Question about Water Sport
Buoyancy a ball that has a diameter of 5.5cm
What does the law of buoyancy mean
the law of buoyancy is the principle that describes why some objects float over water and some others sink: when you put something in water, it receives an upword force equal to the weight of the water it displaces.
this is important in diving in many ways.. and in particular, in diving, you always want to have a neutral buoyancy: this means that if you are standing still in water and you have a neutral buyoancy, you don't sink nor come back to surface
you have a neutral buoyancy if you "displace" always the correct volume of water.. in other words, you always need to occupy about the same volume: if you go in deep water, the water pressure will "reduce" your volume, so to mantain a neutral buoyancy you have to inflate air in your buoyancy compensator jacket to expand its volume.
otherway, if you're coming back to surface, pressure reduces and your body occupies more volume, so you have to deflate your jacket.
Apr 04, 2017 | Scuba Diving & Snorkeling
What kind of ball is used in field hockey?
A field hockey ball is similar to a golf ball in terms of shape and consistency however the hockey ball is larger about 72-73 cm in diameter.
Jan 17, 2013 | Sport & Outdoor - Others
Ball joint on hilux surf gen 3 popped out
Didn't it have a castellated nut and a cotter pin? If no cotter pin, maybe the nut worked itself back off, or wasn't tightened enough. Fit it back on to test fit: the ball stud should be smaller diameter at top and get larger towards bottom, so it pulls in tightly into the hole on the knuckle, which is also smaller diameter at its top end. Know what I am trying to say? As the ball joint stud goes into the knuckle, the more it goes in, the tighter it fits. When you get it in, it should be a very tight fit.
Jan 06, 2013 | 1993 Toyota Pickup
What is the shape and size of an official ping pong ball?
Theofficial ping pong ball is spherical and has 40 mm diameter.
Aug 05, 2012 | Sport & Outdoor - Others
What is a medicine ball?
A medicine ball is aweighted ballroughly the diameter of the shoulders. Oftenused for rehabilitation and strengthtraining, it serves an important role in the field of sportsmedicine. It should not be confused with the larger, inflated exercise ball.
Jul 09, 2012 | Exercise & Fitness
We have an old leap frog learn around playground with tube topper and the balls are missing. can replacement balls be ordered
I have been working on this problem myself. The playground uses 2" diameter balls. So any 2"ball should work. Leapfrog themselves make repalcemetn balls for another toy that meet this criteria(Peek-a-Shoe Talking Octopus Spare Ball Set)..
Dec 31, 2010 | LeapFrog Discovery Ball
Sound driver
What does a computer driver have to do with Scuba Diving?
Jun 09, 2009 | mares JUBILEE Buoyancy Compensator
I have a Dacor airtrim BC. The oral inflate tube checkvalve is leaking. I need a new valve.
it may be dirty. you can unscrew the valve and see if any dirt or sand is keeping it from sealing.
Jan 05, 2009 | mares JUBILEE Buoyancy Compensator
Water Sport Logo
427 people viewed this question
Top Water Sport Experts
Tom Chichester
Bill Boyd
Are you a Water Sport Expert? Answer questions, earn points and help others
