Hello. I have a pinging delonghi and I'm facing a
    New Friend:
Hou can remove e4 error , please tell me ans,
Posted on Jul 25, 2013
  • Nicolo Zoupas Jul 25, 2013
    It's a pinguino 92. I forgot to write it. Sorry.
SOURCE: Delonghi Pinguino Classic Portable Air Conditoner Works for 30 min then red light comes on
Have it serviced. It cost me $250 to have a pro do it. Also, check the timer (the dial is hidden by a sliding cover on my unit). My husband cleaned it himself a year later and he took it apart to do it and it works much better now. When he opened it up, it was full of calcium deposit and dust. He told me he did not think the unit had been cleaned properly by the pro.
Posted on Oct 02, 2008
hvac1960
  • 2133 Answers
SOURCE: LG MS09AH air con turns
Replace indoor coil sensor which inserted in indoor coil bend.Thanks.
Posted on Feb 09, 2011
Testimonial: "thanks. were do i get them from?"
  • 413 Answers
SOURCE: For the past two days I have had to reset the main
Bill, first thing, make sure the outdoor coil isn't stopped up with dirt. This will cause the compressor to overheat and possibly trip the breaker. If you you can check the amp draw that would be good. Look on the data tag on the outside unit and look for RLA or "running load amps". Running amp draw should never exceed this number, it should actually normally run 10% under RLA. If its real hot where you are like it is here (109) it will be running close to RLA.
If you coil is stopped up with dirt, etc., turn off the breakers, use you water hose and sprayer and carefully wash out the coil.
If all this fails, and your amp draw is good, change your breakers. Hope this helps , stay cool.. Mark
Posted on Jul 10, 2011
Testimonial: "You very likely hit the nail on the head with your suggestion to check for clogged coils in the outside unit. We're cooling off now!"
  • 4736 Answers
SOURCE: I've lost the manual for
Your model has been discontinued, But, you can obtain an Owner's Manual by calling Delonghi Consumer Support at 1-800-322-384. They will usually email it to you as an attachment.
Hope this helped you.
Posted on Jul 13, 2011
  • 387 Answers
SOURCE: "Check Filter" light is on.
If you look thru the front panel just behind it you will see a spong filter. you will need to access it either by removing the front cover or removing the whole front of the unit . wash it in warm soapy water and replace it . let me know
Posted on Jul 21, 2011
I don't have a manual for my Delonghi DR155 dehumidifier and the Full light is on at all times. How can I upload an instruction manual for this appliance please?
Hello, click this link to retrieve your manual http://www.delonghi.com.au/support/instruction_manuals/DR155.pdf
if you have any further questions message me back and please also remember when our chat has fully concluded to rank how this opinion has helped it allows me to continue helping others in similar situations in the future. Thanks
Rick
Aug 23, 2011 | DeLonghi Heating & Cooling
How to remove panels from air conditioner - Delonghi PAC A120LE
Are you referring to the from panel of the air conditioner?
Please look for screws or hinges on the side of the fron panel and once you've found them remove the screws or gently take off the the cover from the hinge. (you may have to use a flat head screw to remove the face cover if it's locked by a clip).
Hope this helps!
Jul 03, 2011 | Heating & Cooling
Hello, to protect my self from hackers I tried to look in the Internet for the best ways to protect my PC from hackers and I did see this way start - run - command.com - host ping - ping port - ping port...
Unless you are experienced in computers you should not play with the registry (ever)
Do a system restore to before you went in and changed things. If that does not work you will need to reinstall windows.
Having antivirus and firewall turned on should be fine to protect you from malicious hackers.
Jun 15, 2011 | Computers & Internet
DeLonghi Pinguino PAC-290 - Compressor Won't Come On
Have you tried to descale the unit? I have this unit and it requires descaling often due to the hardness of the water you are using in said unit.
Jul 29, 2009 | DeLonghi Pinguino PAC-290 Air Conditioner
Jun 19, 2008 | DeLonghi PAC85 Portable Air Conditioner
Heating & Cooling Logo
44 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
