Question about Ovens
Simpson 2001 electric oven: oven, large hotplate & clock not working
We have a Simpson 2001 fan-forced oven (65-647). A couple of days ago, in turning off the oven, the control knob was turned in the wrong direction and a sound described as a 'boom' was heard. Now neither the oven, the largest (back left) hotplate nor the clock are working. The griller and the other three plates are still operational. Any help in determining the cause of the problems would be much appreciated. I was initially thinking it might be the selector switch, before discovering the one hotplate also inoperable. Now I'm thinking it seems more like a blown fuse. Does that seem reasonable? Do these ovens even have fuses? If so, where are they typically located? Is it possible that a blown oven element could also knock out the clock and a hotplate? Thanks, David
burzerko
  • 254 Answers
SOURCE: power outage Blodgett Conveyor Oven
On the back of the motors there are safty overload reset's, these are small red push in buttons. Also there are fuses for each motor inside the control panels assembly.
Posted on Jun 10, 2008
barkencoa
  • 3463 Answers
SOURCE: Neff B1432 oven element and fan not working
If the element has failed again in such a short time , then I would suspect that the fan is the culprit.
If the fan is not working, then the element overheats, and burns itself out.
The fact that the fan spins freely, proves nothing, as the fan can be still faulty.
The only way to prove if the fan is faulty, is to remove the oven from the housing, and remove the rear outer panel of oven,.test with a meter set to ac mains and test the fan motor terminals to see if there is power there when oven is set to heat, disconnect the element first. ,if there is ,and the fan is not running then the motor is faulty..
If there is no voltage there, then problem is elsewhere, and you will have to investigate furher.
Plz rate my solution.
Thanks.
Posted on Jan 12, 2009
MNfisherman
  • 11896 Answers
SOURCE: I have an old electric Chef Glendale 600 fan
There is a fuse in the back if you remove the rear panel. Check to see if the fuse looks good. If the element is bad, it won't effect the switch, light, or fan. The switch, light, and fan all run off of there own circuit. If that circuits is bad, has a burnt out fusible link, or the electrical circuit board they connect to is bad, then they won't work. You will likely need to trace the wiring from the control panel to the circuit that runs these three things. Use a volmeter to test for power and you can also use an ohmmeter to test for continuity of the circuit itself.
Posted on Oct 07, 2010
HansPP
  • 2510 Answers
SOURCE: My Omega oven has stopped
The oven has a thermal trip switch behind the back wall of the oven and is under the back cover. It is attached to the back outside wall of the oven towards the top. Some thermal switches can be reset but most usually have to be changed. If you are handy you may be able to open the switch and click the little disc backwards and reassemble the switch. Make sure to refit the disc the right way around. Ensure that the power to the oven is off or the plug is pulled out before attempting to remove the back cover.
Posted on Mar 27, 2011
Testimonial: "Prompt reply that got me looking in the right direction."
  • 973 Answers
SOURCE: i have a 'Simpson 2001
I would say that the oven element has blown. It is common especially if you have a fan forced model. Make sure the fan works before you go buying a new element as the replacement will fail early. Simpson ovens have to be removed from the wall cavity to replace the fan and the element. Make sure you tuen the power off before doing anything...
Give the parts supplier your model number so that you get the fight element ( and fan) if necessary.
Posted on Jul 31, 2011
I need a owners manual for Simpson Concorde fan forced oven?
I recently helped a friend fix the oven in his secound home, turned out the timer was shot. But, in order to find this out, we had to pull the oven from the wall, and there was a wiring diagram in an envelope on the back of the oven. That is all that it took to figure out the problem.
Dec 14, 2014 | Ovens
Need illusrated wireing diagram for 18 year old defy gemini petit chef electric stove
Oven:
power comes in, goes to overtemp > timer > function switch > thermostat > element then back to neutral
fan & light come on with function or thermostat switch.
what else do you need to connect?
Oh, hotplates. Power in > infinite switch > hotplate and indicator then back to neutral.
Watch out for two phase with indicator light.
Oct 18, 2013 | Ovens
My oven is dead - no display, no nothing. Circuit breakers are fine. Turned them off overnight, still nothing on oven this morning. This happened about a year ago but oven came on again ten minutes...
What you need to check is for power at the clock.TURN OFF BREAKER gain access to clock and use volt meter. One the clock will be wires maked L1 & N on those 2 wires when breaker is turned back on their should be 120 vac. IF 120 vac at those 2 wires,replace the clock, if not 120 vac into clock check for burnt/broken wires
Aug 20, 2011 | Jenn-Air Electric Single Oven
I have a 'Simpson 2001 Thermaflow Oven' and a few months ago, i was heating it up, and i heard a pop, from then on my oven has not heated up, i cannot seem to find what is wrong with it!! Please...
Jul 31, 2011 | Ovens
Simpson Evolution 906 Oven light. how to replace it?
I have just replaced mine & had the same problem. I couldnt remove the cover. I found that I just couldnt grip the cover well enough. I got some rubber washing up gloves & used them to grip the cover. It was still tight but it un skrewd quite easy this way.
Jun 28, 2010 | Ovens
Simpson Apollo can't set clock so oven won't work
I don't know if this will help. For the 720ef , this is what you need to do.
There are five buttons on the clock panel and from left to right they are:- Minute Minder, Cook time, Ready Time, Plus and Minus.
TO SET THE TIME OF DAY
Press the Cook Time button and the Ready Time button simultaneously. Use the Plus and Minus buttons to set the time.(24hr clock).
TO SELECT AN ALARM TONE.
Press the Minus button to listen to the first tone. Release it and press it again to listen to the second tone etc (3 tones)
Releasing the button after the tone has sounded will automatically set that tone.
SETTING THE MINUTE MINDER.
Press the Minuter Minder button and either the Plus or Minus buttons simultaneously to set the time.
You can cancel the timer at any time by setting it back to 00.00 by using the Minus button.
After setting, the display will revert to the time of day, but by pressing the Minute Minder button again, the display will show the remaining time.
If you want all the information, then it is best if you supply a vaild email address and this will give you access to my BT Digital Vault, where you can have a complete copy of the handbook that I have scanned in.
Apr 30, 2010 | Stoves 720EF Electric Double Oven
Simpson 2001 series upright electric stove oven does not get hot only gets warm
It could be the oven element (behind the cover plate in the back of the oven), or the fan not blowing the heat into the oven.
Aug 19, 2008 | Ovens
Ovens Logo
75 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
