Question about Epson TM-U295 Matrix Printer
Driver pos I have bought brand new Epson TM-U295 POS printer and i have installed the driver which i have received with the printer. but the printer status is "Not Available" if i am installing a generic it working fine but as part of our work process it have to work with Printer driver. Any one is there to help me to get out of this issue?
  • 10 Answers
SOURCE: Epson TM-U220 Matrix Printer not printing in WinXPP
hi basiime
possible issue is port configuration. if the generic text driver works, apd driver should work too.
what may be happen is that when you install the apd driver the other printer drivers that you have were still using the same port that your apd driver were using. example, you have generic txt assigned to lpt1 and then the apd were assigned on the same port, this is were you get the trouble.
what you must do is, first, check any printer driver that you have using the lpt, say for example, you generic text is using lpt1, when you install the apd driver set it to lpt2. apd drivers will create a new port normally called esdprt. try to use that port but if that will not work reassigned the port of your apd driver to lpt2 printer port then uncheck bi-directional support. from there you should be able to print..
hope that resolves your issue.. =)
Posted on Feb 24, 2008
SOURCE: Printer not available
I'm Still trying to figure it out also, I have the same exact problem of the printer saying "Not Available" I'm going to go ahead and install an older driver for this and see if that helps at all.
Posted on Aug 13, 2008
SOURCE: can u give a download driver for pos printer
www.barcodesinc.com/epson/tm-u220-drivers.htm
Posted on Oct 22, 2008
57 varieties
  • 1653 Answers
SOURCE: TM-T88III print speeds and other issues
Try setting both switch 1-7 and 1-8 to ON for 38400 baud, set switch 1-2 to OFF to give a 4k buffer, set switch 2-5 to OFF to release the busy buffer at 256 bytes, set switches 2-3 and 2-4 to ON & OFF for medium print density and OFF & ON for dark print density or OFF & OFF for normal print density.
Also remember that the thermal TM-T88III also prints faster when the print head is cooler and slower when it heats up. The print speed is adjusted automatically depending on the voltage applied and head temperature. So make sure your power supply is providing a steady 24VDC at full load and has enough capacity to provide a peak of 7.7A in full speed mode. If you are using the printer in high temp and humidity you might want to swap the unit out for a Star Printer which performs faster and uses the same protocol or use a cooling fan.
Also make sure you use a good quality paper and that the humidity is within range at 10 – 90% RH although the paper performance will be greatly diminished at higher humidity levels.
Specifications:
High-speed = Approx. 150 mm/s {5.9"/s} max.; 47.2 lps, max. (3.18 mm {1/8"} feed);
35.5 lps, max. (4.23 mm {1/6"} feed, at 24 V, 28°C {82°F}, density level 1).
Low-power: Approx. 16.5 lps (4.23 mm feed {1/6"}); 70 mm/s {2.76"/s}
Ladder bar code: Approx. 42 mm/s {approx. 1.7"/s}
High-speed mode: Mean: Approx. 1.8A Peak: Approximately 7.7A @24VDC
Low-power mode: Mean: Approx. 1.2A Peak: Approximately 6.6A @ 24VDC
Operating temp = 5 to 45°C {41 to 113°F}
Operating Humidity = 10% - 90% RH
Posted on Aug 29, 2009
muntejaya
  • 10421 Answers
SOURCE: I have a epson TM-T8III printer of a POS windows 7 printing slow.
Please get the correct driver here : www.printcountry.com/drivers.asp
www.opendrivers.com/.../printers-free-driver-download.html
www.driversdown.com/driverslist/r_4_1.shtml
Regards, Jay__yhr4e5
Posted on Feb 26, 2011
Epson UB-U03II not working
I had huge issues with my TM-U220. It does not play well with a Centronix-to-USB cable or with Windows 64-bit. I played for AGES to try and get it all to work.
I installed the USB device driver[1] I was able to print the Test Page proving that the connection between Windows and the printer sort of worked, but when I tried printing anything from Unicenta POS, it always failed.
I finally bought a new Centronix-to-USB and a new parallel port card, used Windows 32-bit, and problem solved.
They key is to uninstall everything, including searching through the Registry to delete everything.
[1] https://pos.epson.com/developers/techresdetails.htm?ProductPK=545
May 30, 2014 | Epson TM-U220 Matrix Printer
Driver for epson TM U300PC
The actual driver for your EPSON POS-printer (TM-***) can be downloaded from EPSONs European download page under: https://download.epson-biz.com/modules/pos/index.php?page=single_soft&cid=2759&scat=31&pcat=1
Aug 08, 2011 | Epson TM-U300 Matrix Label Printer
I need driver for printer tm u220 for install for O.S windows server 2003
You can download the appropriate driver on the following webpage:
https://download.epson-biz.com/modules/pos/index.php?page=prod&pcat=5&pid=42
May 05, 2011 | Epson TM-U220 Matrix Printer
My POS printer print so slow what will i do. How will set it?
Make sure you go into properties of printer and enable draft mode..or best dependant on your needs...otherwise install new driver from 'epson downloads' for your printer
Oct 02, 2009 | Epson TM-T88III (C420863)
Tm-u295 firmware problem?
I can solve that problem but i need some help in the firmware of TM U220B. I just need the .bin files to downgrade to version 1.02
Feb 18, 2009 | Epson TM-U295 Matrix Printer
Tm-t88iv epson made prnter driver for win 2003 server r2 std
Epson POS driver will not install on a Win2K3 machine due to the InstallShield Wizard w/c checks if your running XP/2K or not.
Download the driver from EPSON POS site & extract the contents first on an XP machine.(Installing the driver will create a C:\Epson folder where ACTUAL driver is extracted).
Dec 24, 2008 | Epson TM-T88IV Label Printer
Can u give a download driver for pos printer
Oct 03, 2008 | Epson TM-U220 Matrix Printer
Epson TM-U220PD
Necesitas colocarse para los productos de la ?POS? en el Web page siguiente: https://www.epson-pos.com/cgi-bin/sdssm/main/td_login.jsp?sel_lang=es
Jul 29, 2007 | Epson TM-U220PD Matrix Printer
Epson TM-U295 Matrix Printer Logo
29 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
