Lg inverter air conditioner asq242c5u0 - Heating & Cooling
dgjtex
  • 405 Answers
SOURCE: C4 error code on LG artcool airconditioner
www.yx2.fi/LG/wall_and_art_cool_error_codes_2007.pdf
Please read this article, I think it will help you solve your problem
Posted on Jan 14, 2009
  • 400 Answers
SOURCE: LG Inverter Air Conditioner showing CH 02 what can I do?
The model number would be on the right hand side of the outdoor unit and same on the indoor unit if it is a midwall split. If it is a flat cassette cieling type you may need to open the grill, which is simply two little levers either side of the grill, and the grill will swing open. Without the model number it is difficult to give accurate info. However, I can offer the following. One, check the condensate drain. You can just blow into the drain pipe from the outside and this sometimes clears clogged mud in the drainpan. Or two, error reading can also come from phase failure (in the case of a three phase unit) or power related problem. This can be solved by switching off the mains and then switching on again to reset. If you have a phase failure you would need an electrician to confirm that the power supply is good. Unless you have a volt meter.
Posted on Mar 04, 2009
  • 400 Answers
SOURCE: smells like something has died in my lg split
No joke, something probably did die in there. I have found rats in the drain pan or caught up in the fanmotor. Check this first. Second you can pour in some Miltons (solution used for washing baby bottles) or a mild mix of pool chlorine and water, directly into the drainpan. If you open the front cover, this is the plastic collection pan directly below the aluminium fins where the condensate water drips into. The chlorine will sanitize this area and should help remove the smell. But you should check and remove whatever died there in the first place.
Posted on Nov 13, 2009
  • 6 Answers
SOURCE: lg 12000 btu air conditioner inverter is not
This alarm state is a CH 06 alarm.
Indication for the Indoor unit pipe temperature sensor (thermister) not plugged in or out of calibration.
This alarm will also occur when the unit gas charge is to low and the indoor unit temperature reached a temperature of -5°C for longer that 30 sec. It will switch the machine off.
Posted on Mar 22, 2010
hvac1960
  • 2133 Answers
CH-02 Indoor Pipe Sensor or Outdoor Sensor Assy fault, Open or Short. Disconnect from PCB and measure resistance. Air sensor = 10 kOhm at 25C, Pipe sensor = 5
kOhm at 25C. If not replace sensor
Posted on Dec 28, 2010
LG Inverter V model LMN096HVT air conditioner multi unit has error code 9. How can I fix this myself?
  1. How to fix lg with code CH05 - Fixya
    www.fixya.com/support/t12722126-fix_lg_code_ch05May 8, 2012 - Question about LG Air Conditioners. 2 Answers ... Hi, i've just moved into a house with a LG ART COOL C24AWR N80 inverter unit in it. Have just .... LG Inverter V model LMN096HVT air conditioner multi unit has error code 9.
Jul 12, 2015 | LG LMN096HVT WaMounted Mini Split Indoor...
Error code for LG underceiling airconditioner
check error codes again LED 1 and LED 2. there is no 64 error code.
May 12, 2014 | LG Heating & Cooling
Seting remote ac lg
Why water leaks from split type non inverter Air Conditioner?
Mar 24, 2013 | LG LSC121PMA Split System Air Conditioner
Hello, I have an LG Inverter Air Conditioner - LSR122V-4 and it is only turning on for 10 minutes at a time then switches itself off and the 'power indicator light' flashes slowly. Do you know what the...
Hello, I have an LG Inverter Air Conditioner - 24BTU and it is only turning on on the inside unit. When I look on the out side unit and I see a 'red light' on and no working.
Do you know what the problem could be?
Thanks,
Gil
Feb 03, 2011 | LG Heating & Cooling
LG inverter remote control manual model LSR122v4
Try with this site:
html-pdf-converter.com/.../lg-remote-control-for-air-conditioner.html
Dec 30, 2010 | Heating & Cooling
Error Code on LG Art Cool
error code CH22 is either compressor or inverter fault.
Jun 01, 2009 | LG Art Cool LA091HNP Split System Air...
Heating & Cooling Logo
26 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
