Just bought RCA stav-3660.When i hooked up surround sound ,the volume goes up and will not turn down
Ok well its all put together right but when i turn on speaker button the volume just goes on all the way and wont turn down can you help?
techman
  • 3130 Answers
SOURCE: Volume goes up on its own and stays up.
Aren you sure that the volume up button is not stuck in . It should feel just like the rest of them A little click? It could still be shorted,or the capacitor across the switch could be defective. If all this seems good then the eeprom, or the microprocessor,or the line or trace going to the volum button could be shorted. This is not a repair you should attempt unless your a tech. Now the button thong can be looked at after the set is unpluged and the back is off, gently slide out the chassis toward the rear of the set just a little and slide it back to see if the button is released. if that dosent help then you will need to take the set to The repair center. Good Luck
Posted on Jun 10, 2006
SOURCE: TV not turnig on
change flyback
Posted on Nov 13, 2008
  • 5 Answers
SOURCE: RCA tv when plugged in comes on and right back off
May be intermittent connections to the tuner shield. Usually a sharp rap to the side of the set will cause it to come back on. If it does, take to a repair shop and have the connections repaired. Anyone that works on RCA/GE sets will be familiar with the problem. Do not keep hitting on the set, further damage can occur - such as the data in the eeprom being erased which can turn into more dollars.
Posted on Apr 20, 2009
jrweighing
  • 183 Answers
SOURCE: TV Volume goes up by itself and remote wont work
There are 2 reasons that this is happening in respect to the problem commencing after your daughter has cleaned the tv. Either your daughter has sprayed the volume button with cleaner and fluid has got into the the graphite pad under the button and conducting as though the button is being pressed continuously..or she has put too much pressure on the button if it is a metallic plate contact switch.One way to find out is by pressing the down volume button.does it it click ? if it does.try the up volume..If that doesnt click the problem is the metallic plate is dented in making contact hence a new switch. Another cause ive seen is cleaning the remote control with cleaner and fluid has got into the remote and it sends signals to the tv all the time..If the remote control is hidden under a cushion and the problem stops, then the remote control is at fault and needs drying out..Hope this helps :)
Posted on Aug 04, 2009
SOURCE: Toshiba (Model : 36A43) - volume goes down automatically
I am having same problem on 32 inch same problem. After playing with board with no results,I tried front buttons and found that if I held the power button in ever so slighItly as not to turn it off, it fixed problem which is the micro on/off switch, I removed the switch and used the remote and everything is back to normal, I am about to insall a used micro switch after I finish typing this but I am sure this will clear up volume problen and menu going crazy problem if not I will just leave micro switch out and use the remote, and I will get back to this board only if that micro switch still causes the problem, so if I don't post in next hour the problem is fixed and I'm more than glad to help.
Posted on Sep 14, 2009
Sound bar keeps turning off automatically
Main board [system control side circuit] fault. Contact any service technician. Gopakumar Gopalan Google
Jan 19, 2015 | RCA Televison & Video
I've got a rcs STAV 3880 surround receiver wit ful volumn al the time
Sounds like a shorted audio IC or bad connection in the limiter circuit.
Mar 01, 2014 | RCA Optimus/Stav-3880 Rcvr Parts - Board -...
RCA Stav-3880 turn stereo on goes to full volumn
Take the batteries out of the remote control, then apply a piece of black tape over the IR sensor, Unplug the power, wait a few minutes, now power the unit back up, does the unit still have the same volume high symptom? If so, remove the tape and see if the unit responds to any other commands(other than volume) from the front panel. If it responds to the panel controls, the processor is most likely good. very seldom is the IR transistor bad, if it is no input command will work.
Feb 15, 2014 | RCA Optimus/Stav-3880 Rcvr Parts - Board -...
How do i hook up my surround sound receiver to my asus cm1740 desktop
For you to hookup your surround sounds to your Computer, use a RCA cable, plug the RCA cable to the input marked CD and you used an adapter that has a RCA input, it should have be of the same plugin which is (red and white) on the adapter and you plug that end into the audio card. Be certain that the volume is turned down before making any connections. now you are set to go.
Enjoy.
Aug 03, 2013 | ASUS Essentio CM1740-02 Desktop 2.4GHz 4GB...
Surround sound
You should have the RCA TV plugged into the OUT plugs on the TV and just plug them into the IN on the back of either the ld tv or cd inputs on the receiver then plug it in and set the setting on the receiver to the same RCA you plugged it into then turn your TV and receiver volume up and enjoy.
May 07, 2013 | Audio Players & Recorders
I just bought a Coby home theater system 5.1 surround sound dvd/cd/ player model#765. I've got it all hooked up but I have one problem, when I want to listen to my tv stations through the home theater...
Hi - Your Home Theater System and your TV should have separate volume controls. You should be able to control each individually. Start by checking the volume level on your TV with your HTS shut-off. Turn the volume on your TV all the way down to 0.
Next, turn your HTS on and check the volume level there. Is it still loud? If so, try turning the volume down on your HTS. That should do the trick. If its not loud then you know you can control the volume on either the HTS or the TV. If this answer does not help, then please write us back with a little more detail. Thanks.
Feb 28, 2011 | Audio Players & Recorders
I just bought an rca surround sound rtd315w - mp3 won't work
You must select that input with the RCA surround sound
Apr 20, 2010 | Televison & Video
No surround sound on normal tv just dvds
Do you have a cable box or satellite box? If you do, try hooking up your TV sound through the box. Look for audio out in the back of box (white/red RCA Jacks). Hook RCA cable from cable box to surround amp. Even if the audio out jacks are being used already, you can use Y connectors to hook up the surround amp to the box.
Hope this works for you!
Jul 23, 2009 | RCA Audio Players & Recorders
Need hook up diagram for Samsung HDTV using HDMI with Cable box and Samsung 5.1 Surround Theater System
you can run a fiber optic cable out of the tv into the surround system if the sytem has a fiber optic input, or your tv should at least have red and white rca cables for audio out, then you just pick any input on the surround sound and any audio from dvd players ect thats hooked up to the tv will be sent through that one input on the surround sound. The only thing you'll have to do is turn the volume up or down on your sound system.
Jul 09, 2008 | Televison & Video
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
Electro Med Services...
