Question about Nuova Simonelli Microbar Espresso Machine
Temperature problem Hi I changed the steam prob and control board but the machine still showing steam temperature why this and where i can check it, Laso can you provide me the wiring diagram of this machine board 04900653
    New Friend:
You can check suplly wire of heater there is a capacitor resistance check it.
Posted on Sep 24, 2013
Can I regulate the temp on our machine? our Rancilio machine seems to be to be running on too high a temperature. Meaning, we barely turn the steam wand on to steam milk (after the light goes off), an
Silvia has two bimetalic switches that control the boiler temperature. One for brew water and one for steam. They are not exact and they can go bad. They are cheap and easy to replace. Just Google for Rancilio parts.
A much better fix (and more expensive) is to switch to PID control. Google for Rancilio PID control. The conversion is $250+ but once you've gone PID, you'll never go back. The temperature is exact, fast, and totally under your control.
Jan 12, 2015 | Rancilio Silvia Espresso Machine
Freezer alarm goes off even though the freezer temperature is below -20C. The compressor runs continuously.
From the sound of it the temperature control is bad. I'm only stating this because if the cold control (temperature control) isn't converting the temperature to electrical signal properly, the machine will constantly run trying to reach the set temperature the cold control is set at. Question, is there a digital display showing the temperature or did you use a meter or thermometer to check it, and how is the temperature set, by a digital control or a dial, rheostat or any other type of manual control?
Jun 21, 2012 | Refrigerators
STEAMER NOT WORKING SHOWING E8 FAULT
Hi, error 8 is showing you there is something wrong with temperature control pot. This is soldered to the pcb so you need to get someone to replace this or check the connections, otherwise the pcb needs replacing
Nov 28, 2011 | Combi Steamer electric built in steam...
Got a malfunction 4 on a franke flair ? Any ideas
Hi.I think its a temperature measuring fault in the steam circuit. Most likely to be the thermal sensor on the thermoblock. Check to see if the sensor wires are broken or corroded. Can also be the control board. I'll put my money on the thermal sensor. Dazza REPAIRER
Sep 24, 2011 | Coffee Makers & Espresso Machines
"PROB" shows when fryer is
Computerboard will display "PROB" error when it could not sense resistance reading from the temperature probe sensor (temperature probe sensor is either open circuit or short circuited). Check first the temperature probe connectors, tighten loosely fitted connectors on wiring harness and computer board, then check if the wires are not damaged. Disconnect the temperature probe and check the resistance using an ohm meter. If the reading is either zero or infinite, you have to replace the temp probe.
Dec 18, 2010 | Pitco Frialator SG14 Deep Fryer
Mr. Steam Prr erro
Hi, kindly check the connection of your temperature probe down to the main board maybe its loose.
Oct 03, 2009 | Mr Steam Mr. Steam MS 81500E AutoFlush
Not enough steam
Hello 828698,
One thing that you will want to look for on your machine is to be sure that your temperature gauge is not malfunctioning. In some cases with the FF machines, the temp gauge will not work properly but the machine is still working just fine. When you start up the machine you should notice the the bottom light on the left hand side will come on and be lit solid. Once the machine is up to brew temperature the light will go off or begin to flash. This means you are ready for brew. Then hit the steam button to prepare the machine for steam. Again, the light will come on and be solid until the machine is up to steam temp. Then the light will go off or begin to flash. If this is happening than your machine is working fine and only needs to have the temp gauge replaced. If, however, you do not see this light go off it could be a couple of things. The control board could be malfunctioning, or the heating element is no longer maintaining the proper temperature. In this case it is generally recommended that the machine goes in for service. Or, you can contact Empire Fulfillment (877-855-4540) to order parts for the machine if you are comfortable doing the repair on your own.
Aug 01, 2009 | FrancisFrancis! X1 Espresso Machine
Oven not getting to proper temperature
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Dec 06, 2008 | KitchenAid Architect Series KEBC208KSS...
Machine will turn on but that is it
The light 20 is power control light, 26 light if any problems are indicated on the machine and should only light if there are any trouble with the machine. 22 should light when the temperature is right.
Try to open the steam knob and make a cup of water.
Apr 04, 2008 | Saeco Vienna SuperAutomatica Coffee...
Steam leaking from near temperature control sensor
your machine is over temperature. check your gauge pressure must be 1.2 bar only and you need to check if pressostat is cutting out and tighten the leaking fittings.
Mar 13, 2017 | Nuova Simonelli Oscar Coffee Maker,...
Nuova Simonelli Microbar Espresso Machine Logo
Top Nuova Simonelli Coffee Makers & Espresso Machines Experts
J.D. Browning
J.D. Browning
Andrew Taylor
Andrew Taylor
Gil Shultz
Are you a Nuova Simonelli Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
