Question about Refrigerators
Problems fridge freezer logik
Ice building up at the back of fridge of fridge freezer Logik LFC55s13
  • 57 Answers
SOURCE: Back of Fridge icing up
If the fan is running you more than likely have a defrost problem.
look at the back wall of the freezer section if it is frosted up. it's not defrosting.
There three components in this system. The defrost heater, the defrost termination stat., and the defrost timer. Newer refrigerators do not have a timer per say it is build into a electronic board usually mounted on the back of the refrigerator under a metal plate. The termination stat is the cheapest part @ $ 25.00. The heater should run @ 50.00 to 70.00. The board could be as much as 200.00 or more. If the refrigerator is over 10 years old you may wish to look into getting a replacement. Appliances are designed to start failing after 10 years old.
My opinion.
If you unplug the refrigerator let it defrost then plug it back in. it will work properly about 3 days before it frosts back up.
Posted on May 18, 2008
Maytag317
  • 1136 Answers
SOURCE: water dripping from freezer onto top shelf of fridge with ice buildup back of freezer
Hi, What brand/model# is this unit? I can help
Posted on May 23, 2009
Maytag317
  • 1136 Answers
Hi, I can help you. The drain is plugged in the freezer section. Could I get the model #?
Some models need an after market drain heat strip added.
Please let me know and I can get you through tis.
Thanks
Vic
Posted on May 30, 2009
Sea Breeze
  • 4654 Answers
SOURCE: Freezer cold- Fridge not. Ice build up on freezer
I really believe your adaptive defrost located inside the fresh food compartment and inside the control panel is defective. It puts your refrigerator on a timely defrost and if defective this problem you listed in your post happens. Yes we may need to also check the defrost heater and defrost thermostat but with my experience with that type of Adaptive Defrost Control is famous for its failure.
ADAPTIVE DEFROST CONTROL Part Number 61005988 You can find it located on two of my websites. Some models like yours came with a Defrost Timer. We will need just look inside the control panel and see for sure. Here is a photo of the Adaptive defrost. If you should need to contact me please send an email or try to answer here. Problem is I don't get notifications when someone comments. appliancepartsouteast@live.com
Please rate and ask me as much as you like. Thank You, Sea Breeze
Part 61005988
http://appliancepartseast.blogspot.com/
http://servicepartstec.blogspot.com/
Posted on Aug 10, 2009
  • 66 Answers
SOURCE: Build up of ice on bottom of LG fridge freezer
water drain clogged !
see this page for a fix, it might suggest a fix to your frig a s well
Avi
Posted on Jan 13, 2011
We keep getting lots of ice accumulating at the bottom of our freezer. Any ideas?
Probably a plugged drain line or plugged drain pan opening. This drain pan is located under the cooling coil (evaporator). When the unit defrost itself, the water is carried away via this pan and drain line.
Mar 02, 2015 | Logik LFC55W13 White 200 l Fridge Freezer...
Can my logik fridge freezer go in my garage attached to the house
As long as the temp in the garage doesn't get too high like in the 90s or too low like the 40s, then it should be ok.
Feb 15, 2015 | Refrigerators
Hi we got our logik fridge freezer yester day and
On any refrigerator or freezer, heat from the inside of the box is removed to the outside by means of the refrigerant in the system. This refrigerant is carried through copper or steel tubing which is attached to the cabinet of the unit. This facilitates dispersion of the heat that has been removed from the inside. In other words, it is normal operation.
Oct 01, 2014 | Refrigerators
My logik freezer wont freeze
Hi, the motor (compressor) is not working, or the gas is not circulating properly due to a blocked choke ( A much thicker short section of the piping housed at the back of the body) or the gas is leaking out, probably by now there is no more gas in the pipes. But first check to see and hear if the motor is working when switched on.If the motor does run, then it is definitely a gas circulation problem due to the two mentioned above facts. Only the repair man can help in any one of these circumstances
If there is a gas leak, then you will have to buy a new freezer.as present day modern freezers are too labor intensive to strip down to access the piping in order to repair an internal leak. If the leak is external then it is easily repairable.
Hope i have been of help
Good luck
Sep 10, 2014 | Logik LFC55W13 White 200 l Fridge Freezer...
Logik fan motor repairs
go google.com or ask.com or yahoo.com or bing.com
in the search box type " logik fans customer service website"
also type another search " logik factory service website"
and another "logik fan motor repair shops in your city or your state "
Oct 10, 2013 | Dryers
Logik refrigerator lfc50s10 has a blocked drain hole how do i clear it
Logic fridge/freezer
no! I pushed a plastic coated flexible steel wire down the hole and it hit something solid after 2 feet, I pushed it up from the bottom and it hit the same solid. it feels like plastic, I blew down the pipe in the top hole and water blew back. Water is not flowing down.
Mar 01, 2012 | Refrigerators
I have just defrosted the lower half of my fridge freezer as it built up a big ice block at the back? i put the theromastat on 3 and ice is has started to build up again on the back of fridge
Some ice build up is normal, but it should go away when the unit defrosts...if it continues to build then the defrost is not working correctly...
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 02, 2010 | Refrigerators
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
