Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
Hotpoint Aquarius WMF760 washing machine. No water.No spin.
Last wash machine worked fine. Today it is not taking in any water. The H20 code flashed up.I have switdhed it off waited 10 mins & tried again, same result. I have also tried the spin cycle & that is not working either. Any help greatly appreciated.
  • 209 Answers
SOURCE: HOTPOINT AQUARIUS WF250 1500 SPIN
check the cold water supply, either from the mains pipe, there is no water getting into the machine, if water is there up to the machine check the solenoid for circuit, to do this unplug from electric, remove lid, and test the two wires on relevant solenoid, no circuit means faulty solenoid, (test with the 2 wires removed from solenoid) take care note position of wires to put back properly answer above based on info given
Posted on Sep 27, 2007
  • 121 Answers
SOURCE: My washing machine has stopped spinning.
it sound like your belt has come off if not wait till its dark put it on spin turn the light off if you can see flashes coming from under the machine it your brushes that need replaced on the motor
Posted on Mar 03, 2008
beltronic205
  • 1467 Answers
SOURCE: Hotpoint Aquarius WF560, goes through cycle wash
Could need new motor brush kit>
Posted on Oct 06, 2009
active209
  • 14 Answers
SOURCE: hotpoint aquarius wf340g will wash put wont spin
check solaniod valve on water pump
Posted on Nov 06, 2009
SOURCE: Noisy when spinning
bearing gone cheaper to buy a new one
Posted on Jan 23, 2010
Problem with a hotpoint wmf760 aquarius + error code h20 coming up
You may have soap & grease in the pipe that leads to the pressure switch. Remove and flush through and/or replace. dry before refitting.
Thus constant high would give pump faults (thinks machine still contains water). Constant low may cause over filling. If you have a plug that suddenly moves, that can cause the above errors.
Jan 02, 2013 | Hotpoint Ultima WF860 Front Load Washer
What is code H20 on hotpoint washing machine
Check to make sure that the water valves are open and water is getting to the machine.
May 29, 2012 | Hotpoint Washing Machines
H20 is flashing on my hotpoint washing machine
H20 indicates a problem with water supply.
Check the inlet hose/s for blockage or restriction, make sure the water supply is o/k, and the pressure is good, also check the inlet valve/s filters.
Apr 02, 2011 | Hotpoint Aquarius WD640 Front Load...
My machine is flashing h20
H20 indicates a water supply problem.
Could be frozen pipe, check the hose/s for kinks or restriction, and that you are getting water at the inlet valve/s, and that the water pressure is o/k
Dec 18, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
H20 ERROR SPIN DRYING
The error indicates a problem with the incoming water supply.
Check for restricted or kinked inlet hose/s, check that tap/s are fully turned on and that you have adequate water pressure.
Mar 27, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
My hotpoint aquarius washing machine wd 640 is showing the fault h2o
The code h20 indicates means (not filling)
check the tap/s, hoses, and water inlet valve/s.
Please leave feedback.
Thanks.
Nov 12, 2009 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius Wf740 F-08 just before rinse and spin.
Hi my Hotpoint WF740 keeps flashin H20. Does anyone know why please?
Jan 15, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint
Here is the link to you washer. unfortunatly i can not find the error code you are seeing. you can contact them and have them let you know what the code means and what to do to fix it.
you will need to copy and paste this into your browser.
http://www.hotpoint.co.uk/macro/product.d2w/report?typeref=&prnbr=WD640
please do not forget to rate and comment about your experience with fixya today.
Aug 18, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
64 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
