Question about Dryers
Defy auto maid tumble dryer.. my dryer has power but when I turn on timer the power light goes off an dryer don't spin what can be the problem
  • 209 Answers
SOURCE: Tumble Dryer won't start
assuming what you say you checked is correct and working then the next place to look is the start relay, located behind the front timer control panel, this sis more often than not a cubed shape box made of clear plastic with about 6 spade connectors on it, look for burn marks inside it, replace if looks damaged, do not attempt to bypass or short out to test, as you will blow the timer or and control circuit board and cause extensive damage
Posted on Sep 26, 2007
  • 139 Answers
SOURCE: Defy Tumble dryer not heating
Is this an electric dryer? If so, the most common problem would be a burned-out heating element. There could also be a defective temperature sensor inside. This will need to be evaluated by a qualified appliance repair technician to find the exact cause.
Posted on Jan 18, 2008
  • 66 Answers
SOURCE: Dryer is working but wont tumbel
This does sound like the belt has broken. Is the Defy autodryer the one that made the sound and then stopped tumbling?
Posted on Nov 12, 2008
SOURCE: drying timer on auto dry
I called LG...they said to unplug the dryer for 5 min. to reset the timer ...this solved the problem.
They also said not to use dryer sheets during the sensor dry cycle as the coating on the dryer sheets causes the sensor to malfunction as it can't read the humidity level in the dryer.
Posted on Dec 29, 2008
protek480
  • 1723 Answers
SOURCE: got a Defy tumble dryer but it's not spinning.
Watch the video to see how to replace belt:
Posted on Sep 17, 2009
Tumble dry wont turn and dry
check that your motor spins and your belt is on the drum. you say its heating so your door switch isn't the problem.
May 30, 2014 | Cell Phones
Dryer won't tumble but gets hot
try holding the door switch with your finger and turning the drum with your hand after you push the start button , if this does not start it then you will have to replace the motor
Feb 24, 2013 | Dryers
Timer stops at 6 minutes but continues to tumble.
You will need to replace the auto dry sensor on your dryer.
Mar 11, 2012 | LG DLE2516 Electric Dryer
Defy autodry, comes on timer works but will not tumble
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 15, 2011 | Dryers
My Defy Tumble Dryer model DTD256 is not heating its blowing cold air. My on off switch broke so i opened up to fix it and when i closed up it wasnt heating but it comes on and turns etc.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 01, 2011 | Dryers
Nov 11, 2008 | Dryers
Dryers Logo
32 people viewed this question
Top Dryers Experts
