Question about Cameras
Nikon d5000 troubleshooting
When I switch off my camera, the only way it'll start up again is by taking out th battery and putting it back in.
jackboy
  • 2985 Answers
SOURCE: my nikon d70 won't turn on and the battery if fully charged
The black spot i suspect was the CCD or processor failing. Checkout Nikon customer support re this.
Posted on Aug 05, 2007
  • 111 Answers
SOURCE: Nikon 18-55mm AF-S/ VR lense shudder?
I believe you're hearing the VR in the lens adjusting. Try turning the VR off and see if you hear the sound. If not, then you have a normal operating lens.
Posted on Sep 18, 2009
  • 102366 Answers
SOURCE: How do I adjust the aperture on the Nikon D5000
It depends on the exposure mode.
In Program mode (P), turn the command dial and the camera will shift the exposure by changing both the aperture and the shutter speed.
In Aperture-priority mode (A), turn the command dial and the camera will adjust the shutter speed to suit.
In Manual mode (M), hold the aperture button and turn the command dial.
If you're using a lens with an aperture ring, turn it to its smallest aperture (largest f/number) and lock it.
Posted on Feb 17, 2010
  • 102366 Answers
SOURCE: how can i get pictures from nikon d5000 camera?
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use Nikon Transfer, or any other photo cataloging program.
Posted on Jul 05, 2010
SOURCE: nikon d60 - error. turn camera off and on again.
Locate the button behind the shutter release button with the green dot next to it. Locate the button at the back lower hand side of the D60 with the green dot next to it. Press both buttons at the same time.........This resets the D60 to its original settings and should resolve the problem.....
Posted on Jul 19, 2010
Nikon D5000 completely dead--put in brand new fully charged battery and nothing
Have you tries cleaning the battery and camera terminals with some isopropyl alcohol and a qtip?
Aug 12, 2013 | Nikon D5000 Digital Camera
Oops i put d3000 and meant to put D5000. I dropped my camera and cannot view images on screen anymore. I can look at them via the computer, so camera still works just can't view.
Do you see anything at all on the screen? For example, if you press the MENU button, do you see the menu? If you press the playback button, do you see the pictures you've already taken?
Jan 21, 2013 | Nikon D5000 Digital Camera
DOES SIGMA 70-210MM UC MF FIT AND USABLE ON NIKON D5000
Sigma makes lenses for a variety of cameras. If the lens has Nikon mount then it will fit onto the D5000. However, it's a manual focus lens so naturally you won't get autofocus. The lens also lacks the electronics to communicate with the camera, so you will get no help from the camera's exposure meter and you'll have to shoot in Manual exposure mode.
Jul 03, 2011 | Cameras
I have a D5000 camera w/ kit lens VR 55-200, less than a year old. Recently and only occasionally what is happening is when I press the shutter release button, the lens won't focus, it won't move...
Your camera is still under the one year Nikon warranty. Call Nikon's repair depot at 1-800-NIKON-US (1-800-645-6687) 9AM-8PM EST, Monday to Friday. They will verify your warranty and assist you in returning it for repair.
Jun 08, 2011 | Nikon D5000 Digital Camera
Nikon d5000 control buttons not functioning. Reset button pressed & reset clock display appears but cannot use any controls.If I reset again with camera on, I get back to display of photo but cannot...
Just found this on the Nikon support website:-
My D5000 does not seem to respond to controls. Can I reset the camera?
In extremely rare instances, unusual characters may appear in the monitor and the camera may stop functioning. In most cases, this phenomenon is caused by a strong external static charge. Turn the camera off, remove and reinsert the battery, taking care to avoid burns, and turn the camera on again, or if you are using an AC adapter (available separately), disconnect and reconnect the adapter and turn the camera on again.
If the problem persists, turn the camera off, open the memory card slot cover, and using a paper clip, gently press the reset button by the memory card slot. ( NOTE: This will also reset the camera clock. Also note that disconnecting the power source or pressing the reset button may result in loss of any data not recorded to the memory card at the time the problem occurred. Data already recorded to the card will not be affected. In the event of continued malfunction, contact your retailer or Nikon-authorized service representative.
There's more info here:- http://support.nikonusa.com/app/answers/list/p/19
Just type D5000 in the search box
Apr 24, 2011 | Cameras
When i turn on my nikon d5000 and set it on manual the monitor turn blue. i dont know what happen i might change the setting accidentally and i cant bring it back to its original setting, i cant see the...
You should still be able to see the aperture through the regular viewfinder. When you say 'blue', you mean the whole thing is just blue? No writing? If that is the case, try a fully charged battery, full reset and if no change, I hope it's still under warranty. Get it to a Nikon service point.
Apr 22, 2011 | Nikon D5000 Digital Camera
How do i use the burst mode on my nikon coolpix s6000?
For Nikon s6000 (altho this question is posted in D5000 section)
Hope you have read the instruction manual by now. In Auto mode, go through the menu to get the shooting mode - there are I think 2 different continous shooting modes for your camera - one standard and one sport (2 others but they either select the best shot of serveral or combine them to make the best shot). Pretty impressive. Don't look in the manual for 'burst' mode, it's called 'continuous'.
For D5000, menu and again shooting options.
Feb 24, 2011 | Nikon D5000 Digital Camera
How to set timer in Nikon D5000
there will be a timer buttton on the camera. in the menu you can select how long it will take before taking a picture . it should be stated in the manual
http://www.kenrockwell.com/nikon/d5000/users-guide/menus-custom-timers.htm#c3
Apr 30, 2010 | Nikon D5000 Digital Camera
My nikon d5000 just wont start.. i switch it on and on again but still no responce..i've reinserted the batery but still nothing happen..some said the on/off button on d5000 are always problem..
There has been a Service Advisory issued by Nikon for this problem. The page for full information is below:
http://www.nikonusa.com/Service-And-Support/Service-Advisories/D5000-Service-Advisory.page
Sep 21, 2009 | Nikon D5000 Body Only Digital Camera
Cameras Logo
71 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
