Question about Opti -UPS PowerES 650 UPS System
I need Opti UPS 650B software - Opti -UPS PowerES 650 UPS System
5 Suggested Answers
viaujoc
  • 60 Answers
SOURCE: Opti -UPS PowerES 280 UPS driver and manual
Have you tried installing the software for your UPS found on this page?
http://www.opti-ups.com/download.phtml?id=16
Usualy installing the software will also install the driver.
Posted on Feb 23, 2008
Benimur
  • 6966 Answers
SOURCE: UPS
All UPS uses some sort of battery to power the unit in the event of a power outage. Like car batteries they also have a life span which can be a couple of months to a year or so. If the UPS has been in service for some time, perhaps it simply needs a replacement battery. On the other hand, if the unit is fairly new and carries warranty, it may be to your advantage to consult your dealer and claim for a replacement.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Apr 10, 2008
  • 732 Answers
SOURCE: My Opti-UPS 650ES needs repair. I bought a
tgliang, I appears that the company Opti-Ups is no longer supporting this UPS. Best bet for you will be to get a new unit to replace it. Check the Opti-Ups website. www.optiups.com 12fixlouie
Posted on May 20, 2010
Testimonial: "That's what I figured when I could not find any for sale on the web on this ever changing business. But thanks for the confirmation!"
  • 3 Answers
SOURCE: I need to get the
email me privately, I have a copy of this manual
Posted on Mar 19, 2011
Opti ups 1000 goes from battery to line and back and forth
check the input relay circuit. the issue might be cause by the welded relay
Aug 26, 2014 | Opti -UPS PowerES 1000 UPS System
Tip
There is another condition that will produce the red light alarm. This...
UNINTERRUPTIBLE POWER SUPPLY – FAULTS
Batteries in the UPS typically last 3 to 5 years and it depends upon several factors. Including the number of times the unit must go on battery power and environmental conditions. There are usually several batteries in the UPS and while the battery voltage of each battery may show 13 volts when tested with a multi-meter. This is a float voltage and a true indication of the battery voltage and its condition requires each battery to be tested under a load. If one battery is faulty in a set of batteries it will causes the whole battery system to fail and indicate a battery fault.
Also a faulty charging circuit will not charge the batteries and will cause a fault condition warning.
on Jan 22, 2011 | Opti - UPS ES800C 800VA 480W 1050 JOULES...
550c manual opti ups KEEPS SHUTTING DOWN
Hi Gerald,
You probably need to replace the battery inside of the UPS. Battery price is $27.30. If you can explain in more detail what is going on then I may be able to help you more.
Feel free to call me if you
Oct 09, 2013 | Opti -UPS PowerES 650 UPS System
Opti-ups ps1500b can't start only gives a long beep
Replace your battery. A 12v 7aH battery will cost you 24USD.
If you need UPS, Surge, or Power Related help contact Daniel @ Power & Systems Innovations 800.260.2259 or go to our website: http://psihq.com/
Nov 27, 2012 | Opti (PS-BP3000B) (PS-BP3000B) UPS System
I cannot find a manual for the Opti-UPS Enhanced Series 1500C
I have the actual guide if needed:
User Guide
Enhance Series
Models ES550C, ES800C, ES1000C, ES1500C
ES1000C-RM, ES1500C-RM
Sep 12, 2011 | Opti (es1500c) UPS System
Hi, I have an Opti-UPS ES 1000C. When power goes off, it beeps and shuts down. Everything plugged into it shuts off. It does not convert to battery power. What's wrong?
The Batteries are bad. It can't convert to battery because the batteries are bad. Plug the UPS back in then pull the plug. If if goes off the batteries are bad
Sep 06, 2011 | Opti -UPS PowerES 1000 UPS System
May 20, 2010 | Opti -UPS PowerES 650 UPS System
How do you replace the battery in the Opti Vs575c ups system
reverse down the ups four holes will be seen insert the screwdriver and open the ups also open the clamp of battery and replace the new battery take care that +ve is connected to +ve and -ve is connected to -ve usually red is +ve and black is -ve
Mar 30, 2010 | Opti VS575C UPS System
Feb 23, 2008 | Opti -UPS PowerES 280 UPS System
Opti -UPS PowerES 650 UPS System Logo
43 people viewed this question
Top Opti Computers & Internet Experts
David Payne
David Payne
Are you an Opti Computer and Internet Expert? Answer questions, earn points and help others
