Question about Toshiba e-Studio 202L Copier
Drum unit code e020 - Toshiba e-Studio 202L Copier
  • Toshiba Expert
  • 414 Answers
Check the 2nd transfer roller there was an issue with these and Toshiba issued an updated one. Most in the production line were shipping with 2 one in the machine and one in the box. The setup tech was suppose to switch during setup but I keep finding the wrong one in the machine. These will slow down the drive assembly causing all sorts of headaches.
Also check the exit switch, I have had a bad spring on the actuator that did not return the switch fast enough causing e020.
Posted on Jul 25, 2013
CLC 1180 with error E020 with sub 124
first check this site for the error codes.
clik here
The error code E020 refers to a density problem with one of the Drum Units.
ur hopper motor has jammed and it is not allowing the toner to go to the developer just open the hopper motor and put it into the developer or remove the connecter attacted to the developer. it will work . there is a gear actually on the motor which breaks.
So the only sol. is to replace, if it is under warranty caontact the customer care..
Goodluck,
Dont forget to rate me as fixya..
Jan 29, 2008 | Canon CLC 1150 Color Copier
Hello, i just replaced the black toner of my IR 3200 and i get the error code E000020-04a0. Can anyone help me please
E020-04a0 is a defective drum unit or a drum unit unable to produce the correct color density needed by the machine. E020-0Xa0. X being the color the code points to, count from left to right if you open ur toner door and look at the colored stickers. Just Replace the black drum and ur good to go Part Number is 7625A001AA
Mar 02, 2012 | Canon imageRUNNER C3200 Copier
Canon iRC 2620 error code E000020-04c0 Any ideas?
The error code E020 refers to a density problem with one of the Drum Units. The sub-code 03b0 refers to one specific Drum Unit, of which
I'm not sure. I believe if you go into service mode and check Density, you'll see each Drum Unit listed there. You are looking for an average Density reading of +-2.5 for the Units. Don't get crazy trying to reach that value, but look to see which one is way off and that may be your culprit. Or maybe one of these other guys may be able to tell you which unit the sub-code is pointing to.
Mar 14, 2011 | Canon imageRUNNER C3220 Printer
IR 3100 error. E020-01A9, E020-02A9,
E020-01A9 Error Code : iR C3100 Series
Hi there
I have looked it up and what it says about it I have put down for you so you can gave it a try hope it works for you.
Approved
Symptom
E020-01A9 Error Code.
Cause
For ATR control, the detected Toner/Density ratio exceeds the lower limit (3%) 3 times continuously for Yellow
Action
The ATR Sensor and Patch Image Read Sensor both determine toner density. Depending on the density readings the copier will or will not add toner. Check the status of the Drum Unit under COPIER>DISPLAY>MISC>DRUM-LIFE. The Patch Image Read Sensor looks at a patch of toner that is generated on the drum for each colour and determines the amount of toner that is in the patch by the amount of reflected light. If the drum is not creating the patch correctly, the patch reading will be affected. Replace the Drum Unit if it is 80% of its rated life or higher. ..
Feb 16, 2010 | Canon iRC3100 Printer
E020 01BO What does this error code mean?
E020 indicates a Black Toner malfunction. If you've recently changed the toner and failed to distribute the toner by gently shaking it from side to side, this could be the cause of this error or if the toner is very low it could trigger the same error.
01B0 is a drum error related to your toner error message. If toner cartridge is good, remove the cartridge, clean the drum, replace the cartridge and both errors should clear. A dirty drum will also trigger your 1st error e020.
Nov 16, 2009 | Canon CLC 1120 Color Copier
Error code E000020-01b0, E000020-0260
E020 is a Drum/developer error code
-01b0 is a yellow drum error
-0260 is a magenta drum error
drums need replaced
7622A001AA Yellow drum part#
7623A001AA Magenta drum part#
7624A001AA Cyan drum part#
7623A001AA Black drum part#
Aug 20, 2009 | Canon imageRUNNER C3200 Copier
Error codes E00020-01b0
you need to replace your yellow drum unit with a new one, error code is as follows E020-01(yellow), -02 magenta, -03 cyan, -04 black. for future referrance
Jun 05, 2009 | Canon imageRUNNER C3200 Copier
Error code e000020-0021
getfile.asp?rid=1258 November 12, 2007 getfile.asp?rid=3215 Product : imageRUNNER C2880 / C3380 / C2880i / C3380i Title : E020-0021 Error :
E020-0021will not reset after the machine is powered off and on. Replacing the Drum and the ATR Sensor did not clear the error.
Workaround :
In this case cleaning the Dust Proof Glass fixed the error.Check the Dust Proof Glass for soiling.The glass is located under each unit and may have toner spilled on it. Clean the glass with the tool provided on the front door. Instruction's are also included there.
getfile.asp?rid=22945getfile.asp?rid=22948 Canon USA, Inc. Systems & Technical Support Division
Mar 18, 2009 | Canon Office Equipment & Supplies
Error Code
SPECIFICALLY...you need to replace the Black drum unit.
the sequence of that particular error code is;
E020-01XX(Yellow drum)
E020-02XX(Magenta drum)
E020-03XX(cyan drum)
E020-04XX(Black drum)
Apr 02, 2007 | Canon imageRUNNER C3200 Copier
Toshiba e-Studio 202L Copier Logo
64 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
