Question about Sony KP-53V35 53" Rear Projection Television
Picture adjustment best settings
What are the best picture settings for Samsung UN39EH5003FXZA?
Your eyes are normally the best indicators to how a picture will look; just adjust the color and tint so that the people's faces reflect how they look in real life, and do not adjust the picture while a commercial is airing.
Oct 21, 2014 | Televison & Video
I want to know best picture settings for my panasonic TC-58LE64 LED VIERA SMART TV
Select the default picture settings first. Then adjust the color according to your taste. It will be the best picture.
Sep 07, 2013 | Panasonic Viera TH-42PX80U Plasma TV
Sony kdl55nx720 picture settings
Your are the one that knowing the best settings for your TV..To adjust the picture make it sure that all colors are appear like RGB red,green,blue on your screen to easily set the best picture,,..
Dec 28, 2011 | Sony Televison & Video
The best picture setting
First adjust the contrast & then brightness in such a manner that there just picture detailing. Adjust these controls especially on hair details of the person in the picture. The adjustment should be soft on eyes. Colour shall be adjusted for colour of an Indian should look. If your TV has ambiance sensor, then there is no need to change the settings in day & night.
sonsunny
Jun 24, 2011 | Televison & Video
I purchased 42" LG Plasma TV and i need to know
There is quite a lot you can do. Go to menu, picture settings and select user 1. From here you can adjust everything from colour to contrast to warmth to sharpness. The best thing to do is to switch to XD manual adjustment and make sure the mpeg noise reduction is set to max. This removes artifacts and gives a better picture. Oddly, connecting via SCART rather than HDMI will give a more watchable picture if the HD broadcast is't at a very high bit-rate.
Dec 29, 2010 | LG 42LC2D 42 in. LCD HDTV
What is and how do i adjust the white balnceon my fujitsu S550 digital camers?
Adjustment is in the menu screen, you shouldn't have to go very deep as it is a frequently adjusted setting.
White Balance is how the camera interprets white depending on ambient lighting. Have you ever noticed how when you are taking pictures inside at night and all of the light comes from lamps and the flash that your pictures have a yellow look? Take a picture under flourescent lamps and the pictures look different as well? How about outside? Best true color rendition on the picture taken outside, but different than the others.
White balance is a way for the photographer to adjust the tone of the picture to accurately reproduce the true colors seen in real life in the picture. Most cameras have an automatic white balance and they usually work fairly well. But for the best results, set it manually. Your whites will be white and skin tones appear accurate.
Hope this helps! Good Luck!
Oct 06, 2009 | Fujitsu Cameras
Need best picture settings for tv, films and video games
Those are pre-sets. I would adjust your set the way you like to watch it. Don't use the pre-sets. Some sets will let you change the pre-set controls and others not. If your can, then adjust it the way you like it then save it as personal settings.
Apr 15, 2009 | Televison & Video
Hi, I have just purchased the Samsung LE37A559 tv. I have been trying to get the best colour settings brightness colour contrast tint backlight etc. Is there a optimum setting for all of these ? I am...
The problem is that everyone has a different "taste" when it comes to these settings. I like to turn the color all the way down to start with. You should (if the set is factory adjusted correctly) have a black and white picture. If it's not B&W, then there's something inside the set that needs adjusted and you should get a service call. Then I adjust brightness and contrast to get the best B&W picture. Then I turn the color up until I'm happy with the color level, then I adust tint.
Hope that helps
Geno
Jul 29, 2008 | Samsung Televison & Video
42" LCD TV HD
do the auto adjust image . for this there is a button on the lcd screens
Jul 04, 2008 | Computers & Internet
Green tint I can't seem to fix
Hopefully someone on here has a manual and can tell you exactly where the tint controls are. Also need to try adjusting the color level, turn it clear down so you have a black and white picture.
Is the picture still green over the screen with the color control
set clear down to black and white? If it does, you might
have an issue with the green gun going out or problem in the
circuitry to it.
By the way, the best way to adjust the picture settings on a
tv are to first turn the color control clear down, then adjust
brightness and contrast for best black and white picture, then
bring up the color level to where it should be and adjust the
tint for best red/green ratio.
May 20, 2008 | Mitsubishi CS-27205 TV
Televison & Video Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
