My foxin home theater output left jack did not work
    Top Expert:
  • 12,223 Answers
Restore to the factory defaul, go to the MENU
However you must test the left jack for dirty, or wires broken or faulty.
clean with contacts cleaner.
God bless you
Posted on Jul 25, 2013
2 Suggested Answers
SOURCE: No Audio Out through the Optical OUT jack
just press the DVD button on the remote contol and you will be ok.. :)
Posted on Aug 31, 2008
Connecting a sound bar
Typically you will connect the RCA audio output jacks to the audio input jacks on the sound bar, but if your television does not have RCA audio output, you may have to buy additional hardware to make the soundbar work. If your TV has a headphone jack, then you will need to purchase an 1/8" Headphone connector to RCA Connector cable from a local electronics or audio store. If your TV doens't have any audio outputs, you may need to purchase a digital tuner box and connect it to your TV and soundbar.
Jul 19, 2014 | Sharp home theater system HT-SB300 User...
I can not get my RCA Blu Ray home theater to play what comes through on regular tv. It plays a dvd and will also play when using netflix from my ps3. I do not have any sort of cable box. My tv is a Sa
Gotta find an audio output from the TV and run it to aux input on the home theatre, select the aux function and it should work, if your tv has no audio out see if it has a headphone jack you can use as an audio out, can get a cable with 3.5mm headphone jack one 1 end and rCA red/white on the other, becareful when doin this as the audio output level froma headphone jack maybe controlled by the tV's volume itself. keep tV volume low and use the home theatre volume if your doing it that way
Nov 24, 2013 | RCA Blu-ray Home Theater With Vudu,...
HOW DO YOU GET TV AUDIO TO MY HOME THEATER?
For analog audio output use the L (White) and R (Red) RCA/Phono coax jacks to output to your Home Theater. Other option is to use the headphone jack wired to the home theater, however use of this will switch off any sound coming from the TV.
If the Home Theater supports digital inputs, use one of these connectors, Orange/Black RCA jacks, Toslink (Optical), HDMI. For nice pictures do a search for images in google/yahoo with the connector type.
So basically look for output connectors on the TV and match it with the same type of connector on you Home Theater input.
Jan 15, 2011 | LG 47LE5400 47 in. TV
I have bought a 5.1 home theater with an av receiver and i want it connect to my computer. So how should i connect it ?
Just find the output of the computer's sound card and it should have a microphone style female connector that you plug a male connector into. The other end should have rca phono jacks that can accept stereo or left and right 2.1 connections. If you want 5.1 home theater from this signal, it may be possible or may not be possible depending on the input of the 5.1 home theater system.
Aug 19, 2010 | Computers & Internet
Connect Altec Lansing ADA745 to HD TV RCA output for home theater
It won't work like this due to this being a computer only speaker system. It requires the drivers to work with a computer & a Home theater does not recognize the format. Sorry.
Feb 25, 2009 | Altec Lansing Multimedia Computer Speakers
Can't get surround sound for tv shows
The coby dvd 988 has 2 rca audio input jacks, you need to have these connected to your TV AUDIO OUT jacks, these are usually colored red and white like right and left stereo jacks, be sure to set up the TV for AUDIO output through these connections, some tv`s require that the internal built in speakers are cancelled and the audio output jacks are enabled. Set the coby input signal to receive the port you pluged the tv signal into.
Feb 06, 2009 | Coby DVD-988 Theater System
Instalation
You need to check the back of your home theater for an input jack (it could be labeled tv in or aux in). Then check your tv for audio out jacks. Use a quality rca patch cable from the tv to the home theater. The tv may need to be switched from variable to fixed audio out on the audio menu of the tv. If it is an older or inexpensive tv in may not have the output capabilities.
Jan 11, 2009 | Panasonic Home Theater System System
Wireless headphone connection to multiple components?
Cat,    Splitting an optical output is not recommended.  In fact it would require an optical patch bay, which would be overkill. You could use the headphone output on the front of the Denon AVR3805.    Because this output is behind a door it might be a cleaner looking set up to use the optical output on the top left looking at the back of the unit.  Because those two optical outputs are labeled "optical 3 and 4" they are zone outputs, they should work without having to "map" or patch them internally. The outputs here will be controlled independently as zones from the receiver's remote.      The easiest option looks to be the analog "pre output" located in the middle of the back of the receiver.  The left-most two rca jacks you want to use are labeled "front" and are white over red.  This output will work fine.  Control of the volume will be from the headphone unit and not the receiver.
Jan 07, 2009 | Audio Players & Recorders
Wiring with a sattelite receiver and new Samsung TV
Nope RamaTheMan - you are incorrect! No way to get an actual surroundsound from your TV on this turd - this came straight from the Samsung FAQ -
"You cannot get surround sound from your television. On the other hand, if your television has audio output jacks you can connect your TV or Set Top Box to your Home Theater System and get stereo sound (that is, sound from the left and right speakers of your Home Theater System only).
To connect your TV or STB audio output jacks to your Home Theater System and get stereo sound, follow these steps:
  1. Turn off your TV and Home Theater System.
  2. Connect the Audio Out jacks on your TV to the External Audio Input jacks on the back of your Home Theater System. The External Audio Input connectors are typically labeled AUX IN. Note: There are usually two pairs of Audio Input jacks, AUX 1 and AUX 2. Each pair has a jack for the left audio input and the right audio input. Often, there are two Video AUX IN jacks as well. You can plug the audio cables into either audio AUX 1 or AUX 2. See the following diagram.
  1. Turn on your TV and Home Theater System.
  2. Press the Function Button on the front panel of your Home Theater System until the display on your Home Theater System shows AUX 1 or AUX 2.
For advanced installation, if you are using a High Def STB, you can connect an OPTICAL connection from the STB to the HTS. This is a specified cable that must be purchased separately.
In either instance, you must then set the HTS to its auxiliary input. (i.e AUX 1, AUX 2, DIGITAL IN) in order to get the sound from the HTS.
Note: If your television does not have Audio Out jacks, you may be able to get stereo sound by attaching the Audio Out jacks on your VCR to either the AUX 1 or AUX 2 audio inputs on your Home Theater System. If you attach your VCR to AUX 1 or AUX 2, you will have to tune your television to channel 3 or 4, and then tune to the station you want to watch on your VCR."
Dec 26, 2007 | Samsung HT-X50 System
12 people viewed this question
 Grubhead
Grubhead
