How to reset the lamp hours of an Acto Projector?
5 Suggested Answers
SOURCE: Reset Lamp Hours Timer
This works on a couple different Toshiba models -- might work on yours...
Make sure the main power switch is OFF. Hold the "ON", "MENU", and "INPUT" buttons at the same time and turn the main power switch on. Keep them held until the yellow power standby light comes on, then let go. It is done.
Posted on Dec 06, 2007
SOURCE: lg llp xg22 lamp reset
These instructions are taken from page 44 of the User Guide.
Turn the power off but keep pluged in. Press the buttons on the control panel in the sequence as below.
Press "Up Arrow", Press "Down Arrow", Press "Left Arrow", Press "Right Arrow", Press "Menu", Press "Enter".
Lamp time will be initialized
Posted on Mar 01, 2008
Marrie
  • 563 Answers
SOURCE: RESET LAMP HOURS
Hi Greg147
The resetting is not done in the menu.
Plug in your power cable - Machine is now in standby mode.
Then Hold down the left and right arrow keys on the Projector and press the power button. You'll see a indicator light on top of the Projector flashing twice - Lamp hours is now reset.
Hope this is of help.
Posted on Apr 01, 2008
SOURCE: Panasonic projector PT-L78 lamp reset
Press the MENU button. Use the < > arrows to get to the OPTION menu. Press the ENTER button. Select LAMP RUN TIME. Press and hold the ENTER button for about 3 seconds. The 'lamp time reset' will display. Press OK and press the ENTER button. This will reset the lamp hours as well as turn off the projector.
Posted on Feb 25, 2009
How do I reset my nec projector model vt700 lamp time without remote
How to Reset a NEC Projector Lamp Timer ... - RelampIt
www.relampit.com/Projector-Lamp-Timer/NEC-Projector-Lamp.php
How to Reset a NEC Projector Lamp Timer. Make sure the projector is in standby mode; Press the Off or Help button on the remote control for a minimum of 10 ...
NEC reset lamp without remote Questions & Answers - Fixya
www.fixya.com/tags/reset_lamp_without_remote/browse/nec
My bulb warning had just recently appeared a few weeks prior, so I thought the bulbmust ... ...reset the Lamp timer o an NEC MT1050 projector. ... ...reset lamp usagetime without the remote on NEC VT490 HelloPress the MENU button on the ...
reset lamp hours nec projector without remote Questions ...
www.fixya.com > Forum > Tags
Find solutions to your reset lamp hours nec projector without remote question. ... My nec vt48 projector gets hot and turns off. It ... Question about VT700 Projector.
Replacing The Lamp - Nec VT700 User Manual [Page 58]
www.manualslib.com > ... > Projector > VT700 > User manual
Jan 29, 2016 | NEC Office Equipment & Supplies
I replaced the lamp on my XGC55X Sharp Projector and it worked great for 2 nights (roughly 6 hours). Now it goes to warm up, with the lamp light blinking, and will power down with the status button showing...
Have reset the lamp hours after installing the new lamp? If, not the projector has treated the new lamp as old lamp & refusing to light further. So, reset the lamp hours to zero. To reset the lamp timer do as follows. Plug the power cord into the AC socket of the projector. Switch ON the power of the socket. (not projector) While pressing simultaneously INPUT, ENTER & UNDO on the projector, press ON on the projector. "LAMP 100%" is displayed, indicating that the lamp timer is reset.
If this does not correct your problem then the problem lies in other area. Let me know so that further I can provide you solution. Above things are preliminary
Aug 06, 2011 | Sharp XG-C55X Multimedia Projector
My lamp light is yellow green? what could be the cause?
hi ,
Do one thing just reset the lamp hour of your projector. For resetting the lamp hour do the following.
While simultaneously holding down the Right arrow ( >) button and Auto sync button on the projector press Power ON button and Left arrow ( button . The lamp hour will indicate zero.
If doesn't work you have to replace the lamp.
Remember on thing Lamp hour reset is recommended only after the lamp replaced. so try to replace the lamp if it work after the resetting procedure.
ok
Mar 27, 2011 | Sharp Notevision PG-B10S Multimedia...
Will not coming on ,standby light is orange temp and lamp light not on
hi,
Just try to reset the lamp hour of your projector. For resetting the projector do the following.
While simultaneously holding down MENU/HELP, ENTER and Down arrow button on the projector, Press STANDBY/ON on the projector.
Remember one thing lamp hour reset is recommended only after the lamp replaced. Before going to buy a new lamp just reset the lamp hour and confirm that the projector doesn't have any other problem.
If these doesn't help then check the lamp of you projector chances for lamp became faulty.
ok
Mar 19, 2011 | Sharp XR-10SL DLP Projector
Please forward the details how to fix hour settings in the system when the time to lamp replacement in 8785 model of 3M.
hi,
.To display the total lamp hours, press and hold for 3 seconds, the Reset button on the projector or
Timer button on the remote control.
.To reset the lamp timer, press the Reset button on the projector or Menu On button on the remote
while the total lamp hours are displayed. Use the arrow button on the projector to
select 0 (or CANCEL).
ok
Mar 08, 2011 | 3M (78-6969-8778-9) Projector Lamp for...
Need to reset lamp. replaced lamp and installed new lamp.
Press RESET, <, >, ENTER keys on remote within 5 seconds to reset lamp timer.
Jul 29, 2010 | Sony VPL-CX86 Multimedia Projector
Cannot Reset Infocus LP 350 Projector after replacing a bad lamp
that model has a history of bad ballasts. you'll need to replace it.
Mar 03, 2010 | InFocus LP350 Multimedia Projector
Toshiba Projector TLP 651 lamp problem
yes resetting the lamp hour might be the issue but not necessarily. It could also be a temperature issue as the fan (s) might have stopped or a temp sensor issue is faulty. check your manual for resetting lamp hours. Regards Kevin Andreassend www.iceav.co.nz iceavtech@gmail.com
Oct 28, 2008 | Toshiba TLP450, TLP451, TLP650, TLP651,...
Lamp replacement
Hi there
You need to reset the lamp timer.
Mar 11, 2008 | 3M (EP7640ILK) Projector Lamp for MP7640
83 people viewed this question
k24674
jasbo
jasbo
