speaker output
The main issue is to determine where the distortion is coming from. Does it start in the front and and get amplified or does it appear in the output section only? This will require a fixed signal and an oscilloscope to trace. Check for leaky coupling caps or leaky transistors in at the diff-amp section.
Dan
Posted on Feb 02, 2009
SOURCE: electric bike cuts out while riding
Couple possibilites. If it is just a matter of your battery clips coming undone, tighten the with pair of pliers then reattach. If it cuts out, then reengages when you start pedaling, either your controler is shot, or you have a ground short on your wheel hub. How long does a charge hold, and how often does it cut out?
Posted on May 03, 2009
  • 182 Answers
SOURCE: wiring the scosche fai-3a to a pioneer two channel amp
the 2 left and right dont matter, it only matters when ur hooking up a 4 channel amp.
all u do is connect one of the channels to it but it would be best o buy a stereo ull have alot of engine nose and vibration on ur speakers and a thump every time u turn on ur car but itll sound ok for now ti
Posted on Jul 07, 2009
Where can I buy spare light bulbs for my Sakura scooter type bike
Hi, Hendrik any motorcycle/scooter shop will have spare bulbs or check with Amazon.com for more information about your question and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Electric Scooter and Bicycle Troubleshooting Guide
Sakura scooter thing
Question Answer
Jun 04, 2016 | Motorcycles
In my JVC RX 8SD only works a channel. How do I repair this defect?
Start with the simple things.
  • Check left right balance
  • Swap output speakers left to right
  • Swap the speakers at the receiver to make sure no wire open/short
  • Swap input RCA cables left to right red/white - white/red
Ok No JOY!
JVC has thermal overload circuits/overload on most of there Amps.
Remove power for a minute or two to see if there is a reset.
Rewire speaker connections to speaker set 2.
Connect REC out to Rec In swap cables and see if problem is in pre-amp or power amp.
Check internal fuses.
Jan 19, 2016 | JVC Audio Players & Recorders
Pioneer DEH-P47DH Front left speaker not working, if i press audio button, i get no option to adjust balance, just fader. left rear speaker works and plays as loudly as right rear speaker. Huh? bad...
Are you sure you wired up the head unit correctly? It is fairly uncommon for a audio output amplifier to blow out leaving 3 working speakers and 1 not working. So more than likely it is bad wiring or a blown speaker. Best bet would be get a digital multimeter and ohm out the speaker and see if it has continuity and is the same as the adjacent speaker. You could also try swapping the left/right channel wiring and see if the front right speaker stops working when connected to the left speaker output or vice versa.
Nov 12, 2013 | Car Audio & Video
Sakura electric bike .Red and blue cable broken off right hand brake lever. Can I open it and re-solder?
I once spent 2 years and many attempts to solder a VW Bus throttle cable, finally had to get 2 cable clamps and a short piece of wire, fixed it in about 6 min and it never failed again.
Feb 02, 2013 | Cycling
I have a sakura s200 electric bike can i make it any faster ?
Change out the gears with a higher ratio that turns the wheels faster for the same motor RPM. Another method is find a motor that has a higher rpm capability.
Aug 23, 2012 | Electric Bicycle Motor, Bike,electric...
I have Sakura kitchen range hood model #c R706, R727 and Want to know how ro chaneg teh bulb. Thanks
I found all the part I needed for my Sakura range hood at http://www.rangehoodking.com/ they had everything I needed. of cos that light bulb too!
Dec 31, 2010 | Kitchen Ranges
Hi, Toroidal transformer in Sakura AV-200T input is 220v I need 110v Thanks
Hello shole135, Hi, you need a 110v to 220v step-up transformer with 200 watts power specification. you can visit your local hardware store and find one. Don't replace the toroidal transformer.
Dec 02, 2010 | Audio Players & Recorders
Sakura S305 electric bike, no speed control
I'm not familiar with that make/model, but if it has a brushed motor then it is likely that you have a faulty controller module. Most brushed motors have just 2 wires running to them from the controller.
Feb 04, 2010 | Electric Bicycle Motor, Bike,electric...
No Right Front Speaker Output
Swap speakers over...check the balance isn't fully to the other channel...swap left/right phono cables over (if thats how your using it) other than that i would say is broke.
Easy way to check speaker cable/speaker... touch a small battery (like used in a remote) across speaker wires, you will hear and see the speaker cone move.
Aug 07, 2009 | Audio Players & Recorders
Crafts & Hobbies Logo
102 people viewed this question
Top Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
ray gallant
Are you a Craft and Hobby Expert? Answer questions, earn points and help others
