Question about Microwave Ovens
Panasonic nn sd686s
Door broken
MicrowaveSvc
  • 9086 Answers
SOURCE: broken door catch, possible spring,
If you gently push up on the door latches (hook-like devices on the door) there should be spring tension. If they just flop right up, the spring is off.
Normally the problem is not the spring, but a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
If it's the door panel, it's usually easier and cheaper to use epoxy and some kind of hardware to fashion a new spring mount.
The door latch head (hook) is easy to replace or repair if that's the issue.
We have critical safety & disassembly info at our site, linked here.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
The best place to order parts is Tritronics. You can also call them at 866-779-5835.
Posted on Nov 27, 2008
MicrowaveSvc
  • 9086 Answers
SOURCE: Panasonic Microwave NN-T785SF Door switches are broken.
Oddly enough, the switch holder is called a "door hook". For this model, it is part # F3020-1200 in case that is bad.
The hook assembly that protrudes from the door is called the "door key".
If you gently push up on the door key there should be spring tension. If it just flop right up, the spring is off inside.
Normally the problem is not the spring, but a broken spring mounting tab on the door key or the inner door panel.
If it's the door panel,it's usually easier and cheaper to use epoxy and some kind of hardware to fashion a new spring mount.
The door key is easy to replace or repair if that's the issue.
Normally you have to separate the door panels (as shown in the attached photo)and then you'll see the screws you need to remove.
The best place to order parts for this brand is Tritronics. Or you can call them toll-free at 866-779-5835. Their Web site will be down until Jan. 2nd.
Posted on Jan 01, 2009
  • 4090 Answers
SOURCE: Panasonic NN-A554/NN door catch assembly broken.
This is not an easy fix as a DIY because of the way the interal screws are positioned. The inner glass plate and frame have to be removed then using a stick mirror locate the screws and work in reverse of the mirror image. It is easier to have the skilled guys do it I assure you
Please rate our help to keep the service online
Posted on Aug 17, 2009
SOURCE: Panasonic microwave model NN-2959: can't open door.
Your DOOR LEVER probably is broken. To open the door remove the filter (2 screws at the top) then remore the control panel by removing the screw holding it in place UNPLUG THE MACHINE. then unlatch the door. BUT I am trying to find a door lever and find they are no longer availabel.
Posted on Dec 21, 2009
SOURCE: Door Release Button not working on Panasonic Microwave NN-T664SFT
The problem I had experienced with the Door not opening easily will be resolved by removing the micowave oven top cover with a tamper proof torx head, replacing the door switch and reinstalling the top cover.
Posted on Jan 20, 2010
I have a Panasonic microwave. It is Model NN-T774SF. It has an inverter. The latch on the door will not close. Is it worth the cost of repair?
This is usually a pretty simple fix.
The spring has probably become disconnected from the door latch head assembly or inner door panel.
If so, you can either order a replacement for the broken part, or install a small screw into the broken part, reinforce it with epoxy, and then reassemble everything.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the parts involved.
Or you can watch a
YouTube video (not a video I made) that demonstrates how it's done.
Oct 25, 2012 | Panasonic NN-T774SF Microwave Oven
Panasonic NN-SN789S
Hello, I don't know if it is helpful, but here is the manual - Panasonic Nn Sn789 Users Guide
Aug 20, 2012 | Microwave Ovens
I have a Panasonci NN-SD686S and after a power cut last night, the microwave is now in demo mode. After power cuts previously this has never happened, and I can't find anything in my manual to...
To set Demonstration Mode: press micro power once, then press Stop/Cancel 4 times. To cancel Demonstration Mode press Micro power once, then press Stop/Cancel 4 times.
Sep 09, 2011 | Panasonic NN-C994S Convection/Microwave...
Hi! if the parts is to much expensive i think it is not worth it. considering the years it has serve you.
Sep 11, 2009 | Microwave Ovens
PANASONIC NN-S952WF FAN AND CAROSEL STILL CONTINUES WHEN DOOR IS OPENED. NOT SURE IF THE MICROWAVE CONTINUING AS WELL WHEN DOOR IS OPEN.
The door interlock system has beem compromised , meaning it shifted out of position or the interlock has broken. Dont continue using it like that it will eventually blow the fuse.
May 13, 2009 | Panasonic NN-S952 Microwave Oven
Nn t993sf
Sounds like the door switches are out of adjustment or broken.
I would take it to a shop for repair. Microwaves are almost always repaired affordably unless it is really old.
Hope ya fix it!
Feb 07, 2008 | Panasonic NN-T993SF Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
