Question about Electrolux Washing Machines
Electrolux washing machine error code e30
Motor not rotate and not washing the cloths
  • Official Brand Answer
  • 4,342 Answers
Hello sreenivasulu, if you are receiving error code E30, first check if it is a false error code by resetting the power to the appliance by either unplugging it or flipping off the breaker for about 30 seconds. If the error code persists, it could potentially mean a number of things: a pressure sensor issue, defective wiring, valve assembly problem and/or control board issue. I would strongly recommend connecting with an expert technician to assist further.
Posted on Jul 25, 2013
  • 49 Answers
SOURCE: electrolux ewf 1435 washing machine
i can not find e50 in any of my servive manuals, are you sure it is e50 ?
Posted on Feb 19, 2008
SOURCE: Zanussi zwf1631w jetwash front loading washing m/c
had to call an enginer out, the problem was down to a faulty motor rota, to identify if e30 is this fault, rotate the drum (so the motor rotates) and try to start the m/c. if it runs ok you know to change the rota. hope this may help someone
Posted on Sep 16, 2008
SOURCE: aeg 74640 error code e30
What does the E40 error code mean?
Posted on Sep 18, 2008
  • 135 Answers
SOURCE: zanussi washing machine zwf1437w error code e30
E30 indicates a pressure system fault. There can be several causes but the most frequent is a blockage in the system.
First thing to do is check the filter on front of machine.
Please do this and report your findings.
Posted on Jan 29, 2009
e-Guru
  • 3917 Answers
SOURCE: error code e40 on my washing machine electrolux
The Error E40 warning means the door is not properly closed. The E40 error code indicates a loss of electrical power usually but not always due to the door not shutting properly or not locking. But, since you smelled burning it could be any electrical short that blew a fuse and shut the machine down. It could also be the motor windings with the internal overload protector shutting it down.
Thank you for contacting Fixya.com
Posted on Aug 06, 2009
My Electrolux washing machine is showing error codes MB Alarm E33, and UI Alarm E00. It has stopped working altogether. Door wont open and clothes are stuck in ther. I have run a diagnostic test and it...
I appreciate your post, Anonymous!
From what you have described your Electrolux washer is displaying an error code of MB, E33, and UI Alarm E00. I have been unable to locate those error codes. May I have your model number, please? With that information I will be able to assist you further. -Matt
Mar 19, 2015 | Electrolux Washing Machines
E4 error code on electrolux washing machine ewt 854s
E4 is the pump is blocked {not running} pehaps a hair pin or clothing wires get stuck
fully drain it and take the filter out
and clean it
these error codes are similar to candy
youll get an idea from this video
https://www.youtube.com/watch?v=kzhlvB2LjXg
Nov 28, 2014 | Electrolux EW1000i Front Load Washer
I have washing machine hotpoint model wm71n showing error code E30 and washing machine rund for one minute then stops, please tell me what i should do.
Error code E30 generally indicates a problem with the motor.
Check brushes and associated wiring and connections.
Oct 30, 2010 | Washing Machines
A washing machine Electrolux EWF 1025 does not start up.
E50 is displayed if the there is no drum rotation. drum jammed not allowing motor to turn/ no circuit through motor(poss worn out carbon brushes) less likeley but poss short on motor relay on electronic board.
Jul 24, 2010 | Electrolux Washing Machines
E90 ERROR ELECTROLUX 1087 WASHING MACHINE
Error 90 is a common fault code in domestics within the Electrolux, Zanussi, AEG range. It's a wiring fault /connection normally between the printed cicuit board and wires. switch off power, remove lid, pull off each connector on board checking for clip holding the connector in place, one at a time, look for arcing marks, rub pins gently with clean cloth, tensinsion up clips in connector(delicately) and refit. having done this, test again with a wet load on spin, then a wash programme. Before dispairing check the motor coonnections.
Feb 28, 2010 | Electrolux EW1200i Front Load Washer /...
Error code e30 see user guide .comes on and stops washing do not have user guide
E30 is a motor problem which is most likely brushes need replacing.
Hope this helps & Thanks for using Fixya.
Jan 18, 2009 | Washing Machines
E30 error code
Error E30 is a motor drive problem. Would check motor brushes as most likely fault.
Dec 16, 2008 | Hotpoint Ultima WD72 Front Load...
HOTPOINT WD71 ERROR E 30
Hello john walker24
Welcome
You said, you have a Hotpoint Ultima 1200 Washier dryer model WD71s and keep getting an E30 error code after it fills with water.
Any idea what the problem is?
This is what Hotpoint tells us!
E30 = A motor drive problem has occurred.Try running the programme again.
If the problem persists call for a Service Engineer.
BUT, I will tell you to unplug the appliance for 5 minutes and see if this resets the system and solves the error code.
Sometimes it is only a glitch and you can reboot and be alright if there is really no mechanical failure!!
Let me know how it goes?
Huuum,
Please remember to leave a rating!
Thank You.
Waiting for your response!
Oct 01, 2008 | Hotpoint Ultima WD72 Front Load...
Sep 12, 2008 | Zanussi ZWF1440 Front Load Washer
Error code e30
This error relates to the motor drive. Plug off the wall, open up behind, look for broken belt. If the belt is good its the motor brushes. Secure connections to the motor, look for loose wires.....
& pl rate if helped...............
Dec 04, 2007 | Zanussi FJS1225W Front Load Washer
Washing Machines Logo
679 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
