Question about Hyundai ImageQuest ImageQuest Q15S (Silver) 15.1" LCD Monitor
Blackness on monitor
Im a schools student tec and well having an isue with a few of are monitors coming on for about a sec and then flashing off but u can still barely see the picture but everything is black like uved turned the contrast all the way up and the brightness all the way down any ideas?
  • 101jensen Sep 01, 2007
    anyone know were to get the parts to fix this problem or if it is even fixable?
Thanks for the help!! you have been a life saver
Posted on Sep 01, 2007
    Brigadier General:
  • 6,966 Answers
Hi, A common problem to LCD displays. If you can somehow still see the desktop (...barely see the picture ...) then chances are that you have a backlight problem. This may either be the light itself which is a thin florescent lamp (CCF) or the inverter that powers it. Hope this be of some help/idea. Post back should you need additional information. Good luck and kind regards.
Posted on Aug 30, 2007
  • Louie  Role
    Louie Role Sep 01, 2007
    Hi again,
    Most display's CCF and inverters share common specs with most laptops and are easily available on line. Most of them are interchangeable i.e. a CCF/inverter for a Samsung. AOC. LG or the likes would fit and work for a Hyundai. What is important is the CCF specs like tube diameter, working voltages/freq. The inverter would have a PCB number and must match the working voltages/freq, input/output connectors. Do a google and locate one near your area. Most also do online sales.
    Cheers.
  • Louie  Role
    Louie Role Sep 02, 2007
    No prob, glad to be of help. Would appreciate if you would rate this as you see it fit.
My LG Flatron L1717S wen I power up it flashes good for 2 sec
are you getting a check signal cable message? any on screen instructions?
try the cable, if it works on another monitor, then sorry to say but your monitor is fried
Sep 01, 2009 | LG Flatron L1750S 17" LCD Monitor
Monitor flashes on then goes black.
I think you have the display shut off. the button on the bottom left will shut screen off. It will come on for a few seconds if you touch the screen, but will shut off again. just push the display button again and it should stay on.
Apr 02, 2009 | ViewSonic OptiQuest Monitor
Monitor is black. Press power on monitor/screen shows for 1 sec
You will need a new monitor screen. I have had two screens go on me recently and what you describes normally happens
Dec 10, 2008 | Dell E172FP 17" LCD Flat Panel Monitor
Acer AL2017 20 inch LCD Monitor comes on for 2 sec during start up then goes black. I 've had it for a year now. During start up it comes on 2 sec goes black then as the start up continues comes on 2 sec...
Hi
I repair monitors
Based on other models , it sounds like you are having a powerboard-inverter issue.
It just so happens that I hjust got one in that's doing that, I should know in a day or two (maybe sooner) what the whole story on this model is.
Good timing !!??
ebaysbammbammfran
Oct 14, 2008 | Acer AL2017 20" LCD Monitor
About a problem in my viewsonic monitor
Hi
Actually the common problem of viewsonic LCD monitor is bad electrolytic capacitor at primary, secondary & inverter area, if your lcd using power adaptor test the voltage out, use analog or digital tester range 50v dc, if the voltage out is accurate dont be sure to your adaptor working good, open it and find bad electrolytic capacitor inside. That is common problem of viewsonic LCD monitor could cause of display flashing then back to black after few seconds. Suspect inverter area lastly mainboard.
Gud Luck!
Oct 06, 2008 | ViewSonic VE710s  (Black, Metallic...
I have a Gateway FPD2275W monitor. When I turn on the computer the monitor flashes on for about 2 sec. and then seems to go into standby mode. Even the menu screens will not show up when this happens. When...
Your power supply may not be supplying the required electricity to keep your monitor on. Try plugging your monitor in a different electricity source. Your CPU may be drawing much power from the source and not enough is supplied to the monitor. You may plug the monitor directly to the UPS (uninterrupted power supply) if the cable end allows it.
Aug 31, 2008 | Computers & Internet
My monitor not turn on when the computar turn on to . and when you try to turn on the monitor its like flash for 1 sec and tune off to black . to turn the monitor on i need to prees the botten 30 time on...
First you sec your monitor power cable is not loos or power in properly if ok then you sec your monitor VGA cable is properly conect to your pc if ok then you disconnect your VGA cable in your pc then you power on your monitor and sec that youre monetor screen. show a masege or not masage like tiis : CHEEK SIGNAL CABLE or NO SIGNAL : if show this signal then you men your display card is not responding or monitor shows nothing then you meen your monitor is faulty then contact any monitor techenican and solve your monitor problem.
Jul 19, 2008 | Computers & Internet
Lcd monitor failure
your monitor need to be service so take it to service center if you are in mumbai you can call for service
Ashok
9322133048
Nov 11, 2007 | HP Compaq FP5315 15" LCD Monitor
Samsung monitor randomly flashes black
> brand-new out-of-the-box
Presumably, it has a "warranty".
So, take it back to where you bought it, and demonstrate the problem to them, and make them repair/replace it, under warranty.
Sep 21, 2007 | Samsung SyncMaster 214T Monitor
Hyundai ImageQuest ImageQuest Q15S (Silver) 15.1" LCD Monitor Logo
102 people viewed this question
Top Hyundai Computers & Internet Experts
 Mike M
Mike M
Marvin
Marvin
Andrew Taylor
Andrew Taylor
Are you a Hyundai Computer and Internet Expert? Answer questions, earn points and help others
